Graphing
Good Day
I have graphing set up on my routers and that works 100s. My issue is how can i have the graphs automatically saved to the router? whenever the router reboots it loses all the previous graphs.
Did you enable “store on disk” for you graph rules?
Hi. this is what i have done.
INTERFACE ALLOW-ADDRESS STORE-ON-DISK
0 all 0.0.0.0/0 yes
regards
It should work. I have this configuration for two RB1100 in V4.15 and V5.6.
Try to check whether you RB have enough space for store on disk.
See this long time known and unfixed issue: graphs deleted after reboot on v.5.0 / slow NTP sync
