Groove connecting to wifi but not passing IP to Routerboard
Hi there-
I recently setup a Routerboard as a primary access point connected via PoE to a Groove to connect to/amplify access points. I’m able to log in to both consoles for setup (after successfully using Quickset to config Groove in Router mode, with Auto Address acquisition). Further, I’m able to access it’s IP (for console/config) via the RouterBoard Wifi access (using assigned IP for Groove).
From the Groove, I can scan and connect to a known, good Wifi access point (actually a couple). But for some reason, once connected, the client (macbook) still cannot access the web. I also tried to access the Groove “Check for Updates” (under System/Packages) while connected and it was not able to reach the internet either to look for an update.
I’m sort of stuck trying to figure out what else to troubleshoot. Any help/guidance would be greatly appreciated.
Thanks,
Jeff
A quick update to this: after working through a number of config changes, I still have the same issue:
Setup:
Mikrotik hAP with Groove AC connected to PoE (goal is to be able to grab / amplify wifi for local access).
hAP AP is setup, able to login, and config via: x.x.x.1
Groove boots successfully and am able to access it/config via hAP AP at: x.x.x.10[/list][/list]
From there, can successfully scan/connect Groove to different APs that are known/working.
However, when connected, I continue to get “cannot access internet”. And - when trying to update the Groove OS, the check for updates is not able to reach a server.
1.) any suggestions? I know enough to be dangerous… and am likely just overlooking something.
2.) any config guides out there (beyond what comes OOtB) that might help me troubleshoot?
Appreciate any pointers.
Thanks, Jeff
Post your configuration for the Groove and router then someone will see your problem. Open “New Terminal” and enter /export file=yourfilename hide-sensitive . This file will appear in “Files” . Upload it to your computer, open it in a text editor and paste it in a post using code blocks http://forum.mikrotik.com/t/getting-the-most-out-of-this-forum/40983/1 This will save a lot of guessing about your problem.
Thank you @w32pamela for the pointers and suggestion to post config - much appreciated (and I should have thought of that - my bad). Here are my AP and Groove configs (note: searching the Wiki, I actually used the “export compact”. Hopefully this provides verbose enough detail for initial troubleshooting.) Again, I’m able to connect to Groove via the hAP. And, I’m able top connect to a known-good wifi AP from the Groove (and seem to see some broadcast traffic between the AP I’m connecting the Groove to and the Groove). But, I’m not able top access internet via the hAP.
Again, grateful for any tips/suggestions on what I might be missing.
thanks!
Here is the config for the hAP:
# jan/05/1970 00:36:42 by RouterOS 6.44.6
# software id = LI8D-72M0
# model = RB962UiGS-5HacT2HnT
# serial number = C5610B1DCD57
add admin-mac=C4:AD:34:DD:E8:E3 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX country="united states" disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=<sanitized>-2GHz wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX country="united states" disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=<sanitized>-5GHz wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=<sanitized> wpa2-pre-shared-key=<sanitized>
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=sfp1
add bridge=bridge comment=defconf interface=wlan2
add address=192.168.88.1/24 comment=defconf interface=ether2 network=192.168.88.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/tool mac-server
/tool mac-server mac-winbox
Here is the config for the Groove:
# feb/08/2021 22:06:25 by RouterOS 6.42.11
# software id = 3MA2-0MBR
# model = RouterBOARD Groove GA-52HPacn
# serial number = A3F30A3769A4
add admin-mac=74:4D:28:3E:4E:4C auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n country="united states" disabled=no frequency=auto mode=station-pseudobridge ssid=<sanitized> wireless-protocol=nv2-nstreme-802.11
add name=WAN
add name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk group-ciphers=tkip,aes-ccm mode=dynamic-keys supplicant-identity=MikroTik unicast-ciphers=tkip,aes-ccm wpa-pre-shared-key=<sanitized> wpa2-pre-shared-key=<sanitized>
add name=dhcp ranges=192.168.88.3-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=dhcp1
add bridge=bridge comment=defconf disabled=yes interface=wlan1
add interface=wlan1 list=WAN
add interface=bridge list=LAN
add address=192.168.88.10/24 interface=ether1 network=192.168.88.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=bridge
add dhcp-options=hostname,clientid disabled=no interface=wlan1
add address=192.168.88.0/24 gateway=192.168.88.10 netmask=24
/system clock
set time-zone-name=America/Los_Angeles
FIRST THING FIRST: Upgrade package/firmware to last long term release! You run high risk of getting hacked with old releases like 6.42!!!
Quick look (sorry no time to scan all):
You use same local IP address and DHCP server on both devices?
You should use 2 different local subnets like 192.168.88.x and 192.168.99.x on the two different units DHCP servers.
I would use the Groove in CPE mode and the hAP in WISP AP mode.
First reset the Groove to factory default. Then insure the mode on Quickset is set to CPE. You should be able to use the Quickset to connect to an AP, browse the Internet and update the Groove when connected directly to it.
Next, reset the hAP to factory default. Then goto: IP> Firewall> Filter and disable all firewall rules (or at least the default drop rule for the chain=input). Now you can change the mode to WISP AP in Quickset. You may loose connection to the hAP, this is expected. Connect the Groove to the POE Out port of the hAP. If you left the IP setting on the hAP set to DHCP you should be able to find its IP on the Groove under: IP> DHCP-Server> Leases. You can make this lease static and then edit the IP to something more memorable like 192.168.88.2. A quick reboot of the hAP and you should be able to connect to it and update it. Then you can change the wireless settings using Quickset to your liking.
Normally making changes using Quickset after you make changes out side of it brakes things (the reason for resets), but in this case the script that is used for WISP AP is broken and will cause you to loose IP connectivity to the device if you don’t disable the firewall rules first…
Thanks WeWiNet and 2frogs. Really appreciate the help. I’m away from the gear but will have access tomorrow to make the changes. I’ll follow up with my results.
Regards
Jeff
Well, after many months unable to work on this, I’m reviving the thread with some progress made. Thanks @WeWiNet and @2frogs for the great guidance. I was able to get the Groove setup (in CPE mode) and the hAP (in WISP AP) mode. But, still having a few issues. Although the Groove is set and connected to a reliable/known Wifi AP and shows Tx/Rx, I’m not able to access the internet the Groove is connected to when plugged into the PoE port on the hAP I’m connected to.
Should the Groove be in Router or Bridge mode?
Should the Address Source be Any, Ethernet, or wLAN?
Anything else you might suggest I look into?
I think there may just be a detail or two I’m missing here. Fully admin I an NOT a networking/IP export so appreciate any guidance/assistance.
thanks,
Jeff
Hi. Did you ever solve this? I am struggling with a similar(same?) problem. How do I tell the hap to use ether5 as uplink?
