Sorry for another hairpin NAT post. I have managed to get to the point of reaching the subdomain then getting a 'Secure Connection Failed' error. I have tried a few different solutions and this is as close as I've managed to get.
I am on mobile broadband with a public IP and have added my subdomains to an address list and the router is updating the IP address when it changes so that is ok. I seem to be struggling with the final steps so wondered if anyone can point me in the right direction please.
My config:
2026-10-07 10:13:54 by RouterOS 7.24.5
set [ find default-name=ether1 ] loop-protect=on
/interface lte
set [ find default-name=lte1 ] allow-roaming=no band=1,3,5,7,8,20
network-mode=lte,5g nr-band=28
/interface vlan
add comment=CCTV disabled=yes interface=ether1 name=CCTV vlan-id=20
add comment="Geust WiFi" disabled=yes interface=ether1 name="Guest WiFi"
vlan-id=50
add comment="Home Automation VLAN" disabled=yes interface=ether1 name=
HomeAutomation vlan-id=30
add comment="VLAN 10 Management" disabled=yes interface=ether1 name="VLAN 10"
vlan-id=10
add comment="WiFi VLAN" disabled=yes interface=ether1 name=WiFi vlan-id=40
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] apn=3internet authentication=chap comment=
"Main Mobile Internet" ip-type=ipv4 name=3Internet use-network-apn=no
use-peer-dns=no
add name=dhcp ranges=10.2.1.100-10.2.1.200
add address-pool=dhcp interface=ether1 name=defconf
/queue type
add fq-codel-ecn=no kind=fq-codel name=fq-codel-ethernet-default
/queue interface
set ether1 queue=fq-codel-ethernet-default
/ipv6 settings
set disable-ipv6=yes
/interface detect-internet
set detect-interface-list=WAN
add comment=defconf interface=ether1 list=LAN
add comment=defconf interface=lte1 list=WAN
add address=10.2.1.1/24 comment=defconf interface=ether1 network=10.2.1.0
add address=10.2.1.0/24 comment=defconf dns-server=10.2.1.8,1.1.1.1,9.9.9.9
gateway=10.2.1.1 netmask=24
set allow-remote-requests=yes servers=10.2.1.8,1.1.1.1,9.9.9.9
/ip dns static
add address=10.2.1.1 comment=defconf name=router.lan type=A
/ip firewall address-list
add address=cctv.tsilimawr.co.uk comment=CCTV list="WAN IP"
add address=cloud.tsilimawr.co.uk comment=Cloud list="WAN IP"
add address=axe.tsilimawr.co.uk comment=Matrix list="WAN IP"
add address=axechat.tsilimawr.co.uk comment="Matrix Web" list="WAN IP"
add address=axemas.tsilimawr.co.uk comment="Matrix AS" list="WAN IP"
add address=imm.tsilimawr.co.uk comment=Immich list="WAN IP"
add address=10.2.1.0/24 comment=MainLAN list=LAN_IP
add action=drop chain=forward comment=MalwareFilteringOutbound
connection-state=established,related,new connection-type=""
dst-address-list=Malware-List out-interface=ether1
add action=drop chain=forward comment=MalwareFilteringInbound
connection-state=established,related,new in-interface=lte1
src-address-list=Malware-List
add action=drop chain=forward comment="Drop Block List Traffic Out"
connection-state=established,related,new,untracked dst-address-list=
"Block List"
add action=drop chain=input comment="Drop Block List IP Ranges"
connection-state=invalid,established,related,new,untracked
src-address-list="Block List"
add action=accept chain=forward comment="Internet Traffic" in-interface-list=
LAN out-interface-list=WAN
add action=accept chain=forward comment="Port Forwarding"
connection-nat-state=dstnat
add action=accept chain=input comment="Accept ICMP from LAN"
in-interface-list=LAN protocol=icmp
add action=drop chain=input comment="Drop ICMP from WAN" in-interface-list=
WAN protocol=icmp
add action=drop chain=input comment="Drop DNS from WAN" dst-port=53
in-interface-list=WAN protocol=tcp
in-interface-list=WAN protocol=udp
add action=accept chain=forward comment="https to reverse proxy" disabled=yes
dst-port=443 in-interface-list=WAN log=yes protocol=tcp src-address-list=
add action=accept chain=input comment="Accept Related" connection-state=
related
"defconf: accept established,related, untracked" connection-state=
established,related,untracked
add action=accept chain=input comment="Accept Established" connection-state=
established
add action=fasttrack-connection chain=forward comment="defconf: fasttrack"
add action=drop chain=forward comment="defconf: drop invalid"
add action=drop chain=forward comment="Drop All Not Matching Above"
"defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat
disabled=yes in-interface-list=WAN
add action=drop chain=input in-interface-list=!LAN
/ip firewall mangle
add action=mark-connection chain=prerouting comment=
"Mark connections for hairpin NAT" dst-address-list="WAN IP"
new-connection-mark="Hairpin NAT" src-address-list=LAN_IP
add action=masquerade chain=srcnat comment="Hairpin NAT" connection-mark=
"Hairpin NAT"
add action=masquerade chain=srcnat comment="defconf: masquerade"
add action=dst-nat chain=dstnat comment="https for reverse proxy"
dst-address-list="WAN IP" dst-port=443 protocol=tcp src-address-list=
"!Block List" to-addresses=10.2.1.8 to-ports=443
/ip firewall raw
add action=drop chain=prerouting comment="Block DNS Flooding" dst-port=53
in-interface=lte1 protocol=udp
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set sip disabled=yes
/ip service
set telnet disabled=yes
set www disabled=yes
/ipv6 firewall address-list
/ipv6 firewall filter
"defconf: accept established,related,untracked" connection-state=
add action=drop chain=input comment="defconf: drop invalid" connection-state=
invalid
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute"
dst-port=33434-33534 protocol=udp
"defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=
udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500
protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=
ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=
ipsec-esp
"defconf: drop everything else not coming from LAN" in-interface-list=
!LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack6"
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1"
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=
icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=
500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=
ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=
ipsec-esp
!LAN
/system clock
set time-zone-name=Europe/London
/system identity
set name=Berthllwyd_ATL
/system scheduler
add !days interval=1w1d name=MalwareFullUpdate policy=
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon
start-date=2026-09-30 start-time=09:39:33
add !days interval=12h name=MalwareDiffUpdate policy=
start-date=2026-09-30 start-time=09:39:58
/tool mac-server
/tool mac-server mac-winbox
/tool sms
set port=lte1 receive-enabled=yes
Thank you in advance
Jon
