Find direct (connected) neighbors in MikroTik
Good afternoon.
When using a MikroTik device, if you execute the command /ip neighbor print, it will show all the network neighbors -irrespective of whether they are directly connected to the MikroTik device or not-. I was therefore wondering if there is a way to find out which device(s) are directly connected to the MikroTik, i.e., the L1 (1-hop) neighbors. Is there a way to achieve so? In other words, I would like to find out the real cables.
Thank you very much for all your help.
Regards
