i have mikrotik 3.13 i work as pptp i need to open only 2 port 1 for 80 and another for vpn and drop all another port and drop all comin from internet traffic only open port 1010 for 192.168.100.151 and i tray alot of firwall rull like:
47 X chain=input action=accept src-port=80 protocol=tcp
48 X chain=output action=accept dst-port=80 protocol=tcp
49 X ;;; dns
chain=output action=accept dst-port=53 protocol=udp dst-limit=3048,5,dst-address/1m40s
50 X chain=output action=accept src-port=8080 protocol=tcp
51 X ;;; http
chain=output action=accept dst-port=8080 protocol=tcp
52 X ;;; Allow-limited-icmp
chain=output action=accept protocol=icmp limit=50/5s,2
53 X chain=output action=accept protocol=gre
54 X chain=output action=accept src-port=1723 protocol=tcp
55 X chain=output action=accept dst-port=1723 protocol=tcp
56 X ;;; accept new connections
chain=output action=accept protocol=tcp
57 X ;;; Drop-evry-theenggg
chain=output action=drop
and when i tray to open msn messsnager its work yahoo messanger i ts work
this is my config
[admin@EnG:MoHaMeD] /ip firewall nat> print
2 chain=srcnat action=masquerade
3 chain=dstnat action=redirect to-ports=8080 dst-port=80 protocol=tcp
[admin@EnG:MoHaMeD] /ip address> print
ADDRESS NETWORK BROADCAST INTERFACE
0 ;;; Lan
10.0.0.3/24 10.0.0.4 10.0.0.255 Lan
1 ;;; Wan
91.11.16.88/24 91.11.16.88 91.11.16.88 Wan
2 ;;; Server-Lan
192.168.100.3/24 192.168.100.2 192.168.100.250 Lan
3 D 192.168.100.3/32 192.168.1.229 0.0.0.0
[admin@EnG:MoHaMeD] /ip route> print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
DST-ADDRESS PREF-SRC GATEWAY-STATE GATEWAY DISTANCE INTERFACE
0 A S 0.0.0.0/0 reachable 91.11.16.3 1 Wan
1 ADC 10.0.0.0/24 10.0.0.3 0 Lan
2 ADC 91.11.16.0/24 91.11.16.88 0 Wan
3 A S 192.0.0.0/8 reachable 192.168.100.3 1 Lan
4 A S 192.168.0.0/16 reachable 192.168.100.1 1 Lan
5 ADC 192.168.1.229/32 192.168.100.3 0
6 ADC 192.168.100.0/24 192.168.100.3 0 Lan
/ip proxy> print
enabled: yes
src-address: 0.0.0.0
port: 8080
parent-proxy: 0.0.0.0
parent-proxy-port: 0
cache-drive: system
cache-administrator: "admin"
max-cache-size: 20000KiB
cache-on-disk: yes
max-client-connections: 600
max-server-connections: 600
max-fresh-time: 2d
serialize-connections: no
always-from-cache: yes
cache-hit-dscp: 12
Thanks for help me
