Forcing source ip and/or route
I’m not sure how to properly express this. I had a problem that I tried to solve with various combinations of src-nat and routing policy, failed, and then fixed it by doing it properly - which means configuring the clients directly instead of trying to use network magic.
But I want to learn network magic. So while my original problem has been solved - I’d like to know how I could have accomplished this through the router.
My cloud server is has static public IP a.a.a.a. It provides wireguard service as b.b.b.a.
My office router has dynamic public IP so.me.th.ing. It has wireguard IP b.b.b.b.
My office server has a LAN IP c.c.c.c behind the router.
The question - how can I force traffic from c.c.c.c, destined to a.a.a.a, come from b.b.b.b? Or to put it another way how to force traffic from my office server destined to the public address of the cloud server, which is otherwise properly routed and reachable, instead through the VPN? And while in this particular case a valid answer might be via wireguard configuration - I really want to know how to do it via routing.
I tried
/ip firewall nat add action=src-nat chain=srcnat dst-address=a.a.a.a src-address=c.c.c.c to-addresses=b.b.b.b
That didn’t work.
I tried
/routing table add fib name=wg
/routing rule add action=lookup-only-in-table dst-address=a.a.a.a src-address=c.c.c.c table=wg
/ip route distance=1 dst-address=a.a.a.a gateway=b.b.b.b pref-src="" routing-table=wg scope=30 suppress-hw-offload=no target-scope=10
And that didn’t work.
What am I missing?
Post both configs
/export file=anynameyouwish ( minus router serial number, any public WANIP information, keys, long dchp lease lists etc..)
Why not
```text
gateway=b.b.b.a
I’d say that you took a right direction.
  1. Create a separate routing table to route a.a.a.a to b.b.b.a
  2. Create a rule that sticks your client (source address) to this table.
  3. Add NAT/Masq. to make sure source address of your client gets substituted by b.b.b.b (you server expects connections from b.b.b.b only)
  4. Run trace on client
  5. Check connections on Mikrotik. What do you see?
Interesting.
In the process of sanitizing my export I found some garbage filter rules. Removing those was probably a good thing. Now that I’ve done that, and re-activated the src-nat & routing…
It almost works. Or at least - now traffic from the office server fails to reach the cloud server where it used to make it through fine. And by traffic I mean ping/mtr/tcptraceroute.
So I’ve disabled the rules again pending more guidance.
test.rsc (20.7 KB)
