Hi all,
I am having a problem forwarding all websites to one website. Http works fine but https does not. Below if my config export:
set [ find default-name=ether3 ] master-port=ether2
set [ find default-name=ether4 ] master-port=ether2
set [ find default-name=ether5 ] master-port=ether2
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-128-cbc
add name=dhcp_pool1 ranges=192.168.8.10-192.168.8.254
add address-pool=dhcp_pool1 authoritative=after-2sec-delay disabled=no
interface=ether2 lease-time=3d name=dhcp1
add address=192.168.8.1/24 interface=ether2 network=192.168.8.0
add address=192.168.1.2/24 disabled=yes interface=ether1 network=192.168.1.0
/ip dhcp-server lease
add address=192.168.8.2 client-id=1:f0:9f:c2:d0:19:d0 comment=“UniFi Mesh AP”
mac-address=F0:9F:C2:D0:19:D0 server=dhcp1
add address=192.168.8.0/24 dns-server=192.168.8.1 gateway=192.168.8.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
add action=redirect chain=dstnat dst-port=443 protocol=tcp to-ports=8080
add action=redirect chain=dstnat dst-port=80 protocol=tcp to-ports=8080
/ip proxy
set cache-path=web-proxy1 enabled=yes
/ip proxy access
add dst-host=www.bills.express
add action=deny dst-host=* redirect-to=www.bills.express
add action=deny dst-host=facebook.com redirect-to=www.bills.express
add action=deny dst-host=www.facebook.com redirect-to=www.bills.express
add distance=1 gateway=192.168.1.1
/system clock
set time-zone-name=Africa/Harare
/system identity
set name=“Bills Express”
If I enable the 443 rule under NAT no websites forward correctly, the page just times out. If I disable it then the http traffic is redirected correctly but not https. Please help me figure out where I’ve gone wrong because I’m clearly missing something.
Thanks in advance!
