Hello. Recently I purchased Mikrotik hAP ax3 (C53UiG+5HPaxD2HPaxD) instead of my old TP-Link Archer C6, most of the functionality seems to be working OK (except occasional SA query timeout, but that’s another topic), good coverage and speeds, but I’m having issues connecting Google Nest Audio speaker to the WiFi and spent several days researching this topic to no avail. It often can’t see my networks at all even though it sees all the neighbors. I’m able to connect the speaker to my hotspot from the phone and it worked on my old router as well, so I suspect the problem is in my ax3 since it is the only thing that changed recently.
My setup: I have only one router in my flat, I’ve configured 2 WiFi networks with different names, one for 5 GHz and one for 2.4 GHz. routeros 7.16.2. wifi-qcom 7.16.2.
The issue: While setting up the speaker it often can’t see my networks, neither 5 GHz one, nor 2.4 GHz. Very rarely it detects 5 GHz, tries to connect to it, but later gives up saying “unable to connect”. Sometimes (but only sometimes, for some reason) it can see 2.4 GHz network and then is able to connect to it and will work until the router is rebooted (because of blackout, for example) or once router randomly dropped the connection (it happened only once during a couple of weeks). What I found that could work to fix it - is going into 2.4 network configuration and switching WIFI band to another one (for example AX to N, or N to AX) and then the speaker will be able to connect to the router again, it works more often than not, but still can fail from time to time. This workaround doesn’t work with 5 GHz network though.
I even was able to reproduce the issue with 2.4 GHz network by: rebooting the router → speaker looses the connection → I wait for the speaker to reconnect (waited up to 1 hour, all other devices are able to find the network and connect) → speaker still cannot connect → open network settings and change WiFi band → wait a couple of minutes and the speaker successfully connected to the network (or I can redo the setup process and it will see that network). Repeated this process several times, almost always it worked, one time I had to switch the band couple more times before it connected.
What else I tried on both 5GHz and 2.4GHz networks and did not had an effect:
- Play with the different settings, tried different bands, different channel width, authentification types and encryption types (wpa, wpa2, wpa3, ccmp, tkip, etc), disable\enable FT, enabled UPNP as was suggested in one of the topics on the forum.
- Tried to analyze my neighbors wifi networks via WIFI Analyzer and configure my networks the same way.
- Set up the speaker almost right next to the router (1-2 meters distance).
Did any one else encountered such issues? Could somebody help me?
I’ve asked my friends who have mikrotik devices but no one seem to have this issues, but they are also on older devices like hAP ac or rb2011uias-2hnd-in with wireless driver, not wifi-qcom, could it be the issue with the newer driver?
My config:
# 2024-12-29 11:17:20 by RouterOS 7.16.2
# software id = 7KR8-1ZQT
# model = C53UiG+5HPaxD2HPaxD
# serial number = HGW******
add admin-mac=F4:1E:57:20:XX:XX auto-mac=no comment=defconf name=bridge
/interface wifi
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=disabled .width=20/40/80mhz configuration.country=Ukraine .mode=ap .multicast-enhance=enabled .ssid=Lasagna disabled=no security.authentication-types=wpa2-psk .ft=yes .ft-over-ds=yes
set [ find default-name=wifi2 ] channel.band=2ghz-n .skip-dfs-channels=all .width=20/40mhz configuration.country=Ukraine .mode=ap .multicast-enhance=enabled .ssid=Lasagna2.4 disabled=no security.authentication-types=wpa2-psk .encryption=ccmp .ft=yes .ft-over-ds=no .management-encryption=cmac .management-protection=disabled
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge name=defconf
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
/ip dhcp-client
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=dst-nat chain=dstnat comment="Local server" dst-port=27000-27050 protocol=tcp to-addresses=192.168.88.254
add action=dst-nat chain=dstnat comment="Local server" dst-port=27000-27050 protocol=udp to-addresses=192.168.88.254
add action=masquerade chain=srcnat dst-address=192.168.88.254 out-interface=bridge protocol=tcp src-address=192.168.88.0/24
add action=masquerade chain=srcnat dst-address=192.168.88.254 out-interface=bridge protocol=udp src-address=192.168.88.0/24
/ip ipsec profile
/ip upnp
set allow-disable-external-interface=yes enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=ether1 type=external
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" dst-port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system note
set show-at-login=no
/system routerboard wps-button
set enabled=yes on-event=wps-accept
/system script
add comment=defconf dont-require-permissions=no name=wps-accept owner=*sys policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\r\
\n :foreach iface in=[/interface/wifi find where (configuration.mode=\"ap\" && disabled=no)] do={\r\
\n /interface/wifi wps-push-button \$iface;}\r\
\n "
/tool mac-server
/tool mac-server mac-winbox
