Groove - A-52HPn - 5Ghz wireless bridge + 2.4 ghz WAP
Dear MK Gurus!
I have been making 5ghz wireless bridges by setting one groove as master and the others as client using station WDS mode which works great.
Can i at the same time use the client grooves to act as a 2.4 Ghz WAP as well??
Thank you,
Omar
Set both to ap bridge mode and add wds link manually on both sides.
You can also use wds-slave mode.
