In v5.x, In winbox, if you search something from the “find”, highlights disappear if you scroll down the scroll bar.
In v4.x, this isnt the behavior so you can easily find what you are searching for.
so I guess this is a bug ! (it makes it very diffucult to go through OSPF routes using find)
bump
detailed explaination: as soon as item list gets focus, ‘Find’ string is cleared. in all versions. but before v5, after clicking scroll bar, focus stayed in ‘Find’ textbox. in new v5 interface, even when you click scrollbar, ‘Find’ looses its focus
MT? =)
thanks for bringing attention to this Chupaka. I thought I am the only one having the problem
Any words from MT ?
thanks for the report, I have filed this as a bug to fix.
