Hi There Guys,
I’ve recently bought MikroTik hAP ac3 as my wireless router. I’ve done the settings checking forums and other videos. But, I’m facing issues with the setup of 5GHz WiFi.
Whenever I select “Bangladesh” as my regulatory domain, the following error “No supported channels, the scan list does not contain valid channels” is popping up.
But it works fine with the 2.4GHz band.
Is there any twaeks I can do to make it work and make it better?
My Wireless configuration is below:
add authentication-types=wpa2-psk eap-methods=“” mode=dynamic-keys name=
profile_mgX supplicant-identity=“” wpa2-pre-shared-key=mgX!@#789xyz
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode
band=2ghz-g/n channel-width=20/40mhz-XX country=russia2 disabled=no
distance=indoors frequency=auto hw-protection-mode=cts-to-self
hw-retries=14 installation=indoor max-station-count=85 mode=ap-bridge
security-profile=profile_mgX ssid=mgX-Banani wireless-protocol=802.11
wmm-support=enabled wps-mode=disabled
set [ find default-name=wlan2 ] adaptive-noise-immunity=ap-and-client-mode
antenna-gain=3 band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX country=
russia2 disabled=no distance=indoors frequency=auto hw-protection-mode=
cts-to-self hw-retries=14 installation=indoor max-station-count=85 mode=
ap-bridge security-profile=profile_mgX ssid=mgX-Banani wireless-protocol=
802.11 wmm-support=enabled wps-mode=disabled
Thanks in advance.
