Hi everybody!
I have 1 WAN connection and 2 wireguard connections to mullvad VPN.
As the mullvad IP is the same for both connections, I’ve put the interfaces into their own VRFs.
Vlan VLAN1 should use the VPN1 connection, VLAN2 should use the VPN2 connection.
I have created a script, which sets everything up:
https://gitlab.com/close2/routeros-configuration (router_all.rsc with an example configuration at router-example-configuration.txt)
The relevant commands are:
/interface/wireguard/add private-key=$privateKey1 name=VPN1
/interface/wireguard/peers/add allowed-address=0.0.0.0/0,::/0 endpoint-address=$endpointAddress1 endpoint-port=$endpointPort1 interface=VPN1 public-key=$publicKey1 persistent-keepalive=25s
/ip/address/add address=$address1 interface=VPN1
/ipv6/address/add address=$addressIpv61 interface=VPN1
/ip/vrf/add interfaces=VPN1 name=VPN1_VRF
# An interface list where I add all vlans, which should use the VPN1
/interface/list/add name=USE_VPN1_LIST
# Create an additional routing table (not in the VRF!)
/routing/table/add fib name=VPN1_RT
/ip/route/add dst-address=0.0.0.0/0 gateway=VPN1@VPN1_VRF routing-table=VPN1_RT
# Not sure if the following line is necessary, but lets add the default route in the VRF as well:
/ip/route/add dst-address=0.0.0.0/0 gateway=VPN1@VPN1_VRF routing-table=VPN1_VRF
# For every VLAN which is added to the USE_VPN1_LIST we will also add routes into the routing tables:
/interface/list/member/add interface=VLAN1 list=USE_VPN1_LIST
/ip/route/add dst-address=10.0.1.0/24 gateway=%VLAN1 routing-table=VPN1_RT
/ip/route/add dst-address=10.0.1.0/24 gateway=VLAN1@main routing-table=VPN1_VRF
# Make sure that the VLAN1 interface only sees the VPN1 as default route by giving it the VPN1_RT as the routing table:
/routing/rule/add interface=VLAN1 action=lookup-only-in-table table=VPN1_RT
# Note that VLAN1 can also access VLAN3. Add a route for VLAN3 to VPN1_RT (but not VPN1_VRF):
/ip/route/add dst-address=10.0.3.0/24 gateway=%VLAN3 routing-table=VPN1_RT
# Enable NAT on the VPN interface
/ip/firewall/nat/add chain=srcnat out-interface=VPN1 ipsec-policy=out,none action=masquerade comment="masquerade vpn"
# Add allow route into the firewall:
/ip/firewall/filter/add chain=forward action=accept in-interface-list=USE_VPN1_LIST out-interface=VPN1_VRF comment="accept forwarding vpn-VLANs"
# Same for VPN2
Everything seems to work, except for the firewall rule.
It doesn’t trigger.
As shown in router_all.rsc my last firewall rule is:
/ip/firewall/filter/add chain=forward action=drop comment="drop everything else"
If I replace it with:
/ip/firewall/filter/add chain=forward action=accept comment="accept everything JUST FOR TESTING"
devices in my VLAN1 start to use the VPN tunnel.
What is the correct firewall rule?
I am using 7.17 on a hAP ax².
thanks
Christian
