Firewall rules analysis
Hoping to get a firewalls rules analysis on a newly set up ax3.
This device will be connected to cable internet, have wireguard connections, and a super-special non-vlan secure guest wifi config (so stations connected to guestwifi can get DHCP from ax3, but otherwise have no access to the ax3 or LAN or wireguard routes).
Do these make sense? Is the order smart?
Thank you.
/ip firewall address-list add address=<LOCATION-1>.dyndns.org disabled=no dynamic=no list=<LOCATION-1>
/ip firewall address-list add address=<LOCATION-2>.dyndns.org disabled=no dynamic=no list=<LOCATION-2>
/ip firewall address-list add address=IP-local-admin-destkop disabled=no dynamic=no list=authorized
/ip firewall address-list add address=IP-local-admin-laptop disabled=no dynamic=no list=authorized
/ip firewall address-list add address=<THIS-LOCATION>.dyndns.org disabled=no dynamic=no list=dynamic-WANIP
/ip firewall address-list add address=192.168.0.0/16 disabled=no dynamic=no list=admin
/ip firewall address-list add address=10.10.100.0/24 disabled=no dynamic=no list=admin
/ip firewall address-list add address=10.0.0.2-10.0.0.254 disabled=no dynamic=no list="Guest WiFi"
/ip firewall connection tracking set enabled=auto generic-timeout=10m icmp-timeout=10s loose-tcp-tracking=yes tcp-close-timeout=10s tcp-close-wait-timeout=10s tcp-established-timeout=1d tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s tcp-max-retrans-timeout=5m tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-time-wait-timeout=10s tcp-unacked-timeout=5m udp-stream-timeout=3m udp-timeout=10s
/ip firewall filter add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
/ip firewall filter add action=drop chain=input comment="defconf: drop invalid" connection-state=invalid
/ip firewall filter add action=accept chain=input comment="defconf: accept ICMP" protocol=icmp
/ip firewall filter add action=accept chain=input comment="Allow WG Handshake" !connection-bytes !connection-limit !connection-mark !connection-nat-state !connection-rate !connection-state !connection-type !content disabled=no !dscp dst-address=0.0.0.0 !dst-address-list !dst-address-type !dst-limit dst-port=51880 !fragment !hotspot !icmp-options !in-bridge-port !in-bridge-port-list !in-interface !in-interface-list !ingress-priority !ipsec-policy !ipv4-options !layer7-protocol !limit log=no log-prefix="" !nth !out-bridge-port !out-bridge-port-list !out-interface !out-interface-list !packet-mark !packet-size !per-connection-classifier !port !priority protocol=udp !psd !random !routing-mark !src-address !src-address-list !src-address-type !src-mac-address !src-port !tcp-flags !tcp-mss !time !tls-host !ttl
/ip firewall filter add action=accept chain=input comment="allow 67 68 to 10.0.0.1" dst-address=10.0.0.1 dst-port=67,68 log=yes log-prefix="allow 67 68 to 10.0.0.1" protocol=udp
/ip firewall filter add action=drop chain=input comment="drop all to 10.0.0.1" dst-address=10.0.0.1 in-interface=!lo log=yes log-prefix="drop all to 10.0.0.1"
/ip firewall filter add action=accept chain=input comment="Allow GRE for EoIP" protocol=gre
/ip firewall filter add action=accept chain=input comment="Alow wireguard to router" in-interface=wireguard1
/ip firewall filter add action=accept chain=input comment="Allow all from LAN ifaces (bridge)" !connection-bytes !connection-limit !connection-mark !connection-nat-state !connection-rate !connection-state !connection-type !content disabled=no !dscp !dst-address !dst-address-list !dst-address-type !dst-limit !dst-port !fragment !hotspot !icmp-options !in-bridge-port !in-bridge-port-list !in-interface in-interface-list=LAN !ingress-priority !ipsec-policy !ipv4-options !layer7-protocol !limit log=no log-prefix="" !nth !out-bridge-port !out-bridge-port-list !out-interface !out-interface-list !packet-mark !packet-size !per-connection-classifier !port !priority !protocol !psd !random !routing-mark !src-address !src-address-list !src-address-type !src-mac-address !src-port !tcp-flags !tcp-mss !time !tls-host !ttl
/ip firewall filter add action=accept chain=input !connection-bytes !connection-limit !connection-mark !connection-nat-state !connection-rate !connection-state !connection-type !content disabled=no !dscp !dst-address !dst-address-list !dst-address-type !dst-limit !dst-port !fragment !hotspot !icmp-options !in-bridge-port !in-bridge-port-list !in-interface !in-interface-list !ingress-priority !ipsec-policy !ipv4-options !layer7-protocol !limit log=no log-prefix="" !nth !out-bridge-port !out-bridge-port-list !out-interface !out-interface-list !packet-mark !packet-size !per-connection-classifier !port !priority !protocol !psd !random !routing-mark !src-address src-address-list=admin !src-address-type !src-mac-address !src-port !tcp-flags !tcp-mss !time !tls-host !ttl
/ip firewall filter add action=accept chain=input src-address-list=<LOCATION-1>
/ip firewall filter add action=accept chain=input src-address-list=<LOCATION-2>
/ip firewall filter add action=drop chain=input comment="defconf: drop all not coming from LAN" in-interface-list=!LAN
/ip firewall filter add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
/ip firewall filter add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=established,related,untracked
/ip firewall filter add action=drop chain=forward comment="drop all 10.0.0.0/24 to not-WAN" log-prefix=drop-all-10-0-0-0-24-to-not-WAN out-interface-list=!WAN src-address=10.0.0.0/24
/ip firewall filter add action=drop chain=forward comment="drop guest to 192.168.0.0/16" dst-address=192.168.0.0/16 dst-port=!53,68,68 log=yes log-prefix=drop-guest-to-192-168-0-0-16 protocol=udp src-address-list="Guest WiFi"
/ip firewall filter add action=accept chain=forward comment="allow port forwarding" connection-nat-state=dstnat
/ip firewall filter add action=accept chain=forward comment="Allow wireguard to subnet" in-interface=wireguard1
/ip firewall filter add action=accept chain=forward comment="Allow subnet to enter WG" out-interface=wireguard1
/ip firewall filter add action=drop chain=forward comment="defconf: drop invalid" connection-state=invalid
/ip firewall filter add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip firewall nat add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none out-interface-list=WAN !to-addresses !to-ports
Anyone care to take a look at this?
Wait for your neighbour from the new state (@anav) to wake up … he’s training to become retired person and those need to have long morning naps :laughing:
LOL!
Justin better hurry or Greenland, Gaza, or Mexico might take the #51 position.
(Too soon?)
GAZA —. trillion cubic tons of natural gas offshore, or something like that is the driving factor, not the riviera golf course :stuck_out_tongue_winking_eye:
As the OP knows full well I dont look at snippets, its much more fun to trash an entire config!!
Trash away…
# 2025-02-10 11:21:01 by RouterOS 7.17.2
# software id = ILCG-6S0L
# model = C53UiG+5HPaxD2HPaxD
# serial number = HGJ0
/interface bridge add admin-mac=D4:01:C3:C0:82:CF ageing-time=5m arp=enabled arp-timeout=auto auto-mac=no comment=defconf dhcp-snooping=no disabled=no fast-forward=yes forward-delay=15s igmp-snooping=no max-learned-entries=auto max-message-age=20s mtu=auto mvrp=no name=bridge port-cost-mode=short priority=0x8000 protocol-mode=rstp transmit-hold-count=6 vlan-filtering=no
/interface ethernet set [ find default-name=ether1 ] advertise=10M-baseT-half,10M-baseT-full,100M-baseT-half,100M-baseT-full,1G-baseT-half,1G-baseT-full,2.5G-baseT arp=enabled arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no l2mtu=1568 loop-protect=default loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=D4:01:C3:C0:82:CE mtu=1500 name=ether1 orig-mac-address=D4:01:C3:C0:82:CE poe-out=off poe-priority=10 power-cycle-interval=none !power-cycle-ping-address power-cycle-ping-enabled=no !power-cycle-ping-timeout rx-flow-control=off tx-flow-control=off
/interface ethernet set [ find default-name=ether2 ] advertise=10M-baseT-half,10M-baseT-full,100M-baseT-half,100M-baseT-full,1G-baseT-half,1G-baseT-full arp=enabled arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no l2mtu=1568 loop-protect=default loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=D4:01:C3:C0:82:CF mtu=1500 name=ether2 orig-mac-address=D4:01:C3:C0:82:CF rx-flow-control=off tx-flow-control=off
/interface ethernet set [ find default-name=ether3 ] advertise=10M-baseT-half,10M-baseT-full,100M-baseT-half,100M-baseT-full,1G-baseT-half,1G-baseT-full arp=enabled arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no l2mtu=1568 loop-protect=default loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=D4:01:C3:C0:82:D0 mtu=1500 name=ether3 orig-mac-address=D4:01:C3:C0:82:D0 rx-flow-control=off tx-flow-control=off
/interface ethernet set [ find default-name=ether4 ] advertise=10M-baseT-half,10M-baseT-full,100M-baseT-half,100M-baseT-full,1G-baseT-half,1G-baseT-full arp=enabled arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no l2mtu=1568 loop-protect=default loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=D4:01:C3:C0:82:D1 mtu=1500 name=ether4 orig-mac-address=D4:01:C3:C0:82:D1 rx-flow-control=off tx-flow-control=off
/interface ethernet set [ find default-name=ether5 ] advertise=10M-baseT-half,10M-baseT-full,100M-baseT-half,100M-baseT-full,1G-baseT-half,1G-baseT-full arp=enabled arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no l2mtu=1568 loop-protect=default loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=D4:01:C3:C0:82:D2 mtu=1500 name=ether5 orig-mac-address=D4:01:C3:C0:82:D2 rx-flow-control=off tx-flow-control=off
/interface wifi set [ find default-name=wifi1 ] arp-timeout=auto channel.band=5ghz-ax .skip-dfs-channels=disabled .width=20/40/80mhz configuration.country="United States" .mode=ap .ssid=729-5ghz disabled=no l2mtu=1560 mac-address=D4:01:C3:C0:82:D3 name=wifi1 radio-mac=D4:01:C3:C0:82:D3 security.authentication-types=wpa2-psk .disable-pmkid=yes .management-protection=disabled .passphrase=blueberry1 steering.rrm=no .wnm=no
/interface wifi set [ find default-name=wifi2 ] arp-timeout=auto channel.band=2ghz-ax .skip-dfs-channels=disabled .width=20mhz configuration.country="United States" .mode=ap .ssid=729-2ghz disabled=no l2mtu=1560 mac-address=D4:01:C3:C0:82:D4 name=wifi2 radio-mac=D4:01:C3:C0:82:D4 security.authentication-types=wpa2-psk .disable-pmkid=yes .management-protection=disabled .passphrase=blueberry1
/queue interface set bridge queue=no-queue
/interface wireguard add disabled=no listen-port=51880 mtu=1420 name=wireguard1 private-key=XXXXXUdzhtaQWe9tDnPmv94g/QtGM=
/interface wifi add arp-timeout=auto configuration.country="United States" .mode=ap .ssid=2point4 datapath.client-isolation=yes disabled=no l2mtu=1560 mac-address=D6:01:C3:C0:82:D3 master-interface=wifi2 name=2point4 security.authentication-types=wpa2-psk .disable-pmkid=yes .management-protection=disabled .passphrase=XXXXX
/interface wifi add arp-timeout=auto configuration.mode=ap .ssid=Guest disabled=yes l2mtu=1560 mac-address=D6:01:C3:C0:82:D6 master-interface=wifi1 name=Guest-wifi1 security.authentication-types=wpa2-psk .passphrase=XXXXX
/interface wifi add arp-timeout=auto configuration.mode=ap .ssid=Guest disabled=yes l2mtu=1560 mac-address=D6:01:C3:C0:82:D7 master-interface=wifi2 name=Guest-wifi2 security.authentication-types=wpa2-psk .passphrase=XXXXX
/queue interface set wireguard1 queue=no-queue
/interface ethernet switch set 0 !cpu-flow-control mirror-source=none mirror-target=none name=switch1
/interface ethernet switch port set 0 default-vlan-id=0
/interface ethernet switch port set 1 default-vlan-id=0
/interface ethernet switch port set 2 default-vlan-id=0
/interface ethernet switch port set 3 default-vlan-id=0
/interface ethernet switch port set 4 default-vlan-id=0
/interface ethernet switch port set 5 default-vlan-id=0
/interface ethernet switch port-isolation set 0 !forwarding-override
/interface ethernet switch port-isolation set 1 !forwarding-override
/interface ethernet switch port-isolation set 2 !forwarding-override
/interface ethernet switch port-isolation set 3 !forwarding-override
/interface ethernet switch port-isolation set 4 !forwarding-override
/interface ethernet switch port-isolation set 5 !forwarding-override
/interface list set [ find name=all ] comment="contains all interfaces" exclude="" include="" name=all
/interface list set [ find name=none ] comment="contains no interfaces" exclude="" include="" name=none
/interface list set [ find name=dynamic ] comment="contains dynamic interfaces" exclude="" include="" name=dynamic
/interface list set [ find name=static ] comment="contains static interfaces" exclude="" include="" name=static
/interface list add comment=defconf exclude="" include="" name=WAN
/interface list add comment=defconf exclude="" include="" name=LAN
/interface list add exclude="" include=LAN,WAN name=ALL
/interface list add exclude="" include="" name=TRUSTED
/interface list add exclude="" include="" name=DHCPdisabled
/interface lte apn set [ find default=yes ] add-default-route=yes apn=internet authentication=none default-route-distance=2 ip-type=auto name=default use-network-apn=yes use-peer-dns=yes
/interface macsec profile set [ find default-name=default ] name=default server-priority=10
/interface wifi configuration add datapath.client-isolation=yes disabled=no name=guestcfg security.authentication-types=wpa2-psk .passphrase=blueberry ssid=GuestWifi
/interface wifi add arp-timeout=auto configuration=guestcfg configuration.mode=ap disabled=no l2mtu=1560 mac-address=D6:01:C3:C0:82:D4 master-interface=wifi2 name=Guest2g security.authentication-types=wpa2-psk
/interface wifi add arp-timeout=auto configuration=guestcfg configuration.mode=ap disabled=no l2mtu=1560 mac-address=D6:01:C3:C0:82:D5 master-interface=wifi1 name=Guest5g
/ip dhcp-client option set clientid_duid code=61 name=clientid_duid value="0xff\$(CLIENT_DUID)"
/ip dhcp-client option set clientid code=61 name=clientid value="0x01\$(CLIENT_MAC)"
/ip dhcp-client option set hostname code=12 name=hostname value="\$(HOSTNAME)"
/ip hotspot profile set [ find default=yes ] dns-name="" hotspot-address=0.0.0.0 html-directory=hotspot html-directory-override="" http-cookie-lifetime=3d http-proxy=0.0.0.0:0 install-hotspot-queue=no login-by=cookie,http-chap name=default smtp-server=0.0.0.0 split-user-domain=no use-radius=no
/ip hotspot user profile set [ find default=yes ] add-mac-cookie=yes address-list="" idle-timeout=none !insert-queue-before keepalive-timeout=2m mac-cookie-timeout=3d name=default !parent-queue !queue-type shared-users=1 status-autorefresh=1m transparent-proxy=no
/ip ipsec mode-config set [ find default=yes ] name=request-only responder=no use-responder-dns=exclusively
/ip ipsec policy group set [ find default=yes ] name=default
/ip ipsec profile set [ find default=yes ] dh-group=modp2048,modp1024 dpd-interval=2m dpd-maximum-failures=5 enc-algorithm=aes-128,3des hash-algorithm=sha1 lifetime=1d name=default nat-traversal=yes proposal-check=obey
/ip ipsec proposal set [ find default=yes ] auth-algorithms=sha1 disabled=no enc-algorithms=aes-256-cbc,aes-192-cbc,aes-128-cbc lifetime=30m name=default pfs-group=modp1024
/ip kid-control add disabled=no fri=0s-1d mon=0s-1d name=Monitor rate-limit="" sat=0s-1d sun=0s-1d thu=0s-1d tue=0s-1d tur-fri="" tur-mon="" tur-sat="" tur-sun="" tur-thu="" tur-tue="" tur-wed="" wed=0s-1d
/ip pool add name=default-dhcp ranges=192.168.80.100-192.168.80.200
/ip pool add name=pool-guest ranges=10.0.0.10-10.0.0.252
# Interface not running
add address-lists="" address-pool=pool-guest disabled=no interface=Guest2g lease-script="" lease-time=6h name=dhcp-guest2g use-radius=no
add address-lists="" address-pool=pool-guest disabled=no interface=Guest5g lease-script="" lease-time=6h name=dhcp-guest5g use-radius=no
/ip dhcp-server add address-lists="" address-pool=default-dhcp disabled=no interface=bridge lease-script="\r\
    \n\r\
    \n/system\r\
    \n:local cdate [clock get date] \r\
    \n:local yyyy  [:pick \$cdate 0  4]\r\
    \n:local MM    [:pick \$cdate 5  7]\r\
    \n:local dd    [:pick \$cdate 8 10]\r\
    \n\r\
    \n:local thistime [/system clock get time]\r\
    \n:local thishour [:pick \$thistime 0 2]\r\
    \n:local thisminute [:pick \$thistime 3 5]\r\
    \n:local thissecond [:pick \$thistime 6 8]\r\
    \n:local identitydatetime \"\$[identity get name]_\$yyyy-\$MM-\$dd_\$thishour:\$thisminute:\$thissecond\"\r\
    \n:local datetime \"\$yyyy-\$MM-\$dd_\$thishour:\$thisminute:\$thissecond\"\r\
    \n:local systemname \"\$[identity get name]\"\r\
    \n\r\
    \n:if (\$leaseBound=1) do={\r\
    \n\r\
    \n#  :log info \"testing after condition BOUND\" }\r\
    \n\r\
    \n}\r\
    \n\r\
    \n:if  ([/ip dhcp-server lease find where dynamic mac-address=\$leaseActMAC]!=\"\") do={\r\
    \n\r\
    \n#  :log info \"testing after condition DYNAMIC\"}\r\
    \n\r\
    \n}\r\
    \n\r\
    \n:local recipient \"jXXXXX@domain.com\"\r\
    \n\r\
    \n:if  ((\$leaseBound=1)  && ([/ip dhcp-server lease find where dynamic mac-address=\$leaseActMAC]!=\"\")) do={\r\
    \n\r\
    \n    :log info \"testing after conditions BOUND and DYNAMIC\" \r\
    \n\r\
    \n    :tool e-mail send to=\$recipient subject=\"\$systemname DHCP Lease Assigned to \$leaseActMAC\" body=\"MAC address \$leaseActMAC received IP address \$leaseActIP with a hostname of \$[/ip/dhcp-server/lease/get value-name=host-name [find where mac-address=\$leaseActMAC]] from DHCP Server \$leaseServerName on \$datetime from \$systemname\"\r\
    \n\r\
    \n    :log info \"Sent DHCP alert for MAC \$leaseActMAC\"\r\
    \n\r\
    \n}\r\
    \n\r\
    \n" lease-time=2d name=defconf use-radius=no
/ip smb users set [ find default=yes ] disabled=no name=guest password="" read-only=yes
/ppp profile set *0 address-list="" !bridge !bridge-horizon bridge-learning=default !bridge-path-cost !bridge-port-priority !bridge-port-trusted !bridge-port-vid change-tcp-mss=yes !dns-server !idle-timeout !incoming-filter !insert-queue-before !interface-list !local-address name=default on-down="" on-up="" only-one=default !outgoing-filter !parent-queue !queue-type !rate-limit !remote-address !session-timeout use-compression=default use-encryption=default use-ipv6=yes use-mpls=default use-upnp=default !wins-server
/ppp profile set *FFFFFFFE address-list="" !bridge !bridge-horizon bridge-learning=default !bridge-path-cost !bridge-port-priority !bridge-port-trusted !bridge-port-vid change-tcp-mss=yes !dns-server !idle-timeout !incoming-filter !insert-queue-before !interface-list !local-address name=default-encryption on-down="" on-up="" only-one=default !outgoing-filter !parent-queue !queue-type !rate-limit !remote-address !session-timeout use-compression=default use-encryption=yes use-ipv6=yes use-mpls=default use-upnp=default !wins-server
/queue type set 0 kind=pfifo name=default pfifo-limit=50
/queue type set 1 kind=pfifo name=ethernet-default pfifo-limit=50
/queue type set 2 kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5
/queue type set 3 kind=red name=synchronous-default red-avg-packet=1000 red-burst=20 red-limit=60 red-max-threshold=50 red-min-threshold=10
/queue type set 4 kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
/queue type set 5 kind=pcq name=pcq-upload-default pcq-burst-rate=0 pcq-burst-threshold=0 pcq-burst-time=10s pcq-classifier=src-address pcq-dst-address-mask=32 pcq-dst-address6-mask=128 pcq-limit=50KiB pcq-rate=0 pcq-src-address-mask=32 pcq-src-address6-mask=128 pcq-total-limit=2000KiB
/queue type set 6 kind=pcq name=pcq-download-default pcq-burst-rate=0 pcq-burst-threshold=0 pcq-burst-time=10s pcq-classifier=dst-address pcq-dst-address-mask=32 pcq-dst-address6-mask=128 pcq-limit=50KiB pcq-rate=0 pcq-src-address-mask=32 pcq-src-address6-mask=128 pcq-total-limit=2000KiB
/queue type set 7 kind=none name=only-hardware-queue
/queue type set 8 kind=mq-pfifo mq-pfifo-limit=50 name=multi-queue-ethernet-default
/queue type set 9 kind=pfifo name=default-small pfifo-limit=10
/queue interface set ether1 queue=only-hardware-queue
/queue interface set ether2 queue=only-hardware-queue
/queue interface set ether3 queue=only-hardware-queue
/queue interface set ether4 queue=only-hardware-queue
/queue interface set ether5 queue=only-hardware-queue
/queue interface set "2point4" queue=wireless-default
/queue interface set Guest-wifi1 queue=wireless-default
/queue interface set Guest-wifi2 queue=wireless-default
/queue interface set Guest2g queue=wireless-default
/queue interface set Guest5g queue=wireless-default
/queue interface set wifi1 queue=wireless-default
/queue interface set wifi2 queue=wireless-default
/routing bgp template set default as=65530 name=default
/snmp community set [ find default=yes ] addresses=::/0 authentication-password="" authentication-protocol=MD5 disabled=no encryption-password="" encryption-protocol=DES name=public read-access=yes security=none write-access=no
/system logging action set 0 memory-lines=1000 memory-stop-on-full=no name=memory target=memory
/system logging action set 1 disk-file-count=2 disk-file-name=log disk-lines-per-file=1000 disk-stop-on-full=no name=disk target=disk
/system logging action set 2 name=echo remember=yes target=echo
/system logging action set 3 bsd-syslog=no name=remote remote=192.168.0.13 remote-port=514 src-address=0.0.0.0 syslog-facility=daemon syslog-severity=auto syslog-time-format=bsd-syslog target=remote
/system logging action add bsd-syslog=no name=logserver remote=192.168.0.112 remote-port=51400 src-address=0.0.0.0 syslog-facility=daemon syslog-severity=auto syslog-time-format=bsd-syslog target=remote
/user group set read name=read policy=local,telnet,ssh,reboot,read,test,winbox,password,web,sniff,sensitive,api,romon,rest-api,!ftp,!write,!policy skin=default
/user group set write name=write policy=local,telnet,ssh,reboot,read,write,test,winbox,password,web,sniff,sensitive,api,romon,rest-api,!ftp,!policy skin=default
/user group set full name=full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api,romon,rest-api skin=default
/certificate settings set crl-download=no crl-store=ram crl-use=no
/console settings set sanitize-names=no
/disk settings set auto-media-interface=none auto-media-sharing=no auto-smb-sharing=no auto-smb-user=guest default-mount-point-template="[slot]"
/ip smb set comment=MikrotikSMB domain=MSHOME enabled=auto interfaces=all
/interface bridge port add auto-isolate=no bpdu-guard=no bridge=bridge broadcast-flood=yes comment=defconf disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none hw=yes ingress-filtering=yes interface=ether2 internal-path-cost=10 learn=auto multicast-router=temporary-query mvrp-applicant-state=normal-participant mvrp-registrar-state=normal path-cost=10 point-to-point=auto priority=0x80 pvid=1 restricted-role=no restricted-tcn=no tag-stacking=no trusted=no unknown-multicast-flood=yes unknown-unicast-flood=yes
/interface bridge port add auto-isolate=no bpdu-guard=no bridge=bridge broadcast-flood=yes comment=defconf disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none hw=yes ingress-filtering=yes interface=ether3 internal-path-cost=10 learn=auto multicast-router=temporary-query mvrp-applicant-state=normal-participant mvrp-registrar-state=normal path-cost=10 point-to-point=auto priority=0x80 pvid=1 restricted-role=no restricted-tcn=no tag-stacking=no trusted=no unknown-multicast-flood=yes unknown-unicast-flood=yes
/interface bridge port add auto-isolate=no bpdu-guard=no bridge=bridge broadcast-flood=yes comment=defconf disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none hw=yes ingress-filtering=yes interface=ether4 internal-path-cost=10 learn=auto multicast-router=temporary-query mvrp-applicant-state=normal-participant mvrp-registrar-state=normal path-cost=10 point-to-point=auto priority=0x80 pvid=1 restricted-role=no restricted-tcn=no tag-stacking=no trusted=no unknown-multicast-flood=yes unknown-unicast-flood=yes
/interface bridge port add auto-isolate=no bpdu-guard=no bridge=bridge broadcast-flood=yes comment=defconf disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none hw=yes ingress-filtering=yes interface=ether5 internal-path-cost=10 learn=auto multicast-router=temporary-query mvrp-applicant-state=normal-participant mvrp-registrar-state=normal path-cost=10 point-to-point=auto priority=0x80 pvid=1 restricted-role=no restricted-tcn=no tag-stacking=no trusted=no unknown-multicast-flood=yes unknown-unicast-flood=yes
/interface bridge port add auto-isolate=no bpdu-guard=no bridge=bridge broadcast-flood=yes comment=defconf disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none ingress-filtering=yes interface=wifi1 internal-path-cost=10 learn=auto multicast-router=temporary-query mvrp-applicant-state=normal-participant mvrp-registrar-state=normal path-cost=10 point-to-point=auto priority=0x80 pvid=1 restricted-role=no restricted-tcn=no tag-stacking=no trusted=no unknown-multicast-flood=yes unknown-unicast-flood=yes
/interface bridge port add auto-isolate=no bpdu-guard=no bridge=bridge broadcast-flood=yes disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none ingress-filtering=yes interface=*B internal-path-cost=10 learn=auto multicast-router=temporary-query mvrp-applicant-state=normal-participant mvrp-registrar-state=normal path-cost=10 point-to-point=auto priority=0x80 pvid=1 restricted-role=no restricted-tcn=no tag-stacking=no trusted=no unknown-multicast-flood=yes unknown-unicast-flood=yes
/interface bridge port add auto-isolate=no bpdu-guard=no bridge=bridge broadcast-flood=yes disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none ingress-filtering=yes interface=2point4 internal-path-cost=10 learn=auto multicast-router=temporary-query mvrp-applicant-state=normal-participant mvrp-registrar-state=normal path-cost=10 point-to-point=auto priority=0x80 pvid=1 restricted-role=no restricted-tcn=no tag-stacking=no trusted=no unknown-multicast-flood=yes unknown-unicast-flood=yes
/interface bridge port add auto-isolate=no bpdu-guard=no bridge=bridge broadcast-flood=yes disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none ingress-filtering=yes interface=wifi2 internal-path-cost=10 learn=auto multicast-router=temporary-query mvrp-applicant-state=normal-participant mvrp-registrar-state=normal path-cost=10 point-to-point=auto priority=0x80 pvid=1 restricted-role=no restricted-tcn=no tag-stacking=no trusted=no unknown-multicast-flood=yes unknown-unicast-flood=yes
/interface bridge port add auto-isolate=no bpdu-guard=no bridge=bridge broadcast-flood=yes disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none ingress-filtering=yes interface=*C internal-path-cost=10 learn=auto multicast-router=temporary-query mvrp-applicant-state=normal-participant mvrp-registrar-state=normal path-cost=10 point-to-point=auto priority=0x80 pvid=1 restricted-role=no restricted-tcn=no tag-stacking=no trusted=no unknown-multicast-flood=yes unknown-unicast-flood=yes
/interface bridge port-controller
# disabled
set bridge=none cascade-ports="" switch=none
/interface bridge port-extender
# disabled
set control-ports="" excluded-ports="" switch=none
/interface bridge settings set allow-fast-path=yes use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=no
/ip neighbor discovery-settings set discover-interface-list=all discover-interval=30s lldp-mac-phy-config=no lldp-max-frame-size=no lldp-med-net-policy-vlan=disabled lldp-poe-power=yes lldp-vlan-info=no mode=tx-and-rx protocol=cdp,lldp,mndp
/ip settings set accept-redirects=no accept-source-route=no allow-fast-path=yes arp-timeout=30s icmp-errors-use-inbound-interface-address=no icmp-rate-limit=10 icmp-rate-mask=0x1818 ip-forward=yes ipv4-multipath-hash-policy=l3 max-neighbor-entries=16384 rp-filter=no secure-redirects=yes send-redirects=yes tcp-syncookies=no tcp-timestamps=random-offset
/ipv6 settings set accept-redirects=yes-if-forwarding-disabled accept-router-advertisements=yes-if-forwarding-disabled disable-ipv6=yes forward=no max-neighbor-entries=14336 min-neighbor-entries=3584 multipath-hash-policy=l3 soft-max-neighbor-entries=7168 stale-neighbor-detect-interval=30 stale-neighbor-timeout=60
/interface detect-internet set detect-interface-list=none internet-interface-list=none lan-interface-list=none wan-interface-list=none
/interface l2tp-server server set accept-proto-version=all accept-pseudowire-type=all allow-fast-path=no authentication=pap,chap,mschap1,mschap2 caller-id-type=ip-address default-profile=default-encryption enabled=no ipsec-secret="" keepalive-timeout=30 l2tpv3-circuit-id="" l2tpv3-cookie-length=0 l2tpv3-digest-hash=md5 !l2tpv3-ether-interface-list max-mru=1450 max-mtu=1450 max-sessions=unlimited mrru=disabled one-session-per-host=no use-ipsec=no
/interface list member add comment=defconf disabled=no interface=bridge list=LAN
/interface list member add comment=defconf disabled=no interface=ether1 list=WAN
/interface list member add disabled=no interface=bridge list=TRUSTED
/interface list member add disabled=no interface=ether1 list=TRUSTED
/interface list member add disabled=no interface=wifi1 list=TRUSTED
/interface lte settings set esim-channel=auto firmware-path=firmware mode=auto
/interface ovpn-server server add auth=sha1,md5,sha256,sha512 certificate=*0 cipher=blowfish128,aes128-cbc default-profile=default disabled=yes enable-tun-ipv6=no ipv6-prefix-len=64 keepalive-timeout=60 mac-address=FE:16:FA:03:F9:65 max-mtu=1500 mode=ip name=ovpn-server1 netmask=24 port=1194 protocol=tcp push-routes="" redirect-gateway=disabled reneg-sec=3600 require-client-certificate=no tls-version=any tun-server-ipv6=:: user-auth-method=pap vrf=main
/interface pptp-server server
# PPTP connections are considered unsafe, it is suggested to use a more modern VPN protocol instead
set authentication=mschap1,mschap2 default-profile=default-encryption enabled=no keepalive-timeout=30 max-mru=1450 max-mtu=1450 mrru=disabled
/interface sstp-server server set authentication=pap,chap,mschap1,mschap2 certificate=none ciphers=aes256-sha,aes256-gcm-sha384 default-profile=default enabled=no keepalive-timeout=60 max-mru=1500 max-mtu=1500 mrru=disabled pfs=no port=443 tls-version=any verify-client-certificate=no
/interface wifi cap set enabled=no
/interface wifi capsman set enabled=no
/interface wireguard peers add allowed-address=10.10.90.0/24,192.168.88.0/24 client-endpoint="" comment="WG client on BI PC" disabled=no endpoint-address="" endpoint-port=0 interface=wireguard1 name=peer9 preshared-key="" private-key=XXXXXf/RFr9FogUr5iBSC0jt9TV4="
/interface wireguard peers add allowed-address=10.10.100.8/32 client-endpoint="" comment=Laptop disabled=no endpoint-address="" endpoint-port=0 interface=wireguard1 name=peer10 preshared-key="" private-key=XXXXXh+amb7U03orKJBrljQqFSxc="
/interface wireguard peers add allowed-address=10.10.100.50/32,192.168.0.0/24,192.168.5.0/24 client-endpoint="" comment="355 hEX being UDM" disabled=no endpoint-address=XXXXX.dyndns.org endpoint-port=51833 interface=wireguard1 name=355 persistent-keepalive=40s preshared-key="" private-key=XXXXXBDFxZmbbJrycOWg5omLZq3g="
/interface wireguard peers add allowed-address=10.10.100.60/32,192.168.1.0/24 client-endpoint="" comment="255 Hex behind UDM" disabled=no endpoint-address=XXXXX.dyndns.org endpoint-port=51835 interface=wireguard1 name=255 persistent-keepalive=40s preshared-key="" private-key=XXXXXQcs1c+r9bzZ0aWPK0PMwbRc="
/interface wireguard peers add allowed-address=10.10.100.2/32,192.168.40.0/24 client-endpoint="" comment=371 disabled=no endpoint-address=XXXXX.dyndns.org endpoint-port=52820 interface=wireguard1 name=371 persistent-keepalive=40s preshared-key="" private-key=XXXXXHBEBjCn9YLAxn4pMzU5lohI="
/interface wireguard peers add allowed-address=192.168.30.0/24,10.10.100.30/32 client-endpoint="" comment=76 disabled=no endpoint-address=XXXXX.dyndns.org endpoint-port=51830 interface=wireguard1 name=76 persistent-keepalive=40s preshared-key="" private-key=XXXXXu3x2t1k0omNOLVY6scNgUic="
/interface wireguard peers add allowed-address=10.10.100.70/32,192.168.70.0/24 client-endpoint="" comment=125 disabled=no endpoint-address=XXXXX.dyndns.org endpoint-port=51870 interface=wireguard1 name=125 persistent-keepalive=40s preshared-key="" private-key=XXXXXtvG3PEr6Rk4GF8HbwayGqT8="
/interface wireguard peers add allowed-address=10.10.100.1/24,192.168.2.0/24 client-endpoint="" comment=212 disabled=no endpoint-address=XXXXX.dyndns.org endpoint-port=51820 interface=wireguard1 name=212 persistent-keepalive=40s preshared-key="" private-key=XXXXXbtR1YlEYPUo/op1OqXrW4Ds="
/ip address add address=10.10.100.80/24 disabled=no interface=wireguard1 network=10.10.100.0
/ip address add address=192.168.80.1/24 disabled=no interface=bridge network=192.168.80.0
/ip address add address=10.0.0.1/24 disabled=no interface=Guest2g network=10.0.0.0
/ip address add address=10.0.0.1/24 disabled=no interface=Guest5g network=10.0.0.0
/ip cloud set back-to-home-vpn=revoked-and-disabled ddns-enabled=yes ddns-update-interval=1h update-time=yes
/ip cloud advanced set use-local-address=no
/ip dhcp-client add add-default-route=yes comment=defconf default-route-distance=1 dhcp-options=hostname,clientid disabled=no interface=ether1 use-peer-dns=yes use-peer-ntp=yes
/ip dhcp-server config set accounting=yes interim-update=0s radius-password=empty store-leases-disk=5m
/ip dhcp-server network add address=10.0.0.0/24 caps-manager="" dhcp-option="" dns-server=9.9.9.9,1.1.1.1,8.8.8.8 gateway=10.0.0.1 !next-server ntp-server="" wins-server=""
/ip dhcp-server network add address=192.168.80.0/24 caps-manager="" comment=defconf dhcp-option="" dns-server=192.168.80.1 gateway=192.168.80.1 !next-server ntp-server="" wins-server=""
/ip dns set address-list-extra-time=0s allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB doh-max-concurrent-queries=50 doh-max-server-connections=5 doh-timeout=5s max-concurrent-queries=100 max-concurrent-tcp-sessions=20 max-udp-packet-size=4096 mdns-repeat-ifaces="" query-server-timeout=2s query-total-timeout=10s servers=9.9.9.9,8.8.8.8,1.1.1.1,8.8.4.4 use-doh-server="" verify-doh-cert=no vrf=main
/ip dns static add address=10.10.100.80 comment=defconf disabled=no name=729-10.10.100.80.local ttl=1d type=A
/ip dns static add address=192.168.80.1 comment=defconf disabled=no name=729.local ttl=1d type=A
/ip dns static add address=10.0.0.1 comment=defconf disabled=no name=<THISLOCATION?.router.lan ttl=1d type=A
/ip firewall address-list add address=XXXXX.dyndns.org disabled=no dynamic=no list=XXXXX
/ip firewall address-list add address=XXXXX.dyndns.org disabled=no dynamic=no list=212
/ip firewall address-list add address=<THIS LOCATION>.dyndns.org disabled=no dynamic=no list=dynamic-WANIP
/ip firewall filter add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" disabled=yes dst-address=127.0.0.1
/ip firewall filter add action=accept chain=input src-address-list=212
/ip firewall filter add action=accept chain=input src-address-list=XXXXX
/ip firewall filter add action=drop chain=input comment="defconf: drop all not coming from LAN" !connection-bytes !connection-limit !connection-mark !connection-nat-state !connection-rate !connection-state !connection-type !content disabled=no !dscp !dst-address !dst-address-list !dst-address-type !dst-limit !dst-port !fragment !hotspot !icmp-options !in-bridge-port !in-bridge-port-list !in-interface in-interface-list=!LAN !ingress-priority !ipsec-policy !ipv4-options !layer7-protocol !limit log=no log-prefix="" !nth !out-bridge-port !out-bridge-port-list !out-interface !out-interface-list !packet-mark !packet-size !per-connection-classifier !port !priority !protocol !psd !random !routing-mark !src-address !src-address-list !src-address-type !src-mac-address !src-port !tcp-flags !tcp-mss !time !tls-host !ttl
/ip firewall filter add action=accept chain=forward comment="Allow WG to subnet" disabled=yes dst-address=192.168.1.0/24 in-interface=wireguard1
/ip firewall filter add action=accept chain=forward disabled=yes in-interface=wireguard1 protocol=udp
/ip firewall filter add action=accept chain=forward comment="Allow wireguard to subnet" disabled=yes dst-address=192.168.80.0/24 in-interface=wireguard1
/ip firewall nat add action=dst-nat chain=dstnat disabled=yes dst-port=80 log=yes protocol=tcp to-addresses=192.168.4.1 to-ports=80
/ip firewall nat add action=src-nat chain=srcnat disabled=yes dst-address=192.168.4.0/24 log=yes to-addresses=192.168.4.2 !to-ports
/ip firewall service-port set ftp disabled=no ports=21
/ip firewall service-port set tftp disabled=no ports=69
/ip firewall service-port set irc disabled=yes ports=6667
/ip firewall service-port set h323 disabled=no
/ip firewall service-port set sip disabled=no ports=5060,5061 sip-direct-media=yes sip-timeout=1h
/ip firewall service-port set pptp disabled=no
/ip firewall service-port set rtsp disabled=yes ports=554
/ip firewall service-port set udplite disabled=no
/ip firewall service-port set dccp disabled=no
/ip firewall service-port set sctp disabled=no
/ip hotspot service-port set ftp disabled=no ports=21
/ip hotspot user set [ find default=yes ] comment="counters and limits for trial users" disabled=no name=default-trial
/ip ipsec policy set 0 disabled=no dst-address=::/0 group=default proposal=default protocol=all src-address=::/0 template=yes
/ip ipsec settings set accounting=yes interim-update=0s xauth-use-radius=no
/ip media settings set thumbnails=""
/ip nat-pmp set enabled=no
/ip proxy set always-from-cache=no anonymous=no cache-administrator=webmaster cache-hit-dscp=4 cache-on-disk=no cache-path=web-proxy enabled=no max-cache-object-size=2048KiB max-cache-size=unlimited max-client-connections=600 max-fresh-time=3d max-server-connections=600 parent-proxy=:: parent-proxy-port=0 port=8080 serialize-connections=no src-address=::
/ip route add disabled=no dst-address=192.168.88.0/24 gateway=wireguard1 routing-table=main suppress-hw-offload=no
/ip route add disabled=no dst-address=192.168.2.0/24 gateway=wireguard1 routing-table=main suppress-hw-offload=no
/ip route add disabled=no dst-address=192.168.0.0/24 gateway=wireguard1 routing-table=main suppress-hw-offload=no
/ip route add disabled=no dst-address=192.168.40.0/24 gateway=wireguard1 routing-table=main suppress-hw-offload=no
/ip route add disabled=no dst-address=192.168.70.0/24 gateway=wireguard1 routing-table=main suppress-hw-offload=no
/ip route add disabled=no dst-address=192.168.1.0/24 gateway=wireguard1 routing-table=main suppress-hw-offload=no
/ip route add disabled=no dst-address=192.168.20.0/24 gateway=wireguard1 routing-table=main suppress-hw-offload=no
/ip route add disabled=no dst-address=192.168.30.0/24 gateway=wireguard1 routing-table=main suppress-hw-offload=no
/ip service set telnet address="" disabled=no max-sessions=20 port=23 vrf=main
/ip service set ftp address="" disabled=no max-sessions=20 port=21 vrf=main
/ip service set www address="" disabled=no max-sessions=20 port=80 vrf=main
/ip service set ssh address="" disabled=no max-sessions=20 port=22 vrf=main
/ip service set www-ssl address="" certificate=none disabled=no max-sessions=20 port=443 tls-version=any vrf=main
/ip service set api address="" disabled=no max-sessions=20 port=8728 vrf=main
/ip service set winbox address="" disabled=no max-sessions=20 port=8291 vrf=main
/ip service set api-ssl address="" certificate=none disabled=no max-sessions=20 port=8729 tls-version=any vrf=main
/ip smb shares set [ find default=yes ] directory=/pub disabled=yes invalid-users="" name=pub read-only=no require-encryption=no valid-users=""
/ip socks set auth-method=none connection-idle-timeout=2m enabled=no max-connections=200 port=1080 version=4 vrf=main
/ip ssh set always-allow-password-login=no ciphers=auto forwarding-enabled=both host-key-size=2048 host-key-type=rsa strong-crypto=no
/ip tftp settings set max-block-size=4096
/ip traffic-flow set active-flow-timeout=30m cache-entries=256k enabled=no inactive-flow-timeout=15s interfaces=all packet-sampling=no sampling-interval=0 sampling-space=0
/ip traffic-flow ipfix set bytes=yes dst-address=yes dst-address-mask=yes dst-mac-address=yes dst-port=yes first-forwarded=yes gateway=yes icmp-code=yes icmp-type=yes igmp-type=yes in-interface=yes ip-header-length=yes ip-total-length=yes ipv6-flow-label=yes is-multicast=yes last-forwarded=yes nat-dst-address=yes nat-dst-port=yes nat-events=no nat-src-address=yes nat-src-port=yes out-interface=yes packets=yes protocol=yes src-address=yes src-address-mask=yes src-mac-address=yes src-port=yes sys-init-time=yes tcp-ack-num=yes tcp-flags=yes tcp-seq-num=yes tcp-window-size=yes tos=yes ttl=yes udp-length=yes
/ip upnp set allow-disable-external-interface=no enabled=no show-dummy-rule=yes
/ipv6 nd set [ find default=yes ] advertise-dns=yes advertise-mac-address=yes disabled=no hop-limit=unspecified interface=all managed-address-configuration=no mtu=unspecified other-configuration=no ra-delay=3s ra-interval=3m20s-10m ra-lifetime=30m ra-preference=medium reachable-time=unspecified retransmit-interval=unspecified
/ipv6 nd prefix default set autonomous=yes preferred-lifetime=1w valid-lifetime=4w2d
/mpls settings set allow-fast-path=yes dynamic-label-range=16-1048575 propagate-ttl=yes
/ppp aaa set accounting=yes enable-ipv6-accounting=no interim-update=0s use-circuit-id-in-nas-port-id=no use-radius=no
/radius incoming set accept=no port=3799 vrf=main
/routing igmp-proxy set query-interval=2m5s query-response-interval=10s quick-leave=no
/routing settings set single-process=no
/snmp set contact="" enabled=yes engine-id-suffix="" location="" src-address=:: trap-community=public trap-generators=temp-exception trap-target="" trap-version=2 vrf=main
/system clock set time-zone-autodetect=yes time-zone-name=America/New_York
/system clock manual set dst-delta=+00:00 dst-end="1970-01-01 00:00:00" dst-start="1970-01-01 00:00:00" time-zone=+00:00
/system health settings set cpu-overtemp-check=no cpu-overtemp-startup-delay=1m cpu-overtemp-threshold=105C
/system identity set name=729hAPax3
/system leds set 0 disabled=no leds=poe-led type=poe-out
/system leds set 1 disabled=no interface=ether1 leds=led1 type=interface-activity
/system leds set 2 disabled=no interface=ether2 leds=led2 type=interface-activity
/system leds set 3 disabled=no interface=ether3 leds=led3 type=interface-activity
/system leds set 4 disabled=no interface=ether4 leds=led4 type=interface-activity
/system leds set 5 disabled=no interface=ether5 leds=led5 type=interface-activity
/system leds settings set all-leds-off=never
/system logging set 0 action=memory disabled=no prefix="" regex="" topics=info
/system logging set 1 action=memory disabled=no prefix="" regex="" topics=error
/system logging set 2 action=memory disabled=no prefix="" regex="" topics=warning
/system logging set 3 action=echo disabled=no prefix="" regex="" topics=critical
/system note set note="" show-at-cli-login=no show-at-login=no
/system ntp client set enabled=yes mode=unicast servers=0.north-america.pool.ntp.org,1.north-america.pool.ntp.org,3.pool.ntp.org vrf=main
/system ntp server set auth-key=none broadcast=no broadcast-addresses="" enabled=no local-clock-stratum=5 manycast=no multicast=no use-local-clock=no vrf=main
/system ntp client servers add address=0.north-america.pool.ntp.org auth-key=none disabled=no iburst=yes max-poll=10 min-poll=6
/system ntp client servers add address=1.north-america.pool.ntp.org auth-key=none disabled=no iburst=yes max-poll=10 min-poll=6
/system ntp client servers add address=3.pool.ntp.org auth-key=none disabled=no iburst=yes max-poll=10 min-poll=6
/system package local-update mirror set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=0.0.0.0 user=""
/system resource irq set 0 cpu=auto
/system resource irq set 1 cpu=auto
/system resource irq set 2 cpu=auto
/system resource irq set 3 cpu=auto
/system resource irq set 4 cpu=auto
/system resource irq set 5 cpu=auto
/system resource irq set 6 cpu=auto
/system resource irq set 7 cpu=auto
/system resource irq set 8 cpu=auto
/system resource irq set 9 cpu=auto
/system resource irq set 10 cpu=auto
/system resource irq set 11 cpu=auto
/system resource irq set 12 cpu=auto
/system resource irq set 13 cpu=auto
/system resource irq set 14 cpu=auto
/system resource irq set 15 cpu=auto
/system resource irq set 16 cpu=auto
/system resource irq set 17 cpu=auto
/system resource irq set 18 cpu=auto
/system resource irq set 19 cpu=auto
/system resource irq set 20 cpu=auto
/system resource irq set 21 cpu=auto
/system resource irq set 22 cpu=auto
/system resource irq set 23 cpu=auto
/system resource irq set 24 cpu=auto
/system resource irq set 25 cpu=auto
/system resource irq set 26 cpu=auto
/system resource irq set 27 cpu=auto
/system resource irq set 28 cpu=auto
/system resource irq set 29 cpu=auto
/system resource irq set 30 cpu=auto
/system resource irq set 31 cpu=auto
/system resource irq set 32 cpu=auto
/system resource irq set 33 cpu=auto
/system resource irq set 34 cpu=auto
/system resource irq set 35 cpu=auto
/system resource irq set 36 cpu=auto
/system resource irq set 37 cpu=auto
/system resource irq set 38 cpu=auto
/system resource irq set 39 cpu=auto
/system resource irq set 40 cpu=auto
/system resource irq set 41 cpu=auto
/system resource irq set 42 cpu=auto
/system resource irq set 43 cpu=auto
/system resource irq set 44 cpu=auto
/system resource irq set 45 cpu=auto
/system resource irq set 46 cpu=auto
/system resource irq set 47 cpu=auto
/system resource irq set 48 cpu=auto
/system resource irq rps set ether1 disabled=yes
/system resource irq rps set ether2 disabled=yes
/system resource irq rps set ether3 disabled=yes
/system resource irq rps set ether4 disabled=yes
/system resource irq rps set ether5 disabled=yes
/system resource usb settings set authorization=no
/system routerboard mode-button set enabled=no hold-time=0s..1m on-event=""
/system routerboard reset-button set enabled=no hold-time=0s..1m on-event=""
/system routerboard settings set auto-upgrade=no boot-device=nand-if-fail-then-ethernet boot-protocol=bootp force-backup-booter=no preboot-etherboot=disabled preboot-etherboot-server=any protected-routerboot=disabled reformat-hold-button=20s reformat-hold-button-max=10m silent-boot=no
/system routerboard wps-button set enabled=no hold-time=0s..1m on-event=""
/system scheduler add disabled=yes interval=1d name=dyndns on-event=dyndns policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=2022-10-18 start-time=21:25:36
/system scheduler add disabled=yes interval=10m name=WG-iface-restart on-event=WG-iface-restart policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=2023-03-11 start-time=13:29:33
/system scheduler add disabled=no interval=3d name=export-download on-event=export-download policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=2023-06-22 start-time=01:59:47
/system scheduler add disabled=yes interval=5d name=iplist on-event=IPlist policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=2023-04-10 start-time=06:49:31
/system scheduler add disabled=no interval=2w name=dynamic-data-rextended on-event=dynamic-data-rextended policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=2023-09-30 start-time=02:58:29
/system scheduler add disabled=no interval=2w name=dhcpleasesftp on-event=dhcpleasesftp policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=2024-01-09 start-time=18:27:20
/system scheduler add disabled=no interval=1d name=DynDNS on-event=DynDNS policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=2022-10-18 start-time=02:00:00
/system scheduler add disabled=yes interval=5m name=Data_to_Splunk on-event=Data_to_Splunk_using_Syslog policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=2024-09-06 start-time=18:28:30
/system scheduler add disabled=no interval=0s name=SystemInfoJRS on-event=":delay 60s\
    \n/system script run SystemInfoJRS" policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-time=startup
/system scheduler add disabled=no interval=12h name=UPSonBattery on-event=UPSonBattery policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=2024-10-28 start-time=18:07:34
/system scheduler add disabled=yes interval=10s name=Linevoltageunder120 on-event=Linevoltageunder120 policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=2024-10-29 start-time=11:08:15
/system script add dont-require-permissions=no name=export-download owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\r\
    \n\r\
    \n/system\r\
    \n:local identitydate \"\$[identity get name]_\$yyyy-\$MM-\$dd\"\r\
    \n/export show-sensitive file=\"\$identitydate\"\r\
    \n\r\
    \n/tool fetch upload=yes mode=ftp ascii=no src-path=\"/\$[\$identitydate].rsc\" dst-path=\"/mikrotik-backups/\$[\$identitydate].rsc\" address=192.168.2.22 port=21 user=mikrotik password=XXXXX\r\
    \n\r\
    \n/file remove \"\$[\$identitydate].rsc\"\r\
    \n\r\
    \n:log info (\"Uploaded rsc backup to 192.168.2.22 as \".\$identitydate)"
/system script add dont-require-permissions=no name=WG-iface-restart owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=":foreach i in=[/interface/wireguard/peers/find where disabled=no endpoint-address~\"[a-z]\\\$\"] do={\r\
    \n  :local LastHandshake [/interface/wireguard/peers/get \$i last-handshake]\r\
    \n  :if (([:tostr \$LastHandshake] = \"\") or (\$LastHandshake > [:totime \"5m\"])) do={\r\
    \n   \r\
    \n     :log info \"WG-iface-restart script found WG peers with last handshake greater than 5 minutes; then reset the endpoint-address to reload dns of endpoint\"\r\
    \n\r\
    \n    /interface/wireguard/peers/set \$i endpoint-address=[/interface/wireguard/peers/get \$i endpoint-address]\r\
    \n\r\
    \n   :local endpoint [/interface/wireguard/peers/get \$i endpoint-address]\r\
    \n   :log info \"WG-iface-restart script found WG peer with last handshake greater than 5 minutes; then reset the endpoint-address to reload dns of endpoint:  \$endpoint\"\r\
    \n\r\
    \n  }\r\
    \n}\r\
    \n"
/system script add dont-require-permissions=no name=IPlist owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="# Export public IP and mail it\r\
    \n\r\
    \n/ip/address print file=\"729-IP-\$[\$nowdate]\"\r\
    \n\r\
    \n/tool fetch upload=yes mode=ftp ascii=no src-path=\"729-IP-\$[\$nowdate].txt\" dst-path=\"/mikrotik-backups/729-IP-\$[\$nowdate].txt\" address=192.168.2.22 port=21 user=mikrotik password=XXXXX\r\
    \n\r\
    \n/file remove \"729-IP-\$[\$nowdate].txt\""
/system script add dont-require-permissions=no name=Get_Date-Time owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=":local isodateonly do={\r\
    \n    /system clock\r\
    \n    :local vdate [get date]\r\
    \n    :local vdoff [:toarray \"0,4,5,7,8,10\"]\r\
    \n    :local MM    [:pick \$vdate (\$vdoff->2) (\$vdoff->3)]\r\
    \n    :local M     [:tonum \$MM]\r\
    \n    :if (\$vdate ~ \".../../....\") do={\r\
    \n        :set vdoff [:toarray \"7,11,1,3,4,6\"]\r\
    \n        :set M     ([:find \"xxanebarprayunulugepctovecANEBARPRAYUNULUGEPCTOVEC\" [:pick \$vdate (\$vdoff->2) (\$vdoff->3)] -1] / 2)\r\
    \n        :if (\$M>12) do={:set M (\$M - 12)}\r\
    \n        :set MM    [:pick (100 + \$M) 1 3]\r\
    \n    }\r\
    \n    :local yyyy [:pick \$vdate (\$vdoff->0) (\$vdoff->1)]\r\
    \n    :local dd   [:pick \$vdate (\$vdoff->4) (\$vdoff->5)]\r\
    \n    :return \"\$yyyy-\$MM-\$dd\"\r\
    \n}\r\
    \n\r\
    \n:put \$[\$yyyy-\$MM-\$dd]"
/system script add dont-require-permissions=yes name=Get_Date-Time_2 owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=":global simplercurrdatetimestr do={\r\
    \n    /system clock\r\
    \n    :local vtime [get time]\r\
    \n    }\r\
    \n    :local HH   [:pick \$vtime 0  2]\r\
    \n    :local mm   [:pick \$vtime 3  5]\r\
    \n    :local ss   [:pick \$vtime 6  8]\r\
    \n\r\
    \n    :return \"\$yyyy-\$MM-\$dd \$HH:\$mm:\$ss\"\r\
    \n}\r\
    \n\r\
    \n:put [\$simplercurrdatetimestr]\r\
    \n\r\
    \n:put [\$yyyy]\r\
    \n\r\
    \n"
/system script add comment=test dont-require-permissions=yes name=test owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\r\
    \n\r\
    \n/system\r\
    \n:local identity \"\$[identity get name]\"\r\
    \n:local Host \$host\r\
    \n:local Status [get [find where host=\"\$Host\"] status]\r\
    \n:local Interval [get [find where host=\"\$Host\"] interval]\r\
    \n\r\
    \n:log info \"script=netwatch watch_host=\$Host comment=\\\"\$Comment\\\" status=\$Status interval=\$Interval\"\r\
    \n\r\
    \n:tool e-mail send to=jXXXXX@domain.com subject=\"\$identity \$Status\" body=( \"\$Host\" )"
/system script add dont-require-permissions=no name=script1 owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=":local arrMonths {jan=\"01\";feb=\"02\";mar=\"03\";apr=\"04\";may=\"05\";jun=\"06\";jul=\"07\";aug=\"08\";sep=\"09\";oct=\"10\";nov=\"11\";dec=\"12\"}\r\
    \n:local today [/system clock get date]\r\
    \n:local dateinside \"\$[:pick \$today 7 11]-\$(\$arrMonths->[:pick \$today 1 3])-\$[:pick \$today 4 6]\"\r\
    \n:local backupfile \"\$[/system identity get name]_\$dateinside_\$[/system clock get time]_\$[/system resource get uptime].backup\""
/system script add dont-require-permissions=no name=script2 owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=":local thisBox [/system identity get name];\r\
    \n\r\
    \n:global simplercurrdatetimestr do={\r\
    \n    /system clock\r\
    \n    }\r\
    \n    :global yyyy [:pick \$vdate (\$vdoff->0) (\$vdoff->1)]\r\
    \n\r\
    \n    :return \"\$yyyy-\$MM-\$dd-\$HH:\$mm:\$ss\"\r\
    \n}\r\
    \n\r\
    \n#:put [\$simplercurrdatetimestr]\r\
    \n\r\
    \n\r\
    \n#:tool e-mail send to=jXXXXX@domain.com subject=\"\$thisBox UP\" body=( \$simplercurrdatetimestr \$thisBox UP to 24.168.72.1\" )\r\
    \n\r\
    \n:tool e-mail send to=jXXXXX@domain.com subject=\"\$thisBox UP\" body=(\$simplercurrdatetimestr)"
/system script add dont-require-permissions=no name=dynamic-data-rextended owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="/system\r\
    \n:local identitydate \"\$[identity get name]_\$[clock get date]\"\r\
    \n:local stringexec   \"/system iden print; :put \\\"\\\\r\\\\n\\\"; /ip cloud pri; :put \\\"\\\\r\\\\n\\\";  /ip dhcp-server lease pri det; :put \\\"\\\\r\\\\n\\\"; /int bridge host pri det\"\r\
    \n\r\
    \n:if ([:len [/system package find where name=\"wifiwave2\"]] > 1) do={\r\
    \n    :set stringexec \"\$stringexec; :put \\\"\\\\r\\\\n\\\" /int wifiwave2 reg pri det\"\r\
    \n} \r\
    \n\r\
    \n    :set stringexec \"\$stringexec; :put \\\"\\\\r\\\\n\\\" /int wireless reg pri det\"\r\
    \n}\r\
    \n\r\
    \n\r\
    \n/file remove [find where name=tmpresults.txt]\r\
    \n:delay 1s\r\
    \n:execute \$stringexec file=tmpresults.txt\r\
    \n:delay 2s\r\
    \n\r\
    \n/tool fetch upload=yes mode=ftp ascii=no address=192.168.2.22 port=21 user=mikrotik password=XXXXX \\\r\
    \n    src-path=tmpresults.txt dst-path=\"/mikrotik-backups/\$identitydate-dynamicdata.txt\"\r\
    \n\r\
    \n/file remove [find where name=tmpresults.txt]"
/system script add dont-require-permissions=no name=DHCP_to_DNS owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="# SPDX-License-Identifier: CC0-1.0\
    \n\r\
    \n\r\r\r\r\
    \n\r\
    \n\r\r:local domains [:toarray \"729.local\"]\
    \n\r\
    \n\r\r:local dnsttl \"15m\"\
    \n\r\
    \n\r\r\
    \n\r\
    \n\r\r:local magiccomment \"automatic-from-dhcp (magic comment)\"\
    \n\r\
    \n\r\r:local activehosts [:toarray \"\"]\
    \n\r\
    \n\r\r\
    \n\r\
    \n\r\r:foreach lease in [/ip dhcp-server lease find] do={\
    \n\r\
    \n\r\r  :local hostname [/ip dhcp-server lease get value-name=host-name \$lease]\
    \n\r\
    \n\r\r  :local hostaddr [/ip dhcp-server lease get value-name=address \$lease]\
    \n\r\
    \n\r\r\
    \n\r\
    \n\r\r  :if ([:len \$hostname] > 0) do={\
    \n\r\
    \n\r\r    :foreach domain in \$domains do={\
    \n\r\
    \n\r\r      :local regdomain \"\$hostname.\$domain\"\
    \n\r\
    \n\r\r      :set activehosts (\$activehosts, \$regdomain)\
    \n\r\
    \n\r\r\
    \n\r\
    \n\r\r      :if ([:len [/ip dns static find where name=\$regdomain]] = 0) do={\
    \n\r\
    \n\r\r        /ip dns static add name=\$regdomain address=\$hostaddr comment=\$magiccomment ttl=\$dnsttl\
    \n\r\
    \n\r\r      } else={\
    \n\r\
    \n\r\r        :if ([:len [/ip dns static find where name=\$regdomain comment=\$magiccomment]] = 1) do={\
    \n\r\
    \n\r\r          /ip dns static set address=\$hostaddr [/ip dns static find name=\$regdomain comment=\$magiccomment]\
    \n\r\
    \n\r\r        }\
    \n\r\
    \n\r\r      }\
    \n\r\
    \n\r\r    }\
    \n\r\
    \n\r\r  }\
    \n\r\
    \n\r\r}\
    \n\r\
    \n\r\r\
    \n\r\
    \n\r\r:foreach dnsentry in [/ip dns static find where comment=\$magiccomment] do={\
    \n\r\
    \n\r\r  :local hostname [/ip dns static get value-name=name \$dnsentry]\
    \n\r\
    \n\r\r  :if ([:type [:find \$activehosts \$hostname]] = \"nil\") do={\
    \n\r\
    \n\r\r    /ip dns static remove \$dnsentry\
    \n\r\
    \n\r\r  }\
    \n\r\
    \n\r\r}\
    \n\r\
    \n\r\r"
/system script add dont-require-permissions=no name=dhcpleasesftp owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\r\
    \n/file remove [find where name=temp3.txt]\r\
    \n\r\
    \n/system\r\
    \n\r\
    \n:local identitydate \"\$[identity get name]\"\r\
    \n\r\
    \n:local stringexec \"/ip dhcp-server lease; :foreach i in=[find] do={ :put ([get \\\$i address].\\\",\\\".[get \\\$i comment].\\\",\\\",[get \\\$i mac-address].\\\",\\\".[get \\\$i host-name]  ) }\"\r\
    \n\r\
    \n\r\
    \n:execute \$stringexec file=temp3\r\
    \n\r\
    \n:delay 60\r\
    \n\r\
    \n/tool fetch address=192.168.2.22 port=21 user=mikrotik password=XXXXX src-path=temp3.txt mode=ftp dst-path=\"/mikrotik-backups/\$identitydate-leases.txt\" upload=yes ascii=no\r\
    \n\r\
    \n\r\
    \n\r\
    \n\r\
    \n"
/system script add dont-require-permissions=no name=DynDNS owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\
    \n/system\
    \n#/export show-sensitive file=\"\$identitydate\"\
    \n\
    \n# Export public IP and mail it\
    \n\
    \n#/ip/address print file=\"\$identitydate-IP\"\
    \n\
    \n#/tool fetch upload=yes mode=ftp ascii=no src-path=\"\$[\$identitydate]-IP.txt\" dst-path=\"/mikrotik-backups/\$[\$identitydate]-IP.txt\" address=192.168.2.22 port=21 user=mikrotik password=XXXXX\
    \n\
    \n#/file remove \"\$identitydate-IP.txt\"\
    \n\
    \n# Set needed variables\
    \n\t:local username \"josephXXXXX\"\
    \n\t:local clientkey XXXXX788e206873aa78bc3\"\
    \n\t:local hostname \"<THISLOCATION>.dyndns.org\"\
    \n\
    \n\t:global dyndnsForce\
    \n\t:global previousIP\
    \n\
    \n# get the current IP address from the internet (in case of double-nat)\
    \n\t/tool fetch mode=http address=\"checkip.dyndns.org\" src-path=\"/\" dst-path=\"/dyndns.checkip.html\"\
    \n\t:delay 1\
    \n\t:local result [/file get dyndns.checkip.html contents]\
    \n\
    \n# parse the current IP result\
    \n\t:local resultLen [:len \$result]\
    \n\t:local startLoc [:find \$result \": \" -1]\
    \n\t:set startLoc (\$startLoc + 2)\
    \n\t:local endLoc [:find \$result \"</body>\" -1]\
    \n\t:local currentIP [:pick \$result \$startLoc \$endLoc]\
    \n\t:log info \"UpdateDynDNS: currentIP = \$currentIP\"\
    \n\
    \n# Remove the # on next line to force an update every single time - useful for debugging,\
    \n# but you could end up getting blacklisted by DynDNS!\
    \n\
    \n#:set dyndnsForce true\
    \n\
    \n# Determine if dyndns update is needed\
    \n# more dyndns updater request details https://help.dyn.com/remote-access-api/perform-update/\
    \n\t:log info \"UpdateDynDNS: previousIP = \$previousIP\"\
    \n\t:if (\$dyndnsForce = true) do={ :log warning \"UpdateDynDNS: Forced update on\" }\
    \n\
    \n\t:if ((\$currentIP != \$previousIP) || (\$dyndnsForce = true)) do={\
    \n\t\t:set dyndnsForce false\
    \n\t\t:set previousIP \$currentIP\
    \n\
    \n\t\t/tool fetch mode=https \\\
    \n\t\turl=\"https://\$username:\$clientkey XXXXXg/v3/update\?hostname=\$hostname&myip=\$currentIP\" \\ \
    \n\t\tdst-path=\"/dyndns.txt\"\
    \n\
    \n\t\t:delay 1\
    \n\t\t:local result [/file get dyndns.txt contents]\
    \n\t\t:log info (\"UpdateDynDNS: Dyndns update needed\")\
    \n\t\t:log info (\"UpdateDynDNS: Dyndns Update Result: \".\$result)\
    \n\t\t:put (\"Dyndns Update Result: \".\$result)\
    \n\
    \n                                           /ip/address print file=\"\$identitydate-IP\"\
    \n\
    \n                                           /tool fetch upload=yes mode=ftp ascii=no src-path=\"\$[\$identitydate]-IP.txt\" dst-path=\"/mikrotik-backups/\$[\$identitydate]-IP.txt\" address=192.168.2.22 port=21 user=mikrotik password=XXXXX\
    \n\
    \n                                          /file remove \"\$identitydate-IP.txt\"\
    \n\
    \n\
    \n\t} else={\
    \n\t\t:log info (\"UpdateDynDNS: No dyndns update needed\")\
    \n\t}\
    \n\
    \n"
/system script add dont-require-permissions=no name=Data_to_Splunk_using_Syslog owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="# Collect information from Mikrotik RouterOS\r\
    \n# Jotne 2024\r\
    \n# Script name=Data_to_Splunk_using_Syslog\r\
    \n:log info message=\"script=version ver=5.6\"\r\
    \n# ----------------------------------\r\
    \n\r\
    \n# Auto update syslog server. 5.3-5.4.\r\
    \n# Change <your syslog dns name> to the dns of your syslog server.\r\
    \n# The update is disabled by default.  Remove the # from the two next line to use it.\r\
    \n\r\
    \n#:local mySyslog [resolve <your syslog dns name>]\r\
    \n#/system/logging/action/set [find where name=\"logserver\"] remote=\$mySyslog\r\
    \n\r\
    \n\r\
    \n# What data to collect.  Set to false to skip the section \r\
    \n:local SystemResource true\r\
    \n:local SystemInformation true\r\
    \n:local SystemHealth true\r\
    \n:local TrafficData true\r\
    \n:local AccountData true\r\
    \n:local uPnP true\r\
    \n:local Wireless true\r\
    \n:local AddressLists true\r\
    \n:local DHCP true\r\
    \n:local Neighbor true\r\
    \n:local InterfaceData true\r\
    \n:local CmdHistory true\r\
    \n:local CAPsMANN false\r\
    \n\r\
    \n:local Routing true\r\
    \n:local OSPF false\r\
    \n:local BGP false\r\
    \n\r\
    \n:local PPP true\r\
    \n:local IPSEC true\r\
    \n\r\
    \n# Get RouterOS main version (used to run different script on different version)\r\
    \n:local train [:tonum [:pick [/system resource get version] 0 1]] \r\
    \n\r\
    \n# Collect system resource\r\
    \n:if (\$SystemResource) do={\r\
    \n\t/system resource\r\
    \n\t:local cpuload [get cpu-load]\r\
    \n\t:local freemem ([get free-memory]/1048576)\r\
    \n\t:local totmem ([get total-memory]/1048576)\r\
    \n\t:local freehddspace ([get free-hdd-space]/1048576)\r\
    \n\t:local totalhddspace ([get total-hdd-space]/1048576)\r\
    \n\t:local up [get uptime]\r\
    \n\t:local sector [get write-sect-total]\r\
    \n\t:log info message=\"script=resource free_memory=\$freemem MB total_memory=\$totmem MB free_hdd_space=\$freehddspace MB total_hdd_space=\$totalhddspace MB cpu_load=\$cpuload uptime=\$up write-sect-total=\$sector\"\r\
    \n}\r\
    \n\r\
    \n\r\
    \n# Make some part only run every hours\r\
    \n:global Hour\r\
    \n:local run false\r\
    \n:local hour [:pick [/system clock get time] 0 2]\r\
    \n:if (\$Hour != \$hour) do={\r\
    \n\t:global Hour \$hour\r\
    \n\t:set run true\r\
    \n}\r\
    \n\r\
    \n\r\
    \n# Get NTP status\r\
    \n:local ntpstatus \"\"\r\
    \n:if ([:len [/system package find where !disabled and name=ntp]] > 0 or [:tonum [:pick [/system resource get version] 0 1]] > 6) do={\r\
    \n    :set ntpstatus [/system ntp client get status]\r\
    \n} else={\r\
    \n    :if ([:typeof [/system ntp client get last-update-from]] = \"nil\") do={\r\
    \n        :set ntpstatus \"using-local-clock\"\r\
    \n    } else={\r\
    \n        :set ntpstatus \"synchronized\"\r\
    \n    }\r\
    \n}\r\
    \n:log info message=\"script=ntp status=\$ntpstatus\" \r\
    \n\r\
    \n\r\
    \n# Get interface traffic data for all interface\r\
    \n:if (\$TrafficData) do={\r\
    \n\t:foreach id in=[/interface find] do={\r\
    \n\t\t:local output \"\$[/interface print stats as-value where .id=\$id]\"\r\
    \n\t\t:set ( \"\$output\"->\"script\" ) \"if_traffic\"\r\
    \n\t\t:log info message=\"\$output\"\r\
    \n\t}\r\
    \n}\r\
    \n\r\
    \n\r\
    \n# Get traffic data v2 (Kid Control)\r\
    \n:if (\$AccountData) do={\r\
    \n\t:foreach logline in=[/ip kid-control device find] do={\r\
    \n\t\t:local output \"\$[/ip kid-control device get \$logline]\"\r\
    \n\t\t:set ( \"\$output\"->\"script\" ) \"kids\"\r\
    \n\t}\r\
    \n}\r\
    \n\r\
    \n\r\
    \n# Finding dynmaic lines used in uPnP\r\
    \n:if (\$uPnP) do={\r\
    \n\t:foreach logline in=[/ip firewall nat find where dynamic=yes and comment~\"^upnp \"] do={\r\
    \n\t\t:local output \"\$[/ip firewall nat print as-value from=\$logline]\"\r\
    \n\t\t:set ( \"\$output\"->\"script\" ) \"upnp\"\r\
    \n\t\t:log info message=\"\$output\" \r\
    \n\t}\r\
    \n}\r\
    \n\r\
    \n\r\
    \n# Collect system information 5.5 added ID for non routerBoard 5.6 Remvoed serial\r\
    \n:local model na\r\
    \n:local ffirmware na\r\
    \n:local cfirmware na\r\
    \n:local ufirmware na\r\
    \n:if (\$SystemInformation and \$run) do={\r\
    \n\t:local version ([/system resource get version])\r\
    \n\t:local board ([/system resource get board-name])\r\
    \n\t:local identity ([/system identity get name])\r\
    \n\t:do {\r\
    \n\t\t:if (\$board!=\"CHR\" OR \$board!=\"x86\") do={\r\
    \n\t\t\t/system routerboard\r\
    \n\t\t\t:set model ([get model])\r\
    \n\t\t\t:set ffirmware ([get factory-firmware])\r\
    \n\t\t\t:set cfirmware ([get current-firmware])\r\
    \n\t\t\t:set ufirmware ([get upgrade-firmware])\r\
    \n\t\t}\r\
    \n\t} on-error={}\r\
    \n\t:log info message=\"script=sysinfo version=\\\"\$version\\\" board-name=\\\"\$board\\\" model=\\\"\$model\\\" identity=\\\"\$identity\\\" factory-firmware=\\\"\$ffirmware\\\" current-firmware=\\\"\$cfirmware\\\" upgrade-firmware=\\\"\$ufirmware\\\"\"\r\
    \n}\r\
    \n\r\
    \n\r\
    \n# Collect system health\r\
    \n:if (\$train > 6 and \$SystemHealth) do={\r\
    \n\t# New version (RouterOS >6)\r\
    \n\t:foreach id in=[/system health find] do={\r\
    \n\t\t:local health \"\$[/system health get \$id]\"\r\
    \n\t\t:set ( \"\$health\"->\"script\" ) \"health\"\r\
    \n\t\t:log info message=\"\$health\"\r\
    \n\t}\r\
    \n} else={\r\
    \n\t# Old version (RouterOS 6 or older)\r\
    \n\t:if (!([/system health get]~\"(state=disabled|^\\\$)\")) do={\r\
    \n\t\t:local health \"\$[/system health get]\"\r\
    \n\t}\r\
    \n}\r\
    \n\r\
    \n\r\
    \n\r\
    \n# Sends wireless client data to log server \r\
    \n:if (\$Wireless && [:len [/int find where type=wlan]]>0) do={\r\
    \n\t/interface wireless registration-table\r\
    \n\t:foreach i in=[find] do={\r\
    \n\t\t:log info message=\".id=\$i;ap=\$([get \$i ap]);interface=\$([get \$i interface]);mac-address=\$([get \$i mac-address]);signal-strength=\$([get \$i signal-strength]);tx-rate=\$([get \$i tx-rate]);uptime=\$([get \$i uptime]);script=wifi\"\r\
    \n\t}\r\
    \n}\r\
    \n\r\
    \n\r\
    \n# Count IP in address-lists\r\
    \n#----------------------------------\r\
    \n:if (\$AddressLists) do={\r\
    \n\t:local array [ :toarray \"\" ]\r\
    \n\t:local addrcntdyn [:toarray \"\"] \r\
    \n\t:local addrcntstat [:toarray \"\"] \r\
    \n\t:local test\r\
    \n\t:foreach id in=[/ip firewall address-list find] do={\r\
    \n\t\t:local rec [/ip firewall address-list get \$id]\r\
    \n\t\t:local listname (\$rec->\"list\")\r\
    \n\t\t:local listdynamic (\$rec->\"dynamic\")\r\
    \n\t\t:if (!(\$array ~ \$listname)) do={ :set array (\$array , \$listname) }\r\
    \n\t\t:if (\$listdynamic = true) do={\r\
    \n\t\t\t:set (\$addrcntdyn->\$listname) (\$addrcntdyn->\$listname+1)\r\
    \n\t\t} else={\r\
    \n\t\t\t:set (\$addrcntstat->\$listname) (\$addrcntstat->\$listname+1)}\r\
    \n\t}\r\
    \n\t:foreach k in=\$array do={\r\
    \n\t\t:log info message=(\"script=address_lists list=\$k dynamic=\".((\$addrcntdyn->\$k)+0).\" static=\".((\$addrcntstat->\$k)+0))}\r\
    \n}\r\
    \n\r\
    \n\r\
    \n# Get MNDP (CDP) Neighbors\r\
    \n:if (\$Neighbor and \$run) do={\r\
    \n\t:foreach neighborID in=[/ip neighbor find] do={\r\
    \n\t\t:local nb [/ip neighbor get \$neighborID]\r\
    \n\t\t:local id [:pick (\"\$nb\"->\".id\") 1 99]\r\
    \n\t\t:foreach key,value in=\$nb do={\r\
    \n\t\t\t:local newline [:find \$value \"\\n\"]\r\
    \n\t\t\t:if ([\$newline]>0) do={\r\
    \n\t\t\t\t:set value [:pick \$value 0 \$newline]\r\
    \n\t\t\t}\r\
    \n\t\t\t:log info message=\"script=neighbor nid=\$id \$key=\\\"\$value\\\"\"\r\
    \n\t\t}\r\
    \n\t}\r\
    \n}\r\
    \n\r\
    \n\r\
    \n# Collect DHCP Pool information\r\
    \n:if (\$DHCP and \$run) do={\r\
    \n\t/ip pool {\r\
    \n\t\t:local poolname\r\
    \n\t\t:local pooladdresses\r\
    \n\t\t:local poolused\r\
    \n\t\t:local minaddress\r\
    \n\t\t:local maxaddress\r\
    \n\t\t:local findindex\r\
    \n\r\
    \n# Iterate through IP Pools\r\
    \n\t\t:foreach pool in=[find] do={\r\
    \n\t\t\t:set poolname [get \$pool name]\r\
    \n\t\t\t:set pooladdresses 0\r\
    \n\t\t\t:set poolused 0\r\
    \n\r\
    \n# Iterate through current pool's IP ranges\r\
    \n\t\t\t:foreach range in=[:toarray [get \$pool range]] do={\r\
    \n\r\
    \n# Get min and max addresses\r\
    \n\t\t\t\t:set findindex [:find [:tostr \$range] \"-\"]\r\
    \n\t\t\t\t:if ([:len \$findindex] > 0) do={\r\
    \n\t\t\t\t\t:set minaddress [:pick [:tostr \$range] 0 \$findindex]\r\
    \n\t\t\t\t\t:set maxaddress [:pick [:tostr \$range] (\$findindex + 1) [:len [:tostr \$range]]]\r\
    \n\t\t\t\t} else={\r\
    \n\t\t\t\t\t:set minaddress [:tostr \$range]\r\
    \n\t\t\t\t\t:set maxaddress [:tostr \$range]\r\
    \n\t\t\t\t}\r\
    \n\r\
    \n# Calculate number of ip in one range\r\
    \n\t\t\t\t:set pooladdresses (\$maxaddress - \$minaddress)\r\
    \n\r\
    \n# /foreach range\r\
    \n\t\t\t}\r\
    \n\r\
    \n# Test if pools is used in DHCP or VPN and show leases used\r\
    \n\t\t\t:local dname [/ip dhcp-server find where address-pool=\$poolname]\r\
    \n\t\t\t:if ([:len \$dname] = 0) do={\r\
    \n# No DHCP server found, assume VPN\r\
    \n\t\t\t\t:set poolused [:len [used find pool=[:tostr \$poolname]]]\r\
    \n\t\t\t} else={\r\
    \n# DHCP server found, count leases\r\
    \n\t\t\t\t:local dname [/ip dhcp-server get [find where address-pool=\$poolname] name]\r\
    \n\t\t\t\t:set poolused [:len [/ip dhcp-server lease find where server=\$dname]]}\r\
    \n\r\
    \n# Send data\r\
    \n\t\t\t:log info message=(\"script=pool pool=\$poolname used=\$poolused total=\$pooladdresses\")\r\
    \n\r\
    \n# /foreach pool\r\
    \n\t\t}\r\
    \n# /ip pool\r\
    \n\t}\r\
    \n}\r\
    \n\r\
    \n\r\
    \n# Get detailed command history RouterOS >= v7\r\
    \n:if (\$train > 6 and \$CmdHistory) do={\r\
    \n\t:global cmd\r\
    \n\t:local f 0\r\
    \n\t:foreach i in=[/system history find] do={\r\
    \n\t\t:if (\$i = \$cmd) do={ :set f 1 }\r\
    \n\t\t:if (\$f != 1) do={\r\
    \n\t\t\t:log info message=\"StartCMD\"\r\
    \n\t\t\t:log info message=[/system history get \$i]\r\
    \n\t\t\t:log info message=\"EndCMD\"\r\
    \n\t\t}\r\
    \n\t}\r\
    \n\t:global cmd  [:pick [/system history find] 0]\r\
    \n}\r\
    \n\r\
    \n\r\
    \n# Test if CAPsMANN is installed and run script 5.5\r\
    \n:if ( ([:len [/interface find where type=\"cap\"]] > 0) and \$CAPsMANN) do={ \r\
    \n\t/system script run CAPsMANN\r\
    \n}\r\
    \n\r\
    \n\r\
    \n\r\
    \n# Collect routing information\r\
    \n:if (\$Routing) do={\r\
    \n\t/ip route\r\
    \n\t:foreach id in=[find] do={\r\
    \n\t\t:local route \"\$[get \$id]\"\r\
    \n\t\t:set ( \"\$route\"->\"script\" ) \"route\"\r\
    \n\t\t:log info message=\"\$route\"\r\
    \n\t}\r\
    \n}\r\
    \n\r\
    \n:if (\$OSPF) do={\r\
    \n\t/routing ospf neighbor\r\
    \n\t\t:local ospf \"\$[get \$id]\"\r\
    \n\t\t:set ( \"\$ospf\"->\"script\" ) \"ospf\"\r\
    \n\t\t:log info message=\"\$ospf\"\r\
    \n\t}\r\
    \n}\r\
    \n\r\
    \n:if (\$BGP) do={\r\
    \n\t/routing bgp session\r\
    \n\t\t:local bgp \"\$[get \$id]\"\r\
    \n\t\t:set ( \"\$bgp\"->\"script\" ) \"bgp\"\r\
    \n\t\t:log info message=\"\$bgp\"\r\
    \n\t}\r\
    \n}\r\
    \n\r\
    \n\r\
    \n# Collect PPP/IPSEC\r\
    \n:if (\$PPP) do={\r\
    \n\t/ppp active\r\
    \n\t\t:local ppp \"\$[get \$id]\"\r\
    \n\t\t:set ( \"\$ppp\"->\"script\" ) \"ppp\"\r\
    \n\t\t:log info message=\"\$ppp\"\r\
    \n\t}\r\
    \n}\r\
    \n\r\
    \n:if (\$IPSEC) do={\r\
    \n\t/ip ipsec active-peers\r\
    \n\t\t:local ipsec \"\$[get \$id]\"\r\
    \n\t\t:set ( \"\$ipsec\"->\"script\" ) \"ipsec\"\r\
    \n\t\t:log info message=\"\$ipsec\"\r\
    \n\t}\r\
    \n}\r\
    \n\r\
    \n# End Script\r\
    \n\r\
    \n"
/system script add dont-require-permissions=yes name=Netwatch owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="####################################\
    \n# Netwatch script\
    \n#\
    \n# Used as both up and down script\
    \n# Created Jotne 2021 v1.5\
    \n#\
    \n####################################\
    \n/tool netwatch\
    \n:local Comment [get [find where host=\"\$Host\"] comment]\
    \n:local Since [get [find where host=\"\$Host\"] since]\
    \n:log info \"script=netwatch watch_host=\$Host comment=\\\"\$Comment\\\" status=\$Status interval=\$Interval since=\\\"\$Since\\\"\""
/system script add dont-require-permissions=yes name=Netwatch-JRS owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=":local Host \$host\
    \n/tool netwatch\
    \n:local thisBox [/system identity get name];\
    \n:tool e-mail send to=jXXXXX@domain.com subject=\"\$thisBox DOWN to \$Host\" body=( [ :system clock get date ] . \" \" . [ :system clock get time ] . \"\$thisBox DOWN to \$Host\" )\
    \n"
/system script add dont-require-permissions=yes name=Netwatch-JRS-small owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=":local Host \$host\
    \n/tool netwatch\
    \n:log info \"script=Netwatch-JRS-small watch_host=\$Host comment=\\\"\$Comment\\\" status=\$Status interval=\$Interval since=\\\"\$Since\\\"\"\
    \n"
/system script add dont-require-permissions=no name=SystemInfoJRS owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\
    \n\t:log info message=\"free_memory=\$freemem MB total_memory=\$totmem MB free_hdd_space=\$freehddspace MB total_hdd_space=\$totalhddspace MB cpu_load=\$cpuload uptime=\$up write-sect-total=\$sector\"\
    \n\
    \n\
    \n\
    \n:local model na\
    \n\
    \n\t:do {\
    \n\t\t}\
    \n\t} on-error={}\
    \n\t:log info message=\"version=\\\"\$version\\\" board-name=\\\"\$board\\\" model=\\\"\$model\\\" identity=\\\"\$identity\\\"\"\
    \n\
    \n\
    \n# Collect IP addresses\
    \n:foreach neighborID in=[/ip address find] do={\
    \n\t\t:local nb [/ip address get \$neighborID]\
    \n\t\t\t}\
    \n\t\t\t:if (\$key~\"add\") do={\
    \n#\t\t\t:log info message=\"script=IP-ADDRESSES nid=\$id value=\$key=\\\"\$value\\\"\"\
    \n\
    \n\t\t\t:log info message=\"System IP Address \$value\"\
    \n\t\t    }\
    \n\t    }\
    \n}\
    \n\
    \n\
    \n#\t:foreach id in=[/system health find] do={\
    \n#\t\t:local health \"\$[/system health get \$id]\"\
    \n#\t\t:set ( \"\$health\"->\"script\" ) \"health\"\
    \n#\t\t:log info message=\"\$health\"\
    \n#\t}\
    \n\
    \n\
    \n\
    \n\
    \n#\t:foreach neighborID in=[/ip neighbor find] do={\
    \n#\t\t:local nb [/ip neighbor get \$neighborID]\
    \n#\t\t:local id [:pick (\"\$nb\"->\".id\") 1 99]\
    \n#\t\t:foreach key,value in=\$nb do={\
    \n#\t\t\t:local newline [:find \$value \"\\n\"]\
    \n#\t\t\t:if ([\$newline]>0) do={\
    \n#\t\t\t\t:set value [:pick \$value 0 \$newline]\
    \n#\t\t\t}\
    \n#\t\t\t:log info message=\"script=neighbor nid=\$id \$key=\\\"\$value\\\"\"\
    \n#\t\t}\
    \n#\t}\
    \n\
    \n\
    \n\
    \n\
    \n\
    \n"
/system script add dont-require-permissions=no name=UPSonBattery owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\
    \n:local voltage (([/system ups monitor 0 once as-value]->\"line-voltage\")/100)\
    \n:local online ([/system ups monitor 0 once as-value]->\"on-line\")\
    \n\
    \n#:log info \$online\
    \n\
    \n:if (([/system/ups/monitor 0 once as-value]->\"on-line\") = false) do={\
    \n  :log info \"UPS on-line is false; input voltage is \$voltage\"\
    \n}\
    \n\
    \n:if (([/system/ups/monitor 0 once as-value]->\"line-voltage\") < 11500) do={\
    \n  :log info \"UPS input voltage is \$voltage\"\
    \n}\
    \n\
    \n#:log info \"UPS input voltage is \$voltage\"\
    \n\
    \n"
/system script add dont-require-permissions=no name=Linevoltageunder120 owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\
    \n\
    \n\
    \n:if (([/system/ups/monitor 0 once as-value]->\"on-line\") = \"false\") do={\
    \n}\
    \n\
    \n:if (([/system/ups/monitor 0 once as-value]->\"line-voltage\") < 11700) do={\
    \n}\
    \n\
    \n\
    \n"
/system watchdog set auto-send-supout=yes automatic-supout=yes ping-start-after-boot=10m ping-timeout=10m send-email-from=jXXXXX@domain.com send-email-to=jXXXXX@domain.com watch-address=1.1.1.1 watchdog-timer=yes
/tool bandwidth-server set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=100
/tool e-mail set from=jXXXXX@domain.com password=XXXXX port=587 server=smtp.gmail.com tls=starttls user=jXXXXX@domain.com vrf=main
/tool graphing set page-refresh=300 store-every=5min
/tool graphing interface add allow-address=0.0.0.0/0 disabled=no interface=all store-on-disk=yes
/tool graphing interface add allow-address=0.0.0.0/0 disabled=no interface=wireguard1 store-on-disk=yes
/tool graphing interface add allow-address=0.0.0.0/0 disabled=no interface=bridge store-on-disk=yes
/tool graphing queue add allow-address=0.0.0.0/0 allow-target=yes disabled=no simple-queue=all store-on-disk=yes
/tool graphing resource add allow-address=0.0.0.0/0 disabled=no store-on-disk=yes
/tool mac-server set allowed-interface-list=ALL
/tool mac-server mac-winbox set allowed-interface-list=ALL
/tool mac-server ping set enabled=yes
/tool netwatch add comment=Netwatch-1.1.1.1 disabled=no down-script=Netwatch host=1.1.1.1 http-codes="" interval=2m name=Netwatch-1.1.1.1 test-script="" type=simple up-script=Netwatch
/tool netwatch add comment=Netwatch-9.9.9.9 disabled=no down-script=Netwatch-JRS-small host=9.9.9.9 http-codes="" interval=2m name=9.9.9.9 test-script="" type=simple up-script=Netwatch-JRS-small
/tool romon set enabled=yes id=00:00:00:00:00:00 secrets=""
/tool romon port set [ find default=yes ] cost=100 disabled=no forbid=no interface=all secrets=""
/tool sms set allowed-number="" channel=0 polling=no port=none receive-enabled=no secret="" sim-pin="" sms-storage=sim
/tool sniffer set file-limit=1000KiB file-name="" filter-cpu="" filter-direction=any filter-dst-ip-address="" filter-dst-ipv6-address="" filter-dst-mac-address="" filter-dst-port="" filter-interface="" filter-ip-address="" filter-ip-protocol="" filter-ipv6-address="" filter-mac-address="" filter-mac-protocol="" filter-operator-between-entries=or filter-port="" filter-size="" filter-src-ip-address="" filter-src-ipv6-address="" filter-src-mac-address="" filter-src-port="" filter-stream=no filter-vlan="" memory-limit=100KiB memory-scroll=yes only-headers=no quick-rows=20 quick-show-frame=no streaming-enabled=no streaming-server=0.0.0.0:37008
/tool traffic-generator set latency-distribution-max=100us measure-out-of-order=no stats-samples-to-keep=100 test-id=0
/user aaa set accounting=yes default-group=read exclude-groups="" interim-update=0s use-radius=no
/user settings set minimum-categories=0 minimum-password-length=0
@Josephny
If you remove the double quote from the end of this line:
/interface wireguard add disabled=no listen-port=51880 mtu=1420 name=wireguard1 private-key=XXXXXUdzhtaQWe9tDnPmv94g/QtGM="
the board parser will render better your config.
Done.
Thank you.
Why did you use verbose? Cant read a damn thing LOL…
By the way what is the purpose of sending a config with red lines,
rule 1 complete config
rule2 no red lines LOL
Here is it not verbose.
As for the red, I don’t see any, but if you do you might consider calling a professional :slight_smile:
# 2025-02-10 12:40:06 by RouterOS 7.17.2
# software id = ILCG-6S0L
# model = C53UiG+5HPaxD2HPaxD
# serial number = HGJ0
add admin-mac=D4:01:C3:C0:82:CF auto-mac=no comment=defconf name=bridge \
    port-cost-mode=short
set [ find default-name=ether1 ] poe-out=off
/interface wifi
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=\
    disabled .width=20/40/80mhz configuration.country="United States" .mode=\
    ap .ssid=729-5ghz disabled=no security.authentication-types=wpa2-psk \
    .disable-pmkid=yes .management-protection=disabled .passphrase=blueberry1 \
    steering.rrm=no .wnm=no
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=\
    disabled .width=20mhz configuration.country="United States" .mode=ap \
    .ssid=729-2ghz disabled=no security.authentication-types=wpa2-psk \
add listen-port=51880 mtu=1420 name=wireguard1 private-key=\
    "8B9R3ouerT9MeNi2WPjUdzhtaQWe9tDnPmv94g/QtGM="
/interface wifi
add configuration.country="United States" .mode=ap .ssid=2point4 \
    datapath.client-isolation=yes disabled=no mac-address=D6:01:C3:C0:82:D3 \
    master-interface=wifi2 name=2point4 security.authentication-types=\
    wpa2-psk .disable-pmkid=yes .management-protection=disabled .passphrase=\
    XXXXX
add configuration.mode=ap .ssid=Guest mac-address=D6:01:C3:C0:82:D6 \
    master-interface=wifi1 name=Guest-wifi1 security.authentication-types=\
    wpa2-psk .passphrase=XXXXX
add configuration.mode=ap .ssid=Guest mac-address=D6:01:C3:C0:82:D7 \
    master-interface=wifi2 name=Guest-wifi2 security.authentication-types=\
add comment=defconf name=WAN
add comment=defconf name=LAN
add include=LAN,WAN name=ALL
add name=TRUSTED
add name=DHCPdisabled
/interface wifi configuration
add datapath.client-isolation=yes disabled=no name=guestcfg \
    security.authentication-types=wpa2-psk .passphrase=blueberry ssid=\
    GuestWifi
/interface wifi
add configuration=guestcfg configuration.mode=ap disabled=no mac-address=\
    D6:01:C3:C0:82:D4 master-interface=wifi2 name=Guest2g \
    D6:01:C3:C0:82:D5 master-interface=wifi1 name=Guest5g
add name=default-dhcp ranges=192.168.80.100-192.168.80.200
add name=pool-guest ranges=10.0.0.10-10.0.0.252
add address-pool=pool-guest interface=Guest2g lease-time=6h name=dhcp-guest2g
add address-pool=pool-guest interface=Guest5g lease-time=6h name=dhcp-guest5g
add address-pool=default-dhcp interface=bridge lease-script="\r\
    \n\r\
    \n/system\r\
    \n:local cdate [clock get date] \r\
    \n:local yyyy  [:pick \$cdate 0  4]\r\
    \n:local MM    [:pick \$cdate 5  7]\r\
    \n:local dd    [:pick \$cdate 8 10]\r\
    \n\r\
    \n:local thistime [/system clock get time]\r\
    \n:local thishour [:pick \$thistime 0 2]\r\
    \n:local thisminute [:pick \$thistime 3 5]\r\
    \n:local thissecond [:pick \$thistime 6 8]\r\
    \n:local identitydatetime \"\$[identity get name]_\$yyyy-\$MM-\$dd_\$thish\
    our:\$thisminute:\$thissecond\"\r\
    \n:local datetime \"\$yyyy-\$MM-\$dd_\$thishour:\$thisminute:\$thissecond\
    \"\r\
    \n:local systemname \"\$[identity get name]\"\r\
    \n\r\
    \n:if (\$leaseBound=1) do={\r\
    \n\r\
    \n#  :log info \"testing after condition BOUND\" }\r\
    \n\r\
    \n}\r\
    \n\r\
    \n:if  ([/ip dhcp-server lease find where dynamic mac-address=\$leaseActMA\
    C]!=\"\") do={\r\
    \n\r\
    \n#  :log info \"testing after condition DYNAMIC\"}\r\
    \n\r\
    \n}\r\
    \n\r\
    \n:local recipient \"jXXXXX@domain.com\"\r\
    \n\r\
    \n:if  ((\$leaseBound=1)  && ([/ip dhcp-server lease find where dynamic ma\
    c-address=\$leaseActMAC]!=\"\")) do={\r\
    \n\r\
    \n    :log info \"testing after conditions BOUND and DYNAMIC\" \r\
    \n\r\
    \n    :tool e-mail send to=\$recipient subject=\"\$systemname DHCP Lease A\
    ssigned to \$leaseActMAC\" body=\"MAC address \$leaseActMAC received IP ad\
    dress \$leaseActIP with a hostname of \$[/ip/dhcp-server/lease/get value-n\
    ame=host-name [find where mac-address=\$leaseActMAC]] from DHCP Server \$l\
    easeServerName on \$datetime from \$systemname\"\r\
    \n\r\
    \n    :log info \"Sent DHCP alert for MAC \$leaseActMAC\"\r\
    \n\r\
    \n}\r\
    \n\r\
    \n" lease-time=2d name=defconf
/system logging action
set 3 remote=192.168.0.13
add name=logserver remote=192.168.0.112 remote-port=51400 target=remote
add bridge=bridge comment=defconf interface=ether2 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=ether3 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=ether5 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=wifi1 internal-path-cost=10 \
    path-cost=10
add bridge=bridge interface=*B internal-path-cost=10 path-cost=10
add bridge=bridge interface=2point4 internal-path-cost=10 path-cost=10
add bridge=bridge interface=wifi2 internal-path-cost=10 path-cost=10
add bridge=bridge interface=*C internal-path-cost=10 path-cost=10
set udp-timeout=10s
/ipv6 settings
set disable-ipv6=yes forward=no
add interface=bridge list=TRUSTED
add interface=ether1 list=TRUSTED
add interface=wifi1 list=TRUSTED
add mac-address=FE:16:FA:03:F9:65 name=ovpn-server1
add allowed-address=10.10.90.0/24,192.168.88.0/24 comment=\
    "WG client on BI PC" interface=wireguard1 name=peer9 public-key=\
    "R5SjZucQPhyu5CQyXLvxf/RFr9FogUr5iBSC0jt9TV4="
add allowed-address=10.10.100.8/32 comment=Laptop interface=wireguard1 name=\
    peer10 public-key=XXXXXorKJBrljQqFSxc="
add allowed-address=10.10.100.50/32,192.168.0.0/24,192.168.5.0/24 comment=\
    "355 hEX being UDM" endpoint-address=XXXXX.dyndns.org endpoint-port=\
    51833 interface=wireguard1 name=355 persistent-keepalive=40s public-key=\
    "Q8CPJm+/UBOSQy1AjNPOBDFxZmbbJrycOWg5omLZq3g="
add allowed-address=10.10.100.60/32,192.168.1.0/24 comment=\
    "255 Hex behind UDM" endpoint-address=XXXXX.dyndns.org \
    endpoint-port=51835 interface=wireguard1 name=255 persistent-keepalive=\
    40s public-key=XXXXXzZ0aWPK0PMwbRc="
add allowed-address=10.10.100.2/32,192.168.40.0/24 comment=371 \
    endpoint-address=XXXXX.dyndns.org endpoint-port=52820 interface=wireguard1 \
    name=371 persistent-keepalive=40s public-key=\
    "zoZtiesrYWKeodSUVuivHBEBjCn9YLAxn4pMzU5lohI="
add allowed-address=192.168.30.0/24,10.10.100.30/32 comment=76 \
    endpoint-address=XXXXX.dyndns.org endpoint-port=51830 interface=\
    wireguard1 name=76 persistent-keepalive=40s public-key=\
    "EJu69lCmgQUBsiVng8xWu3x2t1k0omNOLVY6scNgUic="
add allowed-address=10.10.100.70/32,192.168.70.0/24 comment=125 \
    endpoint-address=XXXXX.dyndns.org endpoint-port=51870 interface=\
    wireguard1 name=125 persistent-keepalive=40s public-key=\
    "Otp5S5pvkk1i1souKLXctvG3PEr6Rk4GF8HbwayGqT8="
add allowed-address=10.10.100.1/24,192.168.2.0/24 comment=212 \
    endpoint-address=XXXXX.dyndns.org endpoint-port=51820 interface=\
    wireguard1 name=212 persistent-keepalive=40s public-key=\
    "xx27cpfZFjhs2emAFLH7btR1YlEYPUo/op1OqXrW4Ds="
add address=10.10.100.80/24 interface=wireguard1 network=10.10.100.0
add address=192.168.80.1/24 interface=bridge network=192.168.80.0
add address=10.0.0.1/24 interface=Guest2g network=10.0.0.0
add address=10.0.0.1/24 interface=Guest5g network=10.0.0.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=1h
/ip dhcp-client
add address=10.0.0.0/24 dns-server=9.9.9.9,1.1.1.1,8.8.8.8 gateway=10.0.0.1
add address=192.168.80.0/24 comment=defconf dns-server=192.168.80.1 gateway=\
    192.168.80.1
set allow-remote-requests=yes servers=9.9.9.9,8.8.8.8,1.1.1.1,8.8.4.4
/ip dns static
add address=10.10.100.80 comment=defconf name=729-10.10.100.80.local type=A
add address=192.168.80.1 comment=defconf name=729.local type=A
add address=10.0.0.1 comment=defconf name=729.router.lan type=A
add address=XXXXX.dyndns.org list=XXXXX
add address=XXXXX.dyndns.org list=212
add address=IP-local-admin-destkop list=authorized
add address=IP-local-admin-laptop list=authorized
add address=<thislocation>.dyndns.org list=dynamic-WANIP
add address=192.168.0.0/16 list=admin
add address=10.10.100.0/24 list=admin
add address=10.0.0.2-10.0.0.254 list="Guest WiFi"
    established,related,untracked
    invalid
    "defconf: accept to local loopback (for CAPsMAN)" disabled=yes \
add action=accept chain=input comment="Allow WG Handshake" dst-address=\
    0.0.0.0 dst-port=51880 protocol=udp
add action=accept chain=input comment="allow 67 68 to 10.0.0.1" dst-address=\
    10.0.0.1 dst-port=67,68 log=yes log-prefix="allow 67 68 to 10.0.0.1" \
    protocol=udp
add action=drop chain=input comment="drop all to 10.0.0.1" dst-address=\
    10.0.0.1 in-interface=!lo log=yes log-prefix="drop all to 10.0.0.1"
add action=accept chain=input comment="Allow GRE for EoIP" protocol=gre
add action=accept chain=input comment="Alow wireguard to router" \
add action=accept chain=input comment="Allow all from LAN ifaces (bridge)" \
    in-interface-list=LAN
add action=accept chain=input src-address-list=admin
add action=accept chain=forward comment="Allow WG to subnet" disabled=yes \
add action=drop chain=forward comment="drop all 10.0.0.0/24 to not-WAN" \
    log-prefix=drop-all-10-0-0-0-24-to-not-WAN out-interface-list=!WAN \
    src-address=10.0.0.0/24
add action=drop chain=forward comment="drop guest to 192.168.0.0/16" \
    dst-address=192.168.0.0/16 dst-port=!53,68,68 log=yes log-prefix=\
    drop-guest-to-192-168-0-0-16 protocol=udp src-address-list="Guest WiFi"
add action=accept chain=forward disabled=yes in-interface=wireguard1 \
    protocol=udp
add action=accept chain=forward comment="allow port forwarding" \
    connection-nat-state=dstnat
add action=accept chain=forward comment="Allow wireguard to subnet" disabled=\
add action=accept chain=forward comment="Allow wireguard to subnet" \
add action=accept chain=forward comment="Allow subnet to enter WG" \
    out-interface=wireguard1
    connection-state=invalid
add action=dst-nat chain=dstnat disabled=yes dst-port=80 log=yes protocol=tcp \
add action=src-nat chain=srcnat disabled=yes dst-address=192.168.4.0/24 log=\
/ip hotspot profile
/ip ipsec profile
/ip kid-control
add fri=0s-1d mon=0s-1d name=Monitor sat=0s-1d sun=0s-1d thu=0s-1d tue=0s-1d \
    wed=0s-1d
add disabled=no dst-address=192.168.88.0/24 gateway=wireguard1 routing-table=\
add disabled=no dst-address=192.168.2.0/24 gateway=wireguard1 routing-table=\
add disabled=no dst-address=192.168.0.0/24 gateway=wireguard1 routing-table=\
add disabled=no dst-address=192.168.40.0/24 gateway=wireguard1 routing-table=\
add disabled=no dst-address=192.168.70.0/24 gateway=wireguard1 routing-table=\
add disabled=no dst-address=192.168.1.0/24 gateway=wireguard1 routing-table=\
add disabled=no dst-address=192.168.20.0/24 gateway=wireguard1 routing-table=\
add disabled=no dst-address=192.168.30.0/24 gateway=wireguard1 routing-table=\
/ip service
set www-ssl disabled=no
/ip smb shares
/ip ssh
set forwarding-enabled=both
/snmp
set enabled=yes trap-version=2
/system clock
set time-zone-name=America/New_York
/system identity
set name=729hAPax3
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system scheduler
add disabled=yes interval=1d name=dyndns on-event=dyndns policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
add disabled=yes interval=10m name=WG-iface-restart on-event=WG-iface-restart \
    policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
add interval=3d name=export-download on-event=export-download policy=\
add disabled=yes interval=5d name=iplist on-event=IPlist policy=\
add interval=2w name=dynamic-data-rextended on-event=dynamic-data-rextended \
add interval=2w name=dhcpleasesftp on-event=dhcpleasesftp policy=\
add interval=1d name=DynDNS on-event=DynDNS policy=\
add disabled=yes interval=5m name=Data_to_Splunk on-event=\
    Data_to_Splunk_using_Syslog policy=\
add name=SystemInfoJRS on-event=\
    ":delay 60s\
    \n/system script run SystemInfoJRS" policy=\
    start-time=startup
add interval=12h name=UPSonBattery on-event=UPSonBattery policy=\
add disabled=yes interval=10s name=Linevoltageunder120 on-event=\
    Linevoltageunder120 policy=\
/system script
add dont-require-permissions=no name=export-download owner=admin policy=\
    \r\
    \n\r\
    \n/system\r\
    \n\r\
    \n/tool fetch upload=yes mode=ftp ascii=no src-path=\"/\$[\$identitydate].\
    rsc\" dst-path=\"/mikrotik-backups/\$[\$identitydate].rsc\" address=192.16\
    \n\r\
    \n\r\
add dont-require-permissions=no name=WG-iface-restart owner=admin policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=":\
    foreach i in=[/interface/wireguard/peers/find where disabled=no endpoint-a\
    \n  :local LastHandshake [/interface/wireguard/peers/get \$i last-handshak\
    e]\r\
    \"5m\"])) do={\r\
    \n   \r\
    \n     :log info \"WG-iface-restart script found WG peers with last handsh\
    ake greater than 5 minutes; then reset the endpoint-address to reload dns \
    of endpoint\"\r\
    \n\r\
    \n    /interface/wireguard/peers/set \$i endpoint-address=[/interface/wire\
    \n\r\
    \r\
    \n   :log info \"WG-iface-restart script found WG peer with last handshake\
    \_greater than 5 minutes; then reset the endpoint-address to reload dns of\
    \_endpoint:  \$endpoint\"\r\
    \n\r\
    \n  }\r\
    \n}\r\
    \n"
add dont-require-permissions=no name=IPlist owner=admin policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="#\
    \_Export public IP and mail it\r\
    \n\r\
    \n\r\
    \n/tool fetch upload=yes mode=ftp ascii=no src-path=\"729-IP-\$[\$nowdate]\
    .txt\" dst-path=\"/mikrotik-backups/729-IP-\$[\$nowdate].txt\" address=192\
    \n\r\
add dont-require-permissions=no name=Get_Date-Time owner=admin policy=\
    \n    /system clock\r\
    \n        :set M     ([:find \"xxanebarprayunulugepctovecANEBARPRAYUNULUGE\
    \n    }\r\
    \n}\r\
    \n\r\
add dont-require-permissions=yes name=Get_Date-Time_2 owner=admin policy=\
    \n    /system clock\r\
    \n    }\r\
    \n\r\
    \n}\r\
    \n\r\
    \n\r\
    \n:put [\$yyyy]\r\
    \n\r\
    \n"
add comment=test dont-require-permissions=yes name=test owner=admin policy=\
    \r\
    \n\r\
    \n/system\r\
    \n\r\
    \n:log info \"script=netwatch watch_host=\$Host comment=\\\"\$Comment\\\" \
    \n\r\
    \n:tool e-mail send to=jXXXXX@domain.com subject=\"\$identity \$Statu\
add dont-require-permissions=no name=script1 owner=admin policy=\
    local arrMonths {jan=\"01\";feb=\"02\";mar=\"03\";apr=\"04\";may=\"05\";ju\
    n=\"06\";jul=\"07\";aug=\"08\";sep=\"09\";oct=\"10\";nov=\"11\";dec=\"12\"\
    }\r\
    \n:local dateinside \"\$[:pick \$today 7 11]-\$(\$arrMonths->[:pick \$toda\
    \n:local backupfile \"\$[/system identity get name]_\$dateinside_\$[/syste\
add dont-require-permissions=no name=script2 owner=admin policy=\
    \n\r\
    \n    /system clock\r\
    \n    }\r\
    \n\r\
    \n}\r\
    \n\r\
    \n\r\
    \n\r\
    \n#:tool e-mail send to=jXXXXX@domain.com subject=\"\$thisBox UP\" bo\
    \n\r\
    \n:tool e-mail send to=jXXXXX@domain.com subject=\"\$thisBox UP\" bod\
add dont-require-permissions=no name=dynamic-data-rextended owner=admin \
    source="/system\r\
    \n:local stringexec   \"/system iden print; :put \\\"\\\\r\\\\n\\\"; /ip c\
    \n\r\
    \n    :set stringexec \"\$stringexec; :put \\\"\\\\r\\\\n\\\" /int wifiwav\
    e2 reg pri det\"\r\
    \n} \r\
    \n\r\
    \n    :set stringexec \"\$stringexec; :put \\\"\\\\r\\\\n\\\" /int wireles\
    s reg pri det\"\r\
    \n}\r\
    \n\r\
    \n\r\
    \n:delay 1s\r\
    \n:delay 2s\r\
    \n\r\
    \n/tool fetch upload=yes mode=ftp ascii=no address=192.168.2.22 port=21 us\
    \n    src-path=tmpresults.txt dst-path=\"/mikrotik-backups/\$identitydate-\
    \n\r\
add dont-require-permissions=no name=DHCP_to_DNS owner=admin policy=\
    \_SPDX-License-Identifier: CC0-1.0\
    \n\r\
    \n\r\r\r\r\
    \n\r\
    \n\r\
    \n\r\
    \n\r\r\
    \n\r\
    \n\r\
    \n\r\
    \n\r\r\
    \n\r\
    \n\r\
    \n\r\r  :local hostname [/ip dhcp-server lease get value-name=host-name \$\
    lease]\
    \n\r\
    \n\r\r  :local hostaddr [/ip dhcp-server lease get value-name=address \$le\
    ase]\
    \n\r\
    \n\r\r\
    \n\r\
    \n\r\
    \n\r\
    \n\r\
    \n\r\
    \n\r\r\
    \n\r\
    \n\r\r      :if ([:len [/ip dns static find where name=\$regdomain]] = 0) \
    do={\
    \n\r\
    \n\r\r        /ip dns static add name=\$regdomain address=\$hostaddr comme\
    \n\r\
    \n\r\r      } else={\
    \n\r\
    \n\r\r        :if ([:len [/ip dns static find where name=\$regdomain comme\
    \n\r\
    \n\r\r          /ip dns static set address=\$hostaddr [/ip dns static find\
    \_name=\$regdomain comment=\$magiccomment]\
    \n\r\
    \n\r\r        }\
    \n\r\
    \n\r\r      }\
    \n\r\
    \n\r\r    }\
    \n\r\
    \n\r\r  }\
    \n\r\
    \n\r\r}\
    \n\r\
    \n\r\r\
    \n\r\
    \n\r\r:foreach dnsentry in [/ip dns static find where comment=\$magiccomme\
    nt] do={\
    \n\r\
    \n\r\
    \n\r\
    \n\r\
    \n\r\r  }\
    \n\r\
    \n\r\r}\
    \n\r\
    \n\r\r"
add dont-require-permissions=no name=dhcpleasesftp owner=admin policy=\
    \r\
    \n\r\
    \n/system\r\
    \n\r\
    \n\r\
    \n:local stringexec \"/ip dhcp-server lease; :foreach i in=[find] do={ :pu\
    t ([get \\\$i address].\\\",\\\".[get \\\$i comment].\\\",\\\",[get \\\$i \
    \n\r\
    \n\r\
    \n\r\
    \n:delay 60\r\
    \n\r\
    \n/tool fetch address=192.168.2.22 port=21 user=mikrotik password=XXXXX\
    \_src-path=temp3.txt mode=ftp dst-path=\"/mikrotik-backups/\$identitydate-\
    \n\r\
    \n\r\
    \n\r\
    \n\r\
    \n"
add dont-require-permissions=no name=DynDNS owner=admin policy=\
    \n/system\
    \n\
    \n\
    \n\
    \n#/tool fetch upload=yes mode=ftp ascii=no src-path=\"\$[\$identitydate]-\
    IP.txt\" dst-path=\"/mikrotik-backups/\$[\$identitydate]-IP.txt\" address=\
    \n\
    \n\
    \n\t:local hostname \"<thislocation>.dyndns.org\"\
    \n\
    \n\
    \n\t/tool fetch mode=http address=\"checkip.dyndns.org\" src-path=\"/\" ds\
    \n\t:delay 1\
    \n\
    \n\
    \n# Remove the # on next line to force an update every single time - usefu\
    l for debugging,\
    \n\
    \n\
    \n# more dyndns updater request details https://help.dyn.com/remote-access\
    \n\t:if (\$dyndnsForce = true) do={ :log warning \"UpdateDynDNS: Forced up\
    date on\" }\
    \n\
    \n\
    \n\t\turl=\"https://\$username:\$clientkey XXXXXg/v3/update\?h\
    \n\
    \n\t\t:delay 1\
    \n\
    \n                                           /ip/address print file=\"\$id\
    entitydate-IP\"\
    \n\
    \n                                           /tool fetch upload=yes mode=f\
    tp ascii=no src-path=\"\$[\$identitydate]-IP.txt\" dst-path=\"/mikrotik-ba\
    ckups/\$[\$identitydate]-IP.txt\" address=192.168.2.22 port=21 user=mikrot\
    ik password=XXXXX\
    \n\
    \n                                          /file remove \"\$identitydate-\
    IP.txt\"\
    \n\
    \n\
    \n\t} else={\
    \n\t}\
    \n\
    \n"
add dont-require-permissions=no name=Data_to_Splunk_using_Syslog owner=admin \
    \n# Jotne 2024\r\
    \n\r\
    \n# The update is disabled by default.  Remove the # from the two next lin\
    e to use it.\r\
    \n\r\
    \n#/system/logging/action/set [find where name=\"logserver\"] remote=\$myS\
    yslog\r\
    \n\r\
    \n\r\
    \n\r\
    \n\r\
    \n\r\
    \n# Get RouterOS main version (used to run different script on different v\
    ersion)\r\
    \n\r\
    \n\t:log info message=\"script=resource free_memory=\$freemem MB total_mem\
    ory=\$totmem MB free_hdd_space=\$freehddspace MB total_hdd_space=\$totalhd\
    \n}\r\
    \n\r\
    \n\r\
    \n:global Hour\r\
    \n}\r\
    \n\r\
    \n\r\
    \n:if ([:len [/system package find where !disabled and name=ntp]] > 0 or [\
    \n} else={\r\
    \n    :if ([:typeof [/system ntp client get last-update-from]] = \"nil\") \
    do={\r\
    \n    } else={\r\
    \n    }\r\
    \n}\r\
    \n\r\
    \n\r\
    \r\
    \n\t}\r\
    \n}\r\
    \n\r\
    \n\r\
    \n\t}\r\
    \n}\r\
    \n\r\
    \n\r\
    \n\t:foreach logline in=[/ip firewall nat find where dynamic=yes and comme\
    \r\
    \n\t}\r\
    \n}\r\
    \n\r\
    \n\r\
    \n# Collect system information 5.5 added ID for non routerBoard 5.6 Remvoe\
    d serial\r\
    \n\t:do {\r\
    \n\t\t}\r\
    \n\t:log info message=\"script=sysinfo version=\\\"\$version\\\" board-nam\
    e=\\\"\$board\\\" model=\\\"\$model\\\" identity=\\\"\$identity\\\" factor\
    y-firmware=\\\"\$ffirmware\\\" current-firmware=\\\"\$cfirmware\\\" upgrad\
    \n}\r\
    \n\r\
    \n\r\
    \n\t}\r\
    \n} else={\r\
    \n\t}\r\
    \n}\r\
    \n\r\
    \n\r\
    \n\r\
    \n\t\t:log info message=\".id=\$i;ap=\$([get \$i ap]);interface=\$([get \$\
    i interface]);mac-address=\$([get \$i mac-address]);signal-strength=\$([ge\
    t \$i signal-strength]);tx-rate=\$([get \$i tx-rate]);uptime=\$([get \$i u\
    \n\t}\r\
    \n}\r\
    \n\r\
    \n\r\
    \n\t:local test\r\
    \n\t\t:if (!(\$array ~ \$listname)) do={ :set array (\$array , \$listname)\
    \_}\r\
    \n\t\t} else={\r\
    \n\t}\r\
    \n\t\t:log info message=(\"script=address_lists list=\$k dynamic=\".((\$ad\
    \n}\r\
    \n\r\
    \n\r\
    \n\t\t\t}\r\
    \"\r\
    \n\t\t}\r\
    \n\t}\r\
    \n}\r\
    \n\r\
    \n\r\
    \n\t/ip pool {\r\
    \n\r\
    \n\r\
    \n\r\
    \n\t\t\t\t\t:set maxaddress [:pick [:tostr \$range] (\$findindex + 1) [:le\
    \n\t\t\t\t}\r\
    \n\r\
    \n\r\
    \n\t\t\t}\r\
    \n\r\
    \r\
    \n\t\t\t} else={\r\
    \n\t\t\t\t:local dname [/ip dhcp-server get [find where address-pool=\$poo\
    lname] name]\r\
    \n\t\t\t\t:set poolused [:len [/ip dhcp-server lease find where server=\$d\
    name]]}\r\
    \n\r\
    \n# Send data\r\
    \n\t\t\t:log info message=(\"script=pool pool=\$poolname used=\$poolused t\
    \n\r\
    \n\t\t}\r\
    \n# /ip pool\r\
    \n\t}\r\
    \n}\r\
    \n\r\
    \n\r\
    \n\t:global cmd\r\
    \n\t:local f 0\r\
    \n\t\t}\r\
    \n\t}\r\
    \n}\r\
    \n\r\
    \n\r\
    \n:if ( ([:len [/interface find where type=\"cap\"]] > 0) and \$CAPsMANN) \
    do={ \r\
    \n}\r\
    \n\r\
    \n\r\
    \n\r\
    \n\t/ip route\r\
    \n\t}\r\
    \n}\r\
    \n\r\
    \n\t}\r\
    \n}\r\
    \n\r\
    \n\t}\r\
    \n}\r\
    \n\r\
    \n\r\
    \n\t/ppp active\r\
    \n\t}\r\
    \n}\r\
    \n\r\
    \n\t}\r\
    \n}\r\
    \n\r\
    \n# End Script\r\
    \n\r\
    \n"
add dont-require-permissions=yes name=Netwatch owner=admin policy=\
    \n#\
    \n#\
    \n/tool netwatch\
add dont-require-permissions=yes name=Netwatch-JRS owner=admin policy=\
    local Host \$host\
    \n/tool netwatch\
    \$Host\" body=( [ :system clock get date ] . \" \" . [ :system clock get t\
    \n"
add dont-require-permissions=yes name=Netwatch-JRS-small owner=admin policy=\
    local Host \$host\
    \n/tool netwatch\
    \n:log info \"script=Netwatch-JRS-small watch_host=\$Host comment=\\\"\$Co\
    \n"
add dont-require-permissions=no name=SystemInfoJRS owner=admin policy=\
    \n\t:log info message=\"free_memory=\$freemem MB total_memory=\$totmem MB \
    free_hdd_space=\$freehddspace MB total_hdd_space=\$totalhddspace MB cpu_lo\
    \n\
    \n\
    \n\
    d serial\
    \n:local model na\
    \n\
    \n\t:do {\
    \n\t\t}\
    \n\t} on-error={}\
    \n\
    \n\
    \n\t\t\t}\
    \$value\\\"\"\
    \n\
    \n\t\t    }\
    \n\t    }\
    \n}\
    \n\
    \n\
    \n#\t}\
    \n\
    \n\
    \n\
    \n\
    \n#\t\t\t}\
    \n#\t\t}\
    \n#\t}\
    \n\
    \n\
    \n\
    \n\
    \n\
    \n"
add dont-require-permissions=no name=UPSonBattery owner=admin policy=\
    \n:local voltage (([/system ups monitor 0 once as-value]->\"line-voltage\"\
    )/100)\
    \n\
    \n\
    \n}\
    \n\
    \n:if (([/system/ups/monitor 0 once as-value]->\"line-voltage\") < 11500) \
    do={\
    \n}\
    \n\
    \n\
    \n"
add dont-require-permissions=no name=Linevoltageunder120 owner=admin policy=\
    )/100)\
    \n\
    \n\
    \n:if (([/system/ups/monitor 0 once as-value]->\"on-line\") = \"false\") d\
    o={\
    \n}\
    \n\
    \n:if (([/system/ups/monitor 0 once as-value]->\"line-voltage\") < 11700) \
    do={\
    \n}\
    \n\
    \n\
    \n"
/system watchdog
set auto-send-supout=yes ping-start-after-boot=10m ping-timeout=10m \
    send-email-from=jXXXXX@domain.com send-email-to=\
/tool e-mail
set from=jXXXXX@domain.com password=XXXXX port=587 server=\
add
add interface=wireguard1
add
add
/tool mac-server
/tool netwatch
add comment=Netwatch-1.1.1.1 disabled=no down-script=Netwatch host=1.1.1.1 \
    http-codes="" interval=2m name=Netwatch-1.1.1.1 test-script="" type=\
add comment=Netwatch-9.9.9.9 disabled=no down-script=Netwatch-JRS-small host=\
    9.9.9.9 http-codes="" interval=2m name=9.9.9.9 test-script="" type=simple \
/tool romon
set enabled=yes
Interface not running
disabled
PPTP connections are considered unsafe, it is suggested to use a more modern VPN protocol instead
& Co. are present on new version export
Graphing causes the internal NAND/flash to wear out unnecessarily.
add
add
add
Does my export include:
Should I remove the following commands because I don't use LTE, OVPN-SERVER, or PPTP-SERVER:
/interface lte settings set esim-channel=auto firmware-path=firmware mode=auto
/interface ovpn-server server add auth=sha1,md5,sha256,sha512 certificate=*0 cipher=blowfish128,aes128-cbc default-profile=default disabled=yes enable-tun-ipv6=no ipv6-prefix-len=64 keepalive-timeout=60 mac-address=FE:16:FA:03:F9:65 max-mtu=1500 mode=ip name=ovpn-server1 netmask=24 port=1194 protocol=tcp push-routes="" redirect-gateway=disabled reneg-sec=3600 require-client-certificate=no tls-version=any tun-server-ipv6=:: user-auth-method=pap vrf=main
/interface pptp-server server
# PPTP connections are considered unsafe, it is suggested to use a more modern VPN protocol instead
set authentication=mschap1,mschap2 default-profile=default-encryption enabled=no keepalive-timeout=30 max-mru=1450 max-mtu=1450 mrru=disabled
just a peek here and there…
unused entries (deleted) still exist on bridge ports
Seriously???
/ip ssh
Uhm…
Security breach…
/tool mac-server
Got it -- the *B and *C are wifi interfaces that I recently disabled.
Any harm is leaving them on the bridge/port in case I want to enable them?
Seriously???
Hmmm... even I have a good idea why this is wrong.
/ip ssh
Uhm....
I don't know what is wrong with this.
I can sense that there is something not right, but I don't full know.
Is the problem that "ALL" is more than just LAN and WAN?
Security breach...
/tool mac-server
If I have the interface-list TRUSTED as including interfaces bridge, wifi1, and should I make I set the mac-server and mac-winbox allowed interface list to TRUSTED?
I also want to be able access via wireguard
Like this:
add interface=wifi2 list=TRUSTED
add interface=wireguard1 list=TRUSTED
/tool mac-server
set allowed-interface-list=TRUSTED
leave it only on one interface, like ether5 and use ether5 just for admin access, removing it from any bridge or other functions
delete ether5 from bridge ports
add name=MGMT
add interface=ether5 list=MGMT
/tool mac-server
set allowed-interface-list=MGMT
Better have management access with MAC telnet/MAC winbox if something go wrong with IPs, firewall rules (or VLAN) etc…
I believe we are referring to the mac-server and mac-winbox allowed-interface-list, right?
I need access from a remote location.
Use “VPN” & IP access…
(expanded reply on previous post)
Wait @anav for further help
Yes, but only mac-winbox server use trusted, plain mac-server is not encryped and should be set to NONE.
Of course since your bridge is part of TRUSTED
and wireguard is part of TRUSTED
then you are good to go.
I belive the bridge is your main subnet, and if so why are you detailing wifi1 and wifi2 separately… ???
Okay, great point about bridge ports already including wifi1 and wifi2, so no need to explicity include those ports in the interface-list.
I removed from interface-list.
“plain mac-server” is Telnet Mac-Server in Winbox, right?
I set to NONE.
