CISPA LAB third finding.
If you are receiving a lot of interferance from other Access Points on the air, or Hackers attempting to break into your system; Your CPU Load will go up greatly. This happens because the MT software must handle all of these packets and decide what to do.
If the CPU reaches 95% + you will have troubles; lockups; link drops; reboot; etc.
A Case in Point: We tested a system a the Los Angeles Air Portās USO for 90 days. There were over 64 Access Points running in the area, and we had over 8000 hacker attempts on the system. We used a RB-220 with Level 5 software and natted the RF. Our tracking showed that as the number of false packets increased, so did the CPU Level untill the board dropped all of the users. A few minutes latter, it came back on line. This happened over and over.
One time during the testing, the CPU load HIT 99% and the unit shutdown and rebooted.
One further item, we also found that some Ethernet NICās will stop functing if the collisions on the ethernet go crazy. IE the SLAMMER WORM running on an SQL server does it every time when using DLINKās Ethernet Boards!!!
