Hi there,
I’m trying to setup a GRE tunnel to get some extra static public ipv4-adressen in my network. (Provider: ExtraIP)
But I can’t access my IP from outside my network. When I access a new public IP from within my network, it works fine (of course, IP is bound to the CCR) but when I try to access the IP from WAN, nothing special happens. ![]()
The provider told me to use the following config:
/interface gre
add name=ExtraIP remote-address=85.12.12.12
add address=XXX.XXX.XXX.XXX/YY interface=ether2
add distance=1 gateway=ExtraIP
add distance=1 dst-address=85.12.12.12/32 gateway=<-- gateway -->
But this is to forward the IPs to the ether2 int. I want to NAT the IPs to be more flexible in how to utilise the IPs.
I have added the GRE tunnel, and it shows up as running/not-slave. Afterwards I bound one of the new IPs to the tunnel int. When accessing the IP from LAN it works, WAN it doesn’t.
I’m not very familiar in those Gre tunnels, so I hope one of you could help me out.
