Hi there,
I have used the instructions found on this link : http://gregsowell.com/?p=894 in order to block part of the p2p traffic.
So far its working ok, I can’t bring up any search for torrent files/sites and pretty happy with it.
Now I was wondering, how to add exceptions to this rules? What I mean is: I have 3 users which are currently bind to bypass the hotspot which are using static ip lock to Mac address. I want this 3 users/IP/MAC to be able to bypass the above rules I created, is there an easy way for this ? or should I just assign lets say:
192.168.88.251/252/253 to them and run the firewall block between 192.168.88.0-250 leaving the last 4 addresses reserved ?
Thanks for that.
A
