firewalling a dstnat : srcnat setup???
Hi all… Newbie here…
I have multiple Internet IP addresses and they are dstnat’ed to multiple static IP’s on my local network for example:
Chain: dstnat
Dst addy: 72.14.207.90
Action: dst-nat
To addy: 172.16.1.10
To ports: 0-65535
and
Chain: srcnat
Src Addy: 172.16.1.10
Action: src-nat
To addy: 72.14.207.90
To potrs: 0-65535
Is this the correct way to set up a 1:1 ?
Also I have similar entries for “72.14.207.91-95” dst and src nat’d to 172.16.1.11-15
Everything seems to work ok except when I try and firewall it.
I set up some filter rules:
Chain: forward
Dst addy: 172.16.1.12
Protocol: 6 (tcp)
Dst port: 25
Action: accept
I did the same for other ports like 110, 80, 22 and so forth… different ports for different servers. Then for the very last filter rule I set up a drop
to block the rest of the ports like so:
Chain: forward
Dst addy: 172.16.1.10-172.16.1.15
Action: drop
and it seems to block everything fine except it is also blocking all outbound traffic from those servers at 172.16.1.10-15. For example when this last filter rule is enabled I cant telnet to a ip address outside of my network.
I also tried dst/srcnat ing onlt the ports I needed but I still had the same problems connecting from these servers to anything outside my network.
Can someone point me in the right direction? Thanks for any help.
You need a rule in the forward chain that allows traffic with state ‘Established’ to pass.
You can also put in a rule to allow Related traffic.
Regards
Andrew
Do you have a firewall rule that allows outbound traffic, incoming interface from your LAN, src-ip 172.16.1.0/24, allowed out WAN ? The forward chain is for incoming and outgoing, so you need to allow what you want for each direction. Typically you would put these rules towards the top of your chain.
thanks… that worked perfectly
