Get rate on interface
i wont get the rate of an interface (ether1)
if the rate is not 1Gbps , only 100M, then the interfae should be shut down an 1sec later shut be up.
have you any suggestions?
How can I be the “rate” from “monitor” get?
:put [/interface/ethernet/get rate ether1]
or
will not work
thanks
You cannot get rate from get as it's dynamic, so you need monitor once to get it. For example,
:put ([/interface/ethernet/monitor ether13 once as-value]->"rate")
1Gbps
You can check and do it...
:local if "ether1"
:if (([monitor $if once as-value]->"rate") != "1Gbps") do={
    disable $if
    :delay 1s
    enable $if
...but if it doesn't go back to 1Gbps for some reason... it's always disconnecting and reconnecting...
:local if "ether1"
    disable $if
    :delay 1s
    enable $if
    :delay 10s
        # disable scheduler here...
thank you so much. works perfect.
