firewall filter rule for text string
I want to block DNS requests for “isc.org” domain, which are being abused for a DDoS attack. I’ve created a filter rule:
add action=drop chain=forward content=“isc\03org” disabled=no dst-port=
53 protocol=udp
But it does not work. If I create a similar rule without the \03org, it efectively blocks anything in the form “isc”.
What is the sintaxt for the text matching in filter rules? Does it accept wildcards/regex in any way? DNS queries separate domain segments with ETX (0x03)
In the wiki I can only find:
http://wiki.mikrotik.com/wiki/Manual:IP/Firewall/Filter
content (string; Default: ) Match packets that contain specified text
Regards
A smart guy here at the office did a fuzzy and dirty trick that just works:
echo -e ‘\003’ > tmpfile
he the did cut&paste from that file to the web browser (opera).
The filter rule now shows:
0 chain=forward action=drop protocol=udp dst-port=53 content=\03isc\03org
where the “\03” show in blue (if I enter it manually from ssh console or other browser, it shows in regular grey).
While this solves our problem now, I would rather know how to enter this kind of characters in a filter rule in a cleaner way.
Regards
You should assign the rule to your input chain, not on the forward chain
try ‘export’ instead of ‘print’ command
UPD:
/ip firewall mangle set 8 content="isc\03org"
works fine for me, “\03” is in blue when doing ‘print’
