Hello everyone !
Using Hap ac2 RBD52G-5HacD2HnD-TC, attached usb flash drive. Configured partition, users, in ip-services default ftp ports is changes to 221, also included in firewall.
chain=input action=accept protocol=tcp in-interface=ether1-WAN dst-port=221 log=no log-prefix=""
In local network (lan) ftp is working, when trying to access via WAN port can't connect
ftp client error:TYPE I
Response: 200 Type set to I
Command: PASV
Response: 227 Entering Passive Mode (78,83,109,95,236,214).
Command: LIST
Response: 425 Can't build data connection
Error: Failed to retrieve directory listing
Probably have to configure passive ports. Can't find which passive ports mikrotik ftp server uses, or where I can change them, so they be opened via firewall.
If I open ports 1-65535 ftp works via WAN, but I think that is not correct.
I have two ftp servers on computers in local network, which ports are opened and works perfectly, but for mikrotik ftp server can't find information.
This is current rules in firewall
# nov/07/2019 13:54:08 by RouterOS 6.45.7
# software id = G8AC-QXNU
# model = RBD52G-5HacD2HnD
# serial number = A6470AE67982
established,related,untracked
add action=accept chain=input comment="http WAN" dst-port=8080 protocol=tcp
add action=accept chain=input comment="https WAN" dst-port=58291 protocol=tcp
add action=accept chain=input comment="ftp router" dst-port=2221 \
in-interface=ether1-WAN protocol=tcp
add action=accept chain=input dst-port=20 in-interface=ether1-WAN protocol=\
tcp
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=dst-nat chain=dstnat comment=transmission dst-port=9091 \
in-interface=ether1-WAN protocol=tcp to-addresses=10.10.10.7 to-ports=\
9091
add action=dst-nat chain=dstnat comment="rdp pc" dst-port=53389 in-interface=\
ether1-WAN protocol=tcp to-addresses=10.10.10.2 to-ports=3389
add action=dst-nat chain=dstnat comment="ftp storage" dst-port=2121 protocol=\
tcp to-addresses=10.10.10.7 to-ports=21
add action=dst-nat chain=dstnat comment="ftp pc" dst-port=21 protocol=tcp \
to-addresses=10.10.10.2 to-ports=2121
add action=dst-nat chain=dstnat comment="https storage" dst-port=8443 \
443
add action=dst-nat chain=dstnat comment=torrent dst-port=44222 in-interface=\
ether1-WAN protocol=tcp to-addresses=10.10.10.2 to-ports=44222
add action=dst-nat chain=dstnat comment=WOL disabled=yes dst-port=9 \
in-interface=ether1-WAN protocol=udp to-addresses=10.10.10.2 to-ports=9
add action=dst-nat chain=dstnat comment=netgear dst-port=8888 in-interface=\
ether1-WAN protocol=tcp to-addresses=10.10.10.11 to-ports=8888
add action=dst-nat chain=dstnat comment="ssh storage" dst-port=2222 \
22
add action=dst-nat chain=dstnat comment="ftp passive pc" dst-port=40000-40400 \
in-interface=ether1-WAN in-interface-list=all protocol=tcp to-addresses=\
10.10.10.2 to-ports=40000-40400
add action=dst-nat chain=dstnat comment="ftp passive storage" dst-port=\
50000-50400 in-interface=ether1-WAN protocol=tcp to-addresses=\
10.10.10.7 to-ports=50000-50400
add action=dst-nat chain=dstnat comment="http WAN" disabled=yes dst-port=8080 \
in-interface=ether1-WAN protocol=tcp to-addresses=10.10.10.1 to-ports=\
8080
add action=netmap chain=dstnat comment=wol dst-port=9 protocol=udp \
Thanks in advance !
