GPIO function for RBM33G
I wrote a function to work with GPIO RBM33G I/O lines. Probably not everything is rational in it, since I wrote with little time for optimization, just to work. But it works. Take who needs it. See the parameters in the function code. In general, this is $1 - action, $2 - line number (or all), $3 “direction” for $1 direction. If someone has a desire to optimize, or write their own better, I will say thank you.
P/S: Rex, come back, dear! It’s boring without you.
:global iotLine do={
:global ioLineNONC
:local arrayPin {3; 5; 12; 13; 15; 16}
:local ioLine 6
:local act;
:if ([:len $ioLineNONC]=0) do={:set $ioLineNONC true}
:if ($1="help") do={
         /terminal style varname
         :put ""
         :put "Function works with GPIO RBM33G"
         :put "version 1.2"
         :put "by Sertik 30/10/2023"
         :put ""
         :put "\$1 - action: on/off/enable/disable/direction/info/help"
         :put "\$2 - line number, if not define - all"
         :put "\$3 - input/output for direction"
         :put "\$ioLineNONC - true (or not specified) - line for NO rele/ false - line for NC rele"
         :put ""
         /terminal style none}
 :if ([:len [/system routerboard settings get gpio-function]]!=0) do={
                              :local gpioanswer "Pin 12-16 is not set on GPIO.\n\rPlease reset routerboard gpio-function and reboot Router."
                              :put ("ERROR $0 function"."\r\n"."$gpioanswer")
                              :log error ("ERROR $0 function"."\r\n"."$gpioanswer")
                              :return $gpioanswer}
     if (($1="info") and ([:len $2]=0)) do={
:local gio [/iot gpio digital print as-value]
:local count 0; local name; :local comment; :local script; :local dir; :local output; :local input;
:foreach i in=$gio do={
                            :set name ($gio->$count->"name")
                            :set comment ($gio->$count->"comment")
                            :set script ($gio->$count->"script")
                            :set dir ($gio->$count->"direction")
                            :set input ($gio->$count->"intput")
                            :set output ($gio->$count->"output")
                            :set count ($count+1)
         :put ("$count "."$name "."$dir "."$output "."$input "."$comment "."$script")
         :log warning ("$count "."$name "."$dir "."$output "."$input "."$comment "."$script")
:return $gio}
:if (($1="info") && ([:len $2]=1)) do={
   :if (([:tonum $2]<=0) or ([:tonum $2]>$ioLine)) do={:return Error}
do {
                  :local state [/iot gpio digital get "pin$($arrayPin->([:tonum $2]-1))"]
                  :return $state
} on-error={:return Error}
:if (($1="enable") and ([:len $2]=1)) do={
do {
                               [/iot gpio digital set "pin$($arrayPin->([:tonum $2]-1))" disabled=no]
                               :local pinSet ([/iot gpio digital get "pin$($arrayPin->([:tonum $2]-1))"]->"disabled")
                               :if (!$pinSet) do={:return "Done"} else={:return "Not set"}
:if (($1="disable") and ([:len $2]=1)) do={
do {
                               [/iot gpio digital set "pin$($arrayPin->([:tonum $2]-1))" disabled=yes]
                               :if ($pinSet) do={:return "Done"} else={:return "Not set"}
:if (($1="disable") and ([:len $2]=0)) do={
   do {
                  :foreach Xpin in=$arrayPin do={
                  /iot gpio digital set "pin$Xpin" disabled=yes
:return Done}
:if (($1="enable") and ([:len $2]=0)) do={
   do {
                  /iot gpio digital set "pin$Xpin" disabled=no
:return Done}
:if (($1="direction") and ([:len $3]=0)) do={
    :if (($2="input") or ($2="output")) do={
        do {
                  /iot gpio digital set "pin$Xpin" direction=$2
  } else={:return Error}
:return Done}
:if (($1="direction") and ([:len $2]=1) and ([:len $3]>1)) do={
     :if (($3="input") or ($3="output")) do={
       :if ([:tonum $2]>$ioLine) do={:return "Error"}
            :do {
                  /iot gpio digital set "pin$($arrayPin->[:tonum $2])" direction=$3
:return Done}
     :if (($1="on") && ($ioLineNONC=true)) do={:set act 1}
     :if (($1="on") && ($ioLineNONC=false)) do={:set act 0}
     :if (($1="off") && ($ioLineNONC=true)) do={:set act 0}
     :if (($1="off") && ($ioLineNONC=false)) do={:set act 1}
:if ([:len $act]>0) do={
   :if ([:len $2]>0) do={
           :do {
# check direction output - error
        :if ([/iot gpio digital get "pin$($arrayPin->([:tonum $2]-1))" direction]="input") do={:return "Error line $2 is set on INPUT"}
                  /iot gpio digital set "pin$($arrayPin->([:tonum $2]-1))" output=$act
     } else={
#check direction output for group line - sckip input line
         :if ([/iot gpio digital get "pin$Xpin" direction]="output") do={
                  /iot gpio digital set "pin$Xpin" output=$act}
 :return "Done"} else={:return "Error"}
Examles (:global ioLineNONC true or non for NO line type rele, :global ioLineNONC false for line NC-type)
[$iotLine help]
[$iotLine info]
:local R3 [$iotLine info 3]
:put ([$iotLine info 2]->“disabled”)
[$iotLine direction 3 output]
[$iotLine direction input]
:log error (“Logical 1 on line 3 “.”$[$iotLine on 3]”)
:delay 2s
:log warning (“Logical 0 on line 3 “.”$[$iotLine off 3]”)
[$iotLine on]
[$iotLine off]
[$iotLine enable/disable 1]
[$iotLine enable/disable]
My new article about RBM33G https://habr.com/ru/articles/776908/
  1. Control of the RBM33G Mikrotik via the second serial port
  2. Connecting the remote control to the Microtik
  3. Connecting the beeper module
  4. Talking microtik - connecting the voice recording/playback module
  5. Serial MP3 Player control via Laurent-5G
  6. Connecting Arduino to Mikrotik (via USB) with port forwarding from the network to USB
  7. Output of the GPIO connector to the router housing
