I use Flashfig to configure our Mikrotik routers (450G), usually this works quite well. However I now have run into a problem (different configuration template) where parts of the configuration don’t seem to be accepted via FlashFig. (Flashfig seems to be successful, no errors of the com port console connection or on the Flashfig software).
But when I look at the actually configuration parts (like the /ip address section) are missing.
All the lines are accepted when I just copy them via the console so I can’t see what syntax errors might be causing this.
Is there a way of getting a debug output of the Flashfig configuration process? Or perhaps even some more documentation what happens in the background with the .rsc file
