Function call inside Script called over API doesn't work
I have created some Global Functions and they work fine when calling them from inside a script. But, if you try to call the same script over API, the “Function” part of the script doesn’t run. I’m using ROS v6.42.6.
Thanks in advance,
Artur Scheiner
