Hi, I try to add 5 Vlans to my hAP ax² and want to use 3 of them with the internal antenna. I am a bit confused using the templates you offer at https://help.mikrotik.com/docs/display/ROS/WiFi#WiFi-WiFiCAPsMAN.
Right now, 2 vlans work fine at Wlan (GUEST/PRIVATE)
But I cant see the IoT Net
What is wrong ?
Thanks for a detailed help to get the 3 ssid up and running.Thx in Advance
add name=br vlan-filtering=yes/interface vlan
add interface=br name=GUEST vlan-id=10
add interface=br name=IOT vlan-id=20
add interface=br name=MGMT vlan-id=1
add interface=br name=PRIVATE vlan-id=100
add interface=br name=SIP vlan-id=111/interface list
add name=WAN
add name=LAN/interface wifi datapath
add bridge=br disabled=no name=PRIVATE vlan-id=100
add bridge=br disabled=no name=GUEST vlan-id=10
add bridge=br disabled=no name=IOT vlan-id=20
add bridge=br name=DP_AC/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk disabled=no ft=yes ft-over-ds=yes
name=Security_PRIVATE passphrase=xxxxxxxx
name=Security_GUEST passphrase=xxxxxxxxxxxxxxx
name=Security_IoT passphrase=xxxxxxxxxxx/interface wifi configuration
add datapath=PRIVATE disabled=no name=PRIVATE security=Security_PRIVATE ssid=
PRIVATE_Network
add datapath=GUEST name=GUEST security=Security_GUEST ssid=GUEST_Network
add datapath=IOT disabled=no name=IoT security=Security_IoT ssid=IoT_Network
add datapath=DP_AC name=PRIVATE_AC security=Security_PRIVATE ssid=
PRIVATE_Network
add datapath=DP_AC name=GUEST_AC security=Security_GUEST ssid=GUEST_Network
add datapath=DP_AC disabled=no name=IoT_AC security=Security_IoT ssid=
IoT_Network/ip pool
add name=dhcp_pool-GUEST ranges=192.168.10.2-192.168.10.254
add name=dhcp_pool-IoT ranges=192.168.20.2-192.168.20.254
add name=dhcp_pool-Privat ranges=192.168.100.2-192.168.100.254
add name=dhcp_pool-SIP ranges=192.168.111.2-192.168.111.254
add name=dhcp_pool-MGMT ranges=10.0.0.60-10.0.0.200/ip dhcp-server
add address-pool=dhcp_pool-MGMT interface=MGMT lease-time=1d name=dhcp-MGMT
add address-pool=dhcp_pool-Privat interface=PRIVATE lease-time=1d name=
dhcp-PRIVATE
add address-pool=dhcp_pool-GUEST interface=GUEST lease-time=1d name=
dhcp-GUEST
add address-pool=dhcp_pool-IoT interface=IOT lease-time=1d name=dhcp-IoT
add address-pool=dhcp_pool-SIP interface=SIP lease-time=1d name=dhcp_SIP/interface bridge vlan
add bridge=br tagged=br untagged=wifi1,wifi2,wifi3,wifi4 vlan-ids=20
add bridge=br tagged=br untagged=wifi1,wifi2,wifi3,wifi4 vlan-ids=10
add bridge=br tagged=br untagged=wifi1,wifi2,wifi3,wifi4 vlan-ids=100/interface list member
add interface=ether1 list=WAN
add interface=GUEST list=LAN
add interface=IOT list=LAN
add interface=PRIVATE list=LAN
add interface=MGMT list=LAN/interface wifi cap
set discovery-interfaces=br enabled=yes slaves-static=yes
/interface wifi capsman
set enabled=yes interfaces=br
/interface wifi provisioning
add action=create-dynamic-enabled disabled=no master-configuration=PRIVATE_AC
slave-configurations=GUEST_AC,IoT_AC supported-bands=5ghz-ac
slave-configurations=GUEST_AC,IoT_AC supported-bands=2ghz-n/ip address
add address=192.168.88.1/24 interface=br network=192.168.88.0
add address=192.168.1.1/24 interface=MGMT network=192.168.1.0
add address=192.168.100.1/24 interface=PRIVATE network=192.168.100.0
add address=192.168.20.1/24 interface=IOT network=192.168.20.0
add address=192.168.10.1/24 interface=GUEST network=192.168.10.0/ip dhcp-client
add interface=ether1/ip dhcp-server network
add address=10.0.0.0/24 dns-server=10.0.0.123,1.1.1.1 gateway=10.0.0.1
netmask=24
add address=192.168.1.0/24 gateway=192.168.1.1
add address=192.168.10.0/24 gateway=192.168.10.1
add address=192.168.20.0/24 gateway=192.168.20.1
add address=192.168.111.0/24 gateway=192.168.111.1
add address=192.168.100.0/24 gateway=192.168.100.1
