I recently discovered that offloading does not work at all for the bridge traffic. I upgraded to CRS510 and use SFP25 ports
I see traffic going through
- sfp28-7
- sfp28-8
- switch1-cpu => Counter "Drop Packet" goes up
With ~ 500 Mbit/s of throughput CPU shows values up to 100%.
What am I missing currently?
set sfp28-7 !egress-rate !ingress-rate l3-hw-offloading=yes limit-broadcasts=yes limit-unknown-multicasts=no limit-unknown-unicasts=no mirror-egress=no mirror-ingress=no storm-rate=100
set sfp28-8 !egress-rate !ingress-rate l3-hw-offloading=yes limit-broadcasts=yes limit-unknown-multicasts=no limit-unknown-unicasts=no mirror-egress=no mirror-ingress=no storm-rate=100
/interface bridge settings
set allow-fast-path=yes use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=no
/interface ethernet switch l3hw-settings
set autorestart=yes fasttrack-hw=yes icmp-reply-on-error=yes ipv6-hw=yes
/interface ethernet switch l3hw-settings advanced
set neigh-discovery-burst-delay=300ms neigh-discovery-burst-limit=64 neigh-discovery-interval=1m37s neigh-dump-retries=3 neigh-keepalive-interval=15s partial-offload-chunk=1024 route-index-delay-max=10s route-index-delay-min=1s
route-queue-limit-high=256 route-queue-limit-low=0 shwp-reset-counter=128
set add-dns-entries=no add-dns-entries-suffix=lan discover-interface-list=!none discover-interval=30s dying-gasp=no lldp-dcbx=yes lldp-mac-phy-config=no lldp-max-frame-size=no lldp-med=yes lldp-med-net-policy-vlan=disabled lldp-poe-in-power=
yes lldp-vlan-info=no mode=tx-and-rx protocol=cdp,lldp,mndp
set [ find default-name=sfp28-7 ] advertise=10M-baseT-half,10M-baseT-full,100M-baseT-half,100M-baseT-full,1G-baseT-half,1G-baseT-full,1G-baseX,2.5G-baseT,2.5G-baseX,5G-baseT,10G-baseT,10G-baseSR-LR,10G-baseCR,25G-baseSR-LR,25G-baseCR arp=
enabled arp-accept=no arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no fec-mode=auto l2mtu=10218 loop-protect=default loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=04:F4:1C:15:26:39
mtu=10218 name=sfp28-7 orig-mac-address=04:F4:1C:15:26:39 rx-flow-control=off sfp-ignore-rx-los=no sfp-rate-select=high sfp-shutdown-temperature=95C tx-flow-control=off
set [ find default-name=sfp28-8 ] advertise=10M-baseT-half,10M-baseT-full,100M-baseT-half,100M-baseT-full,1G-baseT-half,1G-baseT-full,1G-baseX,2.5G-baseT,2.5G-baseX,5G-baseT,10G-baseT,10G-baseSR-LR,10G-baseCR,25G-baseSR-LR,25G-baseCR arp=
enabled arp-accept=no arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no fec-mode=auto l2mtu=10218 loop-protect=default loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=04:F4:1C:15:26:3A
mtu=10218 name=sfp28-8 orig-mac-address=04:F4:1C:15:26:3A rx-flow-control=off sfp-ignore-rx-los=no sfp-rate-select=high sfp-shutdown-temperature=95C tx-flow-control=off
/queue interface
set sfp28-7 queue=only-hardware-queue
set sfp28-8 queue=only-hardware-queue
set switch1 l3-hw-offloading=yes mirror-target=none name=switch1 qos-hw-offloading=yes rspan=no rspan-egress-vlan-id=1 rspan-ingress-vlan-id=1
add ageing-time=5m arp=disabled arp-timeout=auto auto-mac=yes !dhcp-agent-circuit-id !dhcp-agent-remote-id dhcp-snooping=no !dhcpv6-agent-circuit-id !dhcpv6-agent-remote-id dhcpv6-snooping=no disabled=yes fast-forward=yes
forward-reserved-addresses=yes igmp-snooping=no max-learned-entries=auto mlag-heartbeat=5s mlag-init-delay=1m mlag-lacp-fallback=yes mlag-peer-port=none mlag-priority=128 mtu=auto name=bridge-2 port-cost-mode=long
protocol-mode=none ra-guard=no vlan-filtering=no
/queue interface
set bridge1 queue=no-queue
set lo queue=no-queue
set bridge-2 queue=no-queue
add auto-isolate=no bpdu-guard=no bridge=bridge1 broadcast-flood=yes disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none hw=yes ingress-filtering=no interface=sfp28-7 !internal-path-cost learn=auto multicast-router=
disabled mvrp-applicant-state=normal-participant mvrp-registrar-state=normal !path-cost point-to-point=auto priority=0x80 pvid=1 restricted-role=no restricted-tcn=no tag-stacking=no trusted=no trusted-arp=no trusted-dhcpv6=no trusted-ra=
no unknown-multicast-flood=yes unknown-unicast-flood=yes
add auto-isolate=no bpdu-guard=no bridge=bridge1 broadcast-flood=yes disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none hw=yes ingress-filtering=no interface=sfp28-8 !internal-path-cost learn=auto multicast-router=
/interface ethernet switch rule
add copy-to-cpu=no disabled=no !dscp !dst-address !dst-address6 !dst-mac-address !dst-port !flow-label !mac-protocol mirror=yes !new-dst-ports !new-qos-profile !new-vlan-id !new-vlan-priority !new-vrf ports=sfp28-7,sfp28-8 !protocol !rate
redirect-to-cpu=no !src-address !src-address6 !src-mac-address !src-port switch=switch1 !traffic-class !vlan-header !vlan-id !vlan-priority
add copy-to-cpu=no disabled=no !dscp !dst-address !dst-address6 !dst-mac-address !dst-port !flow-label !mac-protocol mirror=yes !new-dst-ports !new-qos-profile !new-vlan-id !new-vlan-priority !new-vrf ports=sfp28-8,sfp28-7 !protocol !rate
/ip traffic-flow
set active-flow-timeout=30m cache-entries=32k enabled=no inactive-flow-timeout=15s interfaces=all packet-sampling=no sampling-interval=0 sampling-space=0
"H" for offloading
