Forum changes 2025-10-02?
I primarily use Windows and a browser for forum access. I use Chrome if that makes a difference.
There used to be an edit window with text and markup (that could be copied to notepad) and a preview window on the right to show what the post will look like when posted (and these were individually scrollable). Now I see only a single entry windows that is attempting to be a what you see is what you get editor. When entering a picture it is now harder to see what it will look like.
There used to be on the righthand side a timeline that made it easy to got to the top or the bottom of a thread. How are you now supposed to get the bottom of a long thread?
Change is ok if there is a good reason for it and advantages to make up for the changes. I dislike changes that reduce functionality without any good reason.
Maybe I just need to learn how to do things differently, but I don’t even know where to look for “what’s new” and “how can I do things the new way” anywhere.
About the editor: the top-left button above the edit area can be used to toggle the Markdown / WYSIWYG mode.
Thank you! I don't know if I accidentally hit that button. Maybe there wasn't even a change, as I now see the timeline on the right hand side.
Yesterday after the upgrade the WYSIWYG mode was also the default for me too, so you didn't accidentally turn it on :blush:.
