GPOE-USB raspberry 4B 5V noise issue
I am using GPOE-USB with rpi 4B and hifi-berry hat. Hat looses sync all the time. When i power rpi from phone adapter there arent any issues.
Is my GPOE faulty or Is this a characteristic of it?
Did you check the power draw or voltages when fault appears ? Maybe GPOE is overloaded. Are you using same cable when powering RPI from the charger and GPOE ?
BUT how are you powering the GPOE-USB?
And how many A does the rpi need?
In theory it wants 3.0A@5.1V (15.3W total), but I have seen many people recommend a 4A@5V power supply.
Strictly speaking a 802.3af power source is not enough to provide the "target" 15W (3A@5V) the GPOE-USB promises.
Even if it is 90% efficient, it needs 15/0.9=are 16.67W which at 48V (say) are 0.35A, without considering any loss in cable.
A strict 802.3af power supply may fall shorter than that, as the standard mandates 15.40W at the PSE in order to power a load of max 12.95W .
A 802.3at is needed - still in theory - to exceed 12.95W at the PD.
