GPS clock from RouterOS
For what it's worth, for quite a few years, I have been using a NTP200 (that model since replaced with the NTP220) from CenterClick as my time source, and been very happy with it. https://centerclick.com/ntp/
All my devices that want time (pretty much everything) gets time from the NTP200.
I did an upgrade to RouterOS 7.25... NTP client and server is now quite a mess, offsets to atomic clock is either 53 000 miliseconds or more. Its obviously wrong, just by checking other synced device - router time is +- 1 second.
Obviously a problem in your setup, it works fine here.
I reverted most of the settings.
Basically it looks like that NTP client is reporting offset 53000 miliseconds, compared to a multiple NTP servers, even after it was synced with external source.
it looks more like its a missing decimal, since the offset was previously 53ms.
I will give it more time to sync, but for now it did not seem to happenned over few days.
In my opinion, this turned into a very strange discussion for
I run a very similar setup—phones, tablets, PCs, TVs, synced NASs, and Home Assistant across 4 locations (the furthest being ~35 km away) connected via WireGuard S2S.
Time sync is handled by a MikroTik NTP client (pointing to public NTP servers) and an internal NTP server for all compatible local devices, keeping frequency drift under 9 ms.
In over 8 years, I’ve never had a single issue related to time sync.
I get it, and I’m guilty of this kind of perfectionism myself sometimes—1 microsecond or 1 ms accuracy sounds cool...
But what does it actually achieve in practice?
What is the point of building a dedicated setup just for time synchronization?
I honestly don't have an answer.
Could someone explain the practical benefit of that level of precision for a home/homelab setup like this?
P.S. I realize PPS output is useful for niche applications like ham radio, but beyond that...
Basically just to have properly synced local ntp timesource in case of prolonged network outage.
Just a backup.
Services which run locally might fail without it. Aside from entertainment, it can affect heating, wifi security, depends on what you run locally.
In case of this particular setup, its meant to keep sync within 2 seconds, for 7 dollars if you already have any mikrotik router with GPS and NTP support, while there are certainly more robust solutions.
Yes, I agree—a backup is always useful.
And indeed, a €7 GPS dongle is more than enough.
That’s a very reasonable price to pay for peace of mind.:wink:
My RB5009 which is synchronized to 4 external NTP servers reports offsets like 0.2 ms.
My other NTP reports as low offset as well.
gps sync is off, tried to power off the router, sync with the cloud, but the weird offsets persist.
Nothing else indicate any issue with the router, (cpu/ram is not elevated, ping is normal, no packet loss) just the ntp client.
Will try to check config tomorrow.
