Freeradius 2x and Mac wirelless Authentication Big Headache
Hello everyone!
I’m having a problem to authenticate mac wireless freeradius mikrotik in February on “1171 was quiet”
5.5 use debian lenny postgres and php can authenticate hotspot, PPPoE, DHCP, Winbox, ssh etc … mac hard but wirelless ta
I tried parameters: “User-Passord” of this in the log
Sat Aug 14 00:55:02 2010: Auth: Login incorrect: [00:05:9 E: 8B: 11:35 / 00:05:9 E: 8B: 11:35] (from client server port 0 cli 00-05 -9E-8B-11-35)
attribute “Password”
Sat Aug 14 00:56:09 2010: Auth: Login incorrect (rlm_pap: empty password supplied): [00:05:9 E: 89:4 B: 09 /] (from client server port 0 cli 00-05-9E-89 -4B-09)
attribute “Cleartext-Password”
Sat Aug 14 00:56:10 2010: Auth: Login incorrect: [00:05:9 E: 83: BBA /] (from client server port 0 cli 00-05-9E-83-BB-DA)
I wonder if anyone ever had this problem and could give me a light as I turned the net 10 times and I find no solution.
Below one of my debug freeradius
Thank you for your attention!
Starting - reading configuration files …
including configuration file /etc/freeradius/radiusd.conf
including configuration file /etc/freeradius/proxy.conf
including configuration file /etc/freeradius/clients.conf
including configuration file /etc/freeradius/snmp.conf
including configuration file /etc/freeradius/eap.conf
including configuration file /etc/freeradius/sql.conf
including configuration file /etc/freeradius/sql/postgresql/dialup.conf
including configuration file /etc/freeradius/sql/postgresql/counter.conf
including configuration file /etc/freeradius/policy.conf
including files in directory /etc/freeradius/sites-enabled/
including configuration file /etc/freeradius/sites-enabled/inner-tunnel
including configuration file /etc/freeradius/sites-enabled/default
including dictionary file /etc/freeradius/dictionary
main {
prefix = “/usr”
localstatedir = “/var”
logdir = “/var/log/freeradius”
libdir = “/usr/lib/freeradius”
radacctdir = “/var/log/freeradius/radacct”
hostname_lookups = no
max_request_time = 30
cleanup_delay = 5
max_requests = 1024
allow_core_dumps = yes
pidfile = “/var/run/freeradius/freeradius.pid”
user = “freerad”
group = “freerad”
checkrad = “/usr/sbin/checkrad”
debug_level = 0
proxy_requests = no
security {
max_attributes = 200
reject_delay = 1
status_server = no
client 187.28.xxx.x {
require_message_authenticator = no
secret = “*******”
shortname = “SERVIDOR”
nastype = “other”
secret = “teste”
shortname = “SERVIDOR_VIRTUAL_MIKROTIK_BINHO”
nastype = “other”
radiusd: #### Loading Realms and Home Servers ####
proxy server {
retry_delay = 5
retry_count = 3
default_fallback = no
dead_time = 120
wake_all_if_all_dead = no
home_server localhost {
ipaddr = 127.0.0.1
port = 1812
type = “auth”
secret = “testing123”
response_window = 20
max_outstanding = 65536
zombie_period = 40
status_check = “status-server”
ping_check = “none”
ping_interval = 30
check_interval = 30
num_answers_to_alive = 3
num_pings_to_alive = 3
revive_interval = 120
status_check_timeout = 4
home_server_pool my_auth_failover {
type = fail-over
home_server = localhost
realm example.com {
auth_pool = my_auth_failover
realm LOCAL {
radiusd: #### Instantiating modules ####
instantiate {
Module: Linked to module rlm_exec
Module: Instantiating exec
exec {
wait = yes
input_pairs = “request”
shell_escape = yes
Module: Linked to module rlm_expr
Module: Instantiating expr
Module: Linked to module rlm_expiration
Module: Instantiating expiration
expiration {
reply-message = "Password Has Expired "
Module: Linked to module rlm_logintime
Module: Instantiating logintime
logintime {
reply-message = "You are calling outside your allowed timespan "
minimum-timeout = 60
radiusd: #### Loading Virtual Servers ####
server inner-tunnel {
modules {
Module: Checking authenticate {…} for more modules to load
Module: Linked to module rlm_pap
Module: Instantiating pap
pap {
encryption_scheme = “auto”
auto_header = no
Module: Linked to module rlm_chap
Module: Instantiating chap
Module: Linked to module rlm_mschap
Module: Instantiating mschap
mschap {
use_mppe = yes
require_encryption = no
require_strong = no
with_ntdomain_hack = no
Module: Linked to module rlm_unix
Module: Instantiating unix
unix {
radwtmp = “/var/log/freeradius/radwtmp”
Module: Linked to module rlm_eap
Module: Instantiating eap
eap {
default_eap_type = “md5”
timer_expire = 60
ignore_unknown_eap_types = no
cisco_accounting_username_bug = no
Module: Linked to sub-module rlm_eap_md5
Module: Instantiating eap-md5
Module: Linked to sub-module rlm_eap_leap
Module: Instantiating eap-leap
Module: Linked to sub-module rlm_eap_gtc
Module: Instantiating eap-gtc
gtc {
challenge = "Password: "
auth_type = “PAP”
rlm_eap: Ignoring EAP-Type/tls because we do not have OpenSSL support.
rlm_eap: Ignoring EAP-Type/ttls because we do not have OpenSSL support.
rlm_eap: Ignoring EAP-Type/peap because we do not have OpenSSL support.
Module: Linked to sub-module rlm_eap_mschapv2
Module: Instantiating eap-mschapv2
mschapv2 {
Module: Checking authorize {…} for more modules to load
Module: Linked to module rlm_realm
Module: Instantiating suffix
realm suffix {
format = “suffix”
delimiter = “@”
ignore_default = no
ignore_null = no
Module: Linked to module rlm_files
Module: Instantiating files
files {
usersfile = “/etc/freeradius/users”
acctusersfile = “/etc/freeradius/acct_users”
compat = “no”
Module: Checking session {…} for more modules to load
Module: Linked to module rlm_radutmp
Module: Instantiating radutmp
radutmp {
filename = “/var/log/freeradius/radutmp”
username = “%{User-Name}”
case_sensitive = yes
check_with_nas = yes
perm = 384
callerid = yes
Module: Checking post-proxy {…} for more modules to load
Module: Checking post-auth {…} for more modules to load
Module: Linked to module rlm_attr_filter
Module: Instantiating attr_filter.access_reject
attr_filter attr_filter.access_reject {
attrsfile = “/etc/freeradius/attrs.access_reject”
key = “%{User-Name}”
server {
modules {
Module: Linked to module rlm_preprocess
Module: Instantiating preprocess
preprocess {
huntgroups = “/etc/freeradius/huntgroups”
hints = “/etc/freeradius/hints”
with_ascend_hack = no
ascend_channels_per_line = 23
with_specialix_jetstream_hack = no
with_cisco_vsa_hack = no
with_alvarion_vsa_hack = no
Module: Linked to module rlm_sql
Module: Instantiating sql
sql {
driver = “rlm_sql_postgresql”
server = “localhost”
port = “”
login = “*******”
password = “*******”
radius_db = “sis-prov”
read_groups = yes
sqltrace = yes
sqltracefile = “/var/log/freeradius/sqltrace.sql”
readclients = yes
deletestalesessions = yes
num_sql_socks = 5
sql_user_name = “%{User-Name}”
default_user_profile = “”
connect_failure_retry_delay = 60
simul_count_query = “”
simul_verify_query = “”
postauth_query = “INSERT INTO radpostauth (username, pass, reply, authdate) VALUES (‘%{User-Name}’, ‘%{%{User-Password}:-Chap-Password}’, ‘%{reply:Packet-Type}’, NOW())”
safe-characters = “@abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789.-_: /”
rlm_sql (sql): Driver rlm_sql_postgresql (module rlm_sql_postgresql) loaded and linked
rlm_sql (sql): Attempting to connect to admin@localhost:/sagu
rlm_sql (sql): starting 0
rlm_sql (sql): Attempting to connect rlm_sql_postgresql #0
rlm_sql (sql): Connected new DB handle, #0
rlm_sql (sql): starting 1
rlm_sql (sql): Attempting to connect rlm_sql_postgresql #1
rlm_sql (sql): Connected new DB handle, #1
rlm_sql (sql): starting 2
rlm_sql (sql): Attempting to connect rlm_sql_postgresql #2
rlm_sql (sql): Connected new DB handle, #2
rlm_sql (sql): starting 3
rlm_sql (sql): Attempting to connect rlm_sql_postgresql #3
rlm_sql (sql): Connected new DB handle, #3
rlm_sql (sql): starting 4
rlm_sql (sql): Attempting to connect rlm_sql_postgresql #4
rlm_sql (sql): Connected new DB handle, #4
rlm_sql (sql): Processing generate_sql_clients
rlm_sql (sql) in generate_sql_clients: query is SELECT id, nasname, shortname, type, secret FROM nas
rlm_sql (sql): Reserving sql socket id: 4
rlm_sql_postgresql: query: SELECT id, nasname, shortname, type, secret FROM nas
rlm_sql_postgresql: Status: PGRES_TUPLES_OK
rlm_sql_postgresql: query affected rows = 0 , fields = 5
rlm_sql (sql): Released sql socket id: 4
Module: Checking preacct {…} for more modules to load
Module: Linked to module rlm_acct_unique
Module: Instantiating acct_unique
acct_unique {
key = “User-Name, Acct-Session-Id, NAS-IP-Address, Client-IP-Address, NAS-Port”
Module: Checking accounting {…} for more modules to load
Module: Instantiating attr_filter.accounting_response
attr_filter attr_filter.accounting_response {
attrsfile = “/etc/freeradius/attrs.accounting_response”
radiusd: #### Opening IP addresses and Ports ####
listen {
type = “auth”
ipaddr = *
port = 0
I do not see any authentication attempt in the debug output. Skip all the radius startup responses, and post the results of a login transaction from the router. You might want to post any router log entries about the transaction also.
Maybe your startup post was incomplete, but as I recall, “radiusd -X” finishes startup with something like:
Waiting for input
Thank SurferTim
Below is part of an attempt to debug authentication
rad_recv: Access-Request packet from host 187.28.126.3 port 39327, id=92, length=147
Service-Type = Framed-User
NAS-Port-Id = “wlan3”
User-Name = “00:05:9E:83:C9:AF”
Calling-Station-Id = “00-05-9E-83-C9-AF”
Called-Station-Id = “00-02-6F-30-36-BD:Speed_BP1”
User-Password = “”
NAS-Identifier = “SERVIDOR_BOA_PASSAGEM”
NAS-IP-Address = 187.28.126.3
± entering group authorize
++[preprocess] returns ok
++[chap] returns noop
++[mschap] returns noop
rlm_realm: No ‘@’ in User-Name = “00:05:9E:83:C9:AF”, looking up realm NULL
rlm_realm: No such realm “NULL”
++[suffix] returns noop
rlm_eap: No EAP-Message, not doing EAP
++[eap] returns noop
++[unix] returns notfound
++[files] returns noop
expand: %{User-Name} → 00:05:9E:83:C9:AF
rlm_sql (sql): sql_set_user escaped user → ‘00:05:9E:83:C9:AF’
rlm_sql (sql): Reserving sql socket id: 1
expand: SELECT id, UserName, Attribute, Value, Op FROM radcheck WHERE Username = ‘%{SQL-User-Name}’ ORDER BY id → SELECT id, UserName, Attribute, Value, Op FROM radcheck WHERE Username = ‘00:05:9E:83:C9:AF’ ORDER BY id
rlm_sql_postgresql: query: SELECT id, UserName, Attribute, Value, Op FROM radcheck WHERE Username = ‘00:05:9E:83:C9:AF’ ORDER BY id
rlm_sql_postgresql: query affected rows = 2 , fields = 5
expand: SELECT GroupName FROM usergroup WHERE UserName=‘%{SQL-User-Name}’ ORDER BY priority → SELECT GroupName FROM usergroup WHERE UserName=‘00:05:9E:83:C9:AF’ ORDER BY priority
rlm_sql_postgresql: query: SELECT GroupName FROM usergroup WHERE UserName=‘00:05:9E:83:C9:AF’ ORDER BY priority
rlm_sql_postgresql: query affected rows = 0 , fields = 1
rlm_sql (sql): Released sql socket id: 1
rlm_sql (sql): User 00:05:9E:83:C9:AF not found
++[sql] returns notfound
++[expiration] returns noop
++[logintime] returns noop
rlm_pap: WARNING! No “known good” password found for the user. Authentication may fail because of this.
++[pap] returns noop
auth: No authenticate method (Auth-Type) configuration found for the request: Rejecting the user
auth: Failed to validate the user.
Login incorrect: [00:05:9E:83:C9:AF/] (from client SERVIDOR_BOA_PASSAGEM port 0 cli 00-05-9E-83-C9-AF)
Found Post-Auth-Type Reject
± entering group REJECT
attr_filter: Matched entry DEFAULT at line 11
++[attr_filter.access_reject] returns updated
Delaying reject of request 30 for 1 seconds
Going to the next request
Waking up in 0.1 seconds.
rad_recv: Access-Request packet from host 187.28.126.3 port 38425, id=90, length=147
Waiting to send Access-Reject to client SERVIDOR_BOA_PASSAGEM port 38425 - ID: 90
Sending delayed reject for request 27
Sending Access-Reject of id 89 to 187.28.126.3 port 58907
Waking up in 0.2 seconds.
rad_recv: Access-Request packet from host 187.28.126.3 port 52102, id=91, length=147
Waiting to send Access-Reject to client SERVIDOR_BOA_PASSAGEM port 52102 - ID: 91
Waiting to send Access-Reject to client SERVIDOR_BOA_PASSAGEM port 39327 - ID: 92
Here is the important part. Looks like it may be the default Auth-Type in your radius setup.
Check your radiusd.conf file in the ‘authenticate’ section.
ADD: Are you certain this user is in your SQL database? I just saw this above the Auth-Type message.
My config is soos
Ek het probeer om verskeie conf en tot nou toe kon ek nie maak dit werk
authorize {
preprocess
pap
chap
mschap
suffix
eap {
ok = return
unix
files
sql
expiration
logintime
authenticate {
Auth-Type PAP {
pap
Auth-Type CHAP {
chap
Auth-Type MS-CHAP {
mschap
unix
eap
The radius debug shows the user 00:05:9E:83:C9:AF not found. Is this user in your database?
