The setup is as follows, Windows physical NIC : public IP 23.23.23.90 / gateway: 23.23.23.1 .
Went on and connected CHR’s ethernet 1 to Vmware’s : Network connection: Bridged (Automatic) and powered on the CHR, went to IP/address and gave 23.23.23.91/24 (assigned to me by the provider, have 6 in total) and in IP/routes dst. Address = 0.0.0.0 , gateway 23.23.23.1
The CHR, as expected has access to Internet and can be ping-ed from the Internet.
What would be a good set of firewall rules to secure it from attacks since there is no NAT (nor ISP modem or other firewall) involved while allowing at the same time L2TP/IPsec connections?
In other MT’s behind NAT and ISP modems, I have rules like the ones bellow but am unsure if they are enough to offer good/dissent protection.
A pretty safe approach when constructing firewall rules is to have ultimate rule in both input and forward chan which drops everything not accepted by previous rules. Your setup only drops invalid packets which doesn’t really protect your router (or network behind that router). Remember: implicit last rule is to accept packet. It’s much easier to create safe rule set with “drop all” as last rule since it’s easy to notice that some legitimate traffic is getting dropped (due to forgotten accept rule) … OTOH it’s hard to spot any missing drop rule … until after it’s too late.
So if I understand it correctly create at the end two rules one for input and one for forward in this way ? : add action=drop chain=input and add action=drop chain=forward or after action=drop chain=input comment=“defconf: drop invalid” connection-state=invalid and action=drop chain=forward comment=“defconf: drop invalid” connection-state=invalid log=yes respectively?
And then have them appear in logs to see if any legitimate traffic is blocked ?
Something like that. If you need to add some accept rules later, push them just below the “drop invalid” rules and above the new “drop all” ones.
I wouldn’t log all hits of “drop all rules”, there might be many entries due to bots scanning the network. A missing accept rule will be very obvious because something won’t work.
