i have noticed that if i have password stored in database in md5 or sha user can not use/authenticate using:
bandwidth test
winbox
mac-telnet
things taht only work are:
telnet
ssh
ftp
if i have password in clear text format all above works
freeradius -X returns:
without clear text login via winbox/mac-telnet/bw test:
++[logintime] returns noop
[pap] Normalizing SHA-Password from hex encoding
[pap] WARNING: Auth-Type already set. Not setting to PAP
++[pap] returns noop
Found Auth-Type = CHAP
# Executing group from file /etc/freeradius/sites-enabled/default
+- entering group CHAP {...}
[chap] login attempt by "*****" with CHAP password
[chap] Cleartext-Password is required for authentication
with sha or md5 password login via ssh/telnet:
++[sql] returns ok
++[expiration] returns noop
++[pap] returns updated
Found Auth-Type = PAP
+- entering group PAP {...}
[pap] login attempt with password "*******"
[pap] Using SHA1 encryption.
[pap] User authenticated successfully
++[pap] returns ok
i have found that when logging via ssh/telnet mikrotik sends password in clear text. when logging via winbox/mac-telnet/bw-test mikrotik sens password in chap-password format. it is now obvious why radius fails to “transform” chap password into sha-password.
i am asking why it is different in winbox/mac-telnet/bw-test ?
HI
I had the same problem before, my problem solved by moving some lines in /usr/local/etc/raddb/sites-enabled/default
i’m using SQL so i load SQL module and pap,chap
I’ve changed the lines from
chap
sql
pap
to:
sql
pap
chap
so freeradius first loads the sql and then loads the chap, so it could locate password in SQL.
I have the same issue. If user has configured password in database with attribute “Cleartext-Password” everything is fine but I would like to know what other attribute and hash should put to store so all password are encrypted and winbox/ssh/telnet to works. In this days is very very unacceptable to store whatever password in clear text format. In our company we have a lot of mikrotik routers and would like to have centralized user control with freeradius server. I have read that latest versions of Winbox supports PAP as authentication mechanism but I didn’t managed to find any information how to configure.
I would really highly appreciate if someone help us with the config. Thanks in advance.
