As some point I have lost the ability to connect to couple of hap ac2’s from the wan side.
Winbox, ping, pptp, nothing from wan side. Is there a hidden feature somewhere that blocks all connections from outside world?
Not internet issue, because I cannot even ping from local pfsense server simulating “wan side”.
Tried even accepting all in firewall. Still nothing. No winbox not even a ping response from the wan side.
And the weirdest part of all is that firewall logs the ICMP packets. Looks like Router sends no response.
23:54:27 firewall,info input: in:InternetBr out:(unknown 0), src-mac 00:00:5e:00:0
1:01, proto ICMP (type 8, code 0), 193.40.XX.XX->84.50.XX.XX, len 60
add admin-mac=CC:2D:E0:A3:74:E1 auto-mac=no name=InternetBr
add admin-mac=CC:2D:E0:A3:74:DE auto-mac=no comment=defconf name=LanBr
add name=dTVBr
add name=pfSBr
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
disabled=no distance=indoors frequency=auto installation=indoor mode=\
ap-bridge ssid=MikroTik-A374E2 wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto \
installation=indoor mode=ap-bridge ssid=MikroTik-A374E3 \
/interface vlan
add comment=LAN interface=ether1 name=eth1.10 vlan-id=10
add comment=dTV interface=ether1 name=eth1.4 vlan-id=4
add comment=pfS interface=ether1 name=eth1.6 vlan-id=6
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
dynamic-keys supplicant-identity=MikroTik
/ip hotspot profile
add name=dhcp ranges=192.168.11.10-192.168.11.140
add name=vpn ranges=192.168.89.2-192.168.89.255
add address-pool=dhcp disabled=no interface=LanBr name=defconf
/ppp profile
set *FFFFFFFE local-address=192.168.89.1 remote-address=vpn
add bridge=LanBr comment=defconf interface=ether2
add bridge=LanBr comment=defconf interface=ether3
add bridge=LanBr comment=defconf interface=ether4
add bridge=LanBr comment=defconf interface=ether5
add bridge=LanBr comment=defconf interface=wlan1
add bridge=LanBr comment=defconf interface=wlan2
add bridge=LanBr interface=eth1.10
add bridge=dTVBr interface=eth1.4
add bridge=pfSBr interface=eth1.6 trusted=yes
add bridge=InternetBr interface=ether1
/interface detect-internet
set detect-interface-list=all internet-interface-list=WAN lan-interface-list=\
LAN wan-interface-list=WAN
/interface l2tp-server server
set enabled=yes use-ipsec=yes
add comment=defconf interface=LanBr list=LAN
/interface pptp-server server
set enabled=yes
/interface sstp-server server
set default-profile=default-encryption enabled=yes
add address=192.168.11.1/24 comment=defconf interface=ether2 network=\
192.168.11.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=\
InternetBr
add add-default-route=no dhcp-options=hostname,clientid disabled=no \
interface=pfSBr
add add-default-route=no dhcp-options=hostname,clientid interface=dTVBr
add address=192.168.11.0/24 comment=defconf gateway=192.168.11.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.11.1 comment=defconf name=router.lan
established,related,untracked
add action=accept chain=input comment="Input ALL!!!"
add action=accept chain=forward comment="Forward ALL!!!"
add action=accept chain=output comment="Output ALL!!!"
add action=accept chain=input comment="allow IPsec NAT" dst-port=4500 \
protocol=udp
add action=accept chain=input comment="allow ping" protocol=icmp
add action=accept chain=input comment="allow winbox" dst-port=8291 protocol=\
tcp
add action=accept chain=input comment="allow IKE" dst-port=500 protocol=udp
add action=accept chain=input comment="allow l2tp" dst-port=1701 protocol=udp
add action=accept chain=input comment="allow pptp" dst-port=1723 protocol=tcp
add action=accept chain=input comment="allow sstp" dst-port=443 protocol=tcp
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=masquerade chain=srcnat comment="masq. vpn traffic" src-address=\
192.168.89.0/24
add distance=1 dst-address=172.17.0.0/16 gateway=192.168.6.1
add distance=5 dst-address=193.40.5.245/32 gateway=192.168.6.1
add distance=5 dst-address=193.40.7.92/32 gateway=192.168.6.1
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=LanBr type=internal
add interface=ether1 type=external
/ipv6 firewall address-list
add address=::224.0.0.0/100 comment="defconf: other" list=bad_ipv6
add address=::127.0.0.0/104 comment="defconf: other" list=bad_ipv6
add address=::/104 comment="defconf: other" list=bad_ipv6
add address=::255.0.0.0/104 comment="defconf: other" list=bad_ipv6
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/ppp secret
add name=vpn
/system clock
set time-zone-name=Europe/Tallinn
/system routerboard settings
set auto-upgrade=yes
/tool mac-server
/tool mac-server mac-winbox
