Hello everyone,
I have been practicing and experimenting with some firewall rules lately and I come across some of these rules that baffles me. This firewall rules were copied from Mikrotik website. for example, when the RAW rules below is applied, something strange happens. In this testing, I have only one computer connected to the router. The router has 192.168.88.1 and the PC connected to it has an IP: 192.168.88.2. I noticed that only the JUMP “jump-target=bad_tcp” [shown in BOLD] counter continues increasing at a high rate but the actual rule “bad_tcp” [in GREEN] did not increase. I have attached the logs and RAW pic to this post.
My question is: Why is the JUMP counter increasing instead of the actual rules that the traffic was suppose to match against? I thought the JUMP is just instructing the firewall process to JUMP into the “bad_tcp” chain, then match the packet against the “bad_tcp” rules, then return. I’m confused.
/ip firewall raw
add action=accept chain=prerouting comment=“defconf: enable for transparent firewall” disabled=yes
add action=accept chain=prerouting comment=“defconf: accept DHCP discover” dst-address=255.255.255.255 dst-port=67 in-interface-list=LAN protocol=udp src-address=0.0.0.0 src-port=68
add action=drop chain=prerouting comment=“defconf: drop bogon IP’s” src-address-list=bad_ipv4
add action=drop chain=prerouting comment=“defconf: drop bogon IP’s” dst-address-list=bad_ipv4
add action=drop chain=prerouting comment=“defconf: drop bogon IP’s” src-address-list=bad_src_ipv4
add action=drop chain=prerouting comment=“defconf: drop bogon IP’s” dst-address-list=bad_dst_ipv4
add action=drop chain=prerouting comment=“defconf: drop non global from WAN” src-address-list=not_global_ipv4 in-interface-list=WAN
add action=drop chain=prerouting comment=“defconf: drop forward to local lan from WAN” in-interface-list=WAN dst-address=192.168.88.0/24
add action=drop chain=prerouting comment=“defconf: drop local if not from default IP range” in-interface-list=LAN src-address=!192.168.88.0/24
add action=drop chain=prerouting comment=“defconf: drop bad UDP” port=0 protocol=udp
add action=jump chain=prerouting comment=“defconf: jump to ICMP chain” jump-target=icmp4 protocol=icmp
add action=jump chain=prerouting comment=“defconf: jump to TCP chain” jump-target=bad_tcp protocol=tcp
add action=accept chain=prerouting comment=“defconf: accept everything else from LAN” in-interface-list=LAN
add action=accept chain=prerouting comment=“defconf: accept everything else from WAN” in-interface-list=WAN
add action=drop chain=prerouting comment=“defconf: drop the rest”
/ip firewall raw
add action=drop chain=bad_tcp comment=“defconf: TCP flag filter” protocol=tcp tcp-flags=!fin,!syn,!rst,!ack
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=fin,syn
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=fin,rst
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=fin,!ack
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=fin,urg
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=syn,rst
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=rst,urg
add action=drop chain=bad_tcp comment=“defconf: TCP port 0 drop” port=0 protocol=tcp
