hAP ax³ - Frequent wifi disconnections
I am the happy owner of an hAP ax³. It runs very fine but the wifi disconnects every now and then with no apparent reason. It happens on both 2.4 and 5 GHz bands.
[admin@hAP] > /log/print where message~"disconnect"
2026-09-17 15:39:58 wireless,info xxx@wifi1(MikroTik-xxx) disconnected, connection lost, signal strength -56
2026-09-17 15:40:15 wireless,info xxx@wifi1(MikroTik-xxx) disconnected, connection lost, signal strength -56
2026-09-17 15:41:25 wireless,info xxx@wifi1(MikroTik-xxx) disconnected, connection lost, signal strength -54
2026-09-17 15:42:34 wireless,info xxx@wifi2(MikroTik-xxx) disconnected, connection lost, signal strength -39
2026-09-17 16:19:43 wireless,info xxx@wifi2(MikroTik-xxx) disconnected, connection lost, signal strength -38
2026-09-17 16:20:28 wireless,info xxx@wifi2(MikroTik-xxx) disconnected, connection lost, signal strength -50
2026-09-17 16:42:39 wireless,info xxx@wifi2(MikroTik-xxx) disconnected, connection lost, signal strength -50
2026-09-17 16:49:38 wireless,info xxx@wifi2(MikroTik-xxx) disconnected, connection lost, signal strength -46
2026-09-17 16:50:17 wireless,info xxx@wifi1(MikroTik-xxx) disconnected, connection lost, signal strength -51
2026-09-17 16:50:34 wireless,info xxx@wifi1(MikroTik-xxx) disconnected, connection lost, signal strength -51
2026-09-17 16:51:49 wireless,info xxx@wifi2(MikroTik-xxx) disconnected, connection lost, signal strength -41
2026-09-17 16:51:49 wireless,info xxx@wifi1(MikroTik-xxx) disconnected, connection lost, signal strength -50
2026-09-17 17:00:56 wireless,info xxx@wifi2(MikroTik-xxx) disconnected, connection lost, signal strength -60
I have set the duration of the leases to 1 day, I have also tried (then reverted) to limit the security to WPA2-PSK, with no success. I have seen the issue mentioned in many threads but couldn't find any effective parade. What should I try ?
Based on your information my best guess would be incorrect config. Please share:
/interface wifi export
Have you seen the interworking.realms-raw="" problem? And is that part of the config?
Thanks for your time. Here it is.
[admin@hAP] > /interface wifi export
# 2026-09-17 19:58:53 by RouterOS 7.24.4
# software id = BE35-S9GA
# model = C53UiG+5HPaxD2HPaxD
# serial number = xxx
/interface wifi
set [ find default-name=wifi1 ] channel.skip-dfs-channels=10min-cac configuration.country=France .mode=ap .ssid=MikroTik-xxx disabled=no mtu=1500 \
security.authentication-types=wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=yes
set [ find default-name=wifi2 ] channel.skip-dfs-channels=10min-cac configuration.country=France .mode=ap .ssid=MikroTik-xxx disabled=no mtu=1500 \
/interface wifi configuration
add datapath.client-isolation=yes disabled=no name=iot_cfg security.authentication-types=wpa2-psk,wpa3-psk ssid=Mikrotik_iot
/interface wifi
add configuration=iot_cfg configuration.mode=ap disabled=no mac-address=xxx master-interface=wifi2 name=wifi_iot
Have you redacted your config? Looks like edited, missing parts.
I have suppressed the identification numbers (serial number, SSID and MAC address), replaced with xxx.
I'd suggest using "preformatted text" formatting. Other than that your config looks pretty much default. I don't think you can fix these disconnections yourself. You can report to Mikrotik support or live with it.
I would also try disabling FT-over-DS, as it is actually intended for use with multiple access points.
If the connection drops do not affect all clients, you could also disable FT. Some clients cannot cope with it.
Which devices disconnect?
I had this recently with a Windows 11 Laptop, other devices worked normally. An update of the Intel wifi driver of the laptop solved the issue (via Intel driver update, the drivers supplied by windows update were not sufficient).
Unfortunately, all my devices seem to disconnect. But it is indeed a bigger problem with my Windows laptop since I use it professionally, which means for videoconferencing.
Do you have the same issue on 7.23.7
I have been having the issue for a certain amount of time, I couldn't tell if a specific version did any better. I have cancelled ft-over-ds. Wait and see!
If that doesn’t help, I’d also try disabling FT.
I also disable it. It is useless anyway with only one router.
That’s not quite right – even with just one access point (router), seamless transitions between the 2.4GHz and 5GHz bands are still possible. However, the Wi-Fi client must also support this feature.
I have around 50 Wi-Fi clients, but only four of them support FT.
Unfortunately that wasn't sufficient to solve the issue.
2026-09-17 15:39:58 wireless,info E0:0A:F6:75:76:A9@wifi1(MikroTik-AC8291) disconnected, connection lost, signal strength -56
2026-09-17 15:40:15 wireless,info E0:0A:F6:75:76:A9@wifi1(MikroTik-AC8291) disconnected, connection lost, signal strength -56
2026-09-17 15:41:25 wireless,info E0:0A:F6:75:76:A9@wifi1(MikroTik-AC8291) disconnected, connection lost, signal strength -54
2026-09-17 15:42:34 wireless,info 02:55:B2:CE:43:A0@wifi2(MikroTik-AC8291) disconnected, connection lost, signal strength -39
2026-09-17 16:19:43 wireless,info 02:55:B2:CE:43:A0@wifi2(MikroTik-AC8291) disconnected, connection lost, signal strength -38
2026-09-17 16:20:28 wireless,info E0:0A:F6:75:76:A9@wifi2(MikroTik-AC8291) disconnected, connection lost, signal strength -50
2026-09-17 16:42:39 wireless,info 02:55:B2:CE:43:A0@wifi2(MikroTik-AC8291) disconnected, connection lost, signal strength -50
2026-09-17 16:49:38 wireless,info E0:0A:F6:75:76:A9@wifi2(MikroTik-AC8291) disconnected, connection lost, signal strength -46
2026-09-17 16:50:17 wireless,info E0:0A:F6:75:76:A9@wifi1(MikroTik-AC8291) disconnected, connection lost, signal strength -51
2026-09-17 16:50:34 wireless,info E0:0A:F6:75:76:A9@wifi1(MikroTik-AC8291) disconnected, connection lost, signal strength -51
2026-09-17 16:51:49 wireless,info 02:55:B2:CE:43:A0@wifi2(MikroTik-AC8291) disconnected, connection lost, signal strength -41
2026-09-17 16:51:49 wireless,info E0:0A:F6:75:76:A9@wifi1(MikroTik-AC8291) disconnected, connection lost, signal strength -50
2026-09-17 17:00:56 wireless,info E0:0A:F6:75:76:A9@wifi2(MikroTik-AC8291) disconnected, connection lost, signal strength -60
2026-09-17 20:09:33 wireless,info E0:0A:F6:75:76:A9@wifi2(MikroTik-AC8291) disconnected, connection lost, signal strength -44
2026-09-17 20:09:50 wireless,info E0:0A:F6:75:76:A9@wifi2(MikroTik-AC8291) disconnected, connection lost, signal strength -44
2026-09-17 20:23:09 wireless,info 02:55:B2:CE:43:A0@wifi2(MikroTik-AC8291) disconnected, connection lost, signal strength -44
2026-09-17 20:23:55 wireless,info E0:0A:F6:75:76:A9@wifi1(MikroTik-AC8291) disconnected, connection lost, signal strength -65
2026-09-17 20:23:58 wireless,info E0:0A:F6:75:76:A9@wifi2(MikroTik-AC8291) disconnected, connection lost, signal strength -58
2026-09-17 21:26:12 wireless,info 02:55:B2:CE:43:A0@wifi2(MikroTik-AC8291) disconnected, connection lost, signal strength -42
2026-09-18 00:23:37 wireless,info A6:33:F0:0A:E9:95@wifi1(MikroTik-AC8291) disconnected, connection lost, signal strength -49
2026-09-18 02:32:27 wireless,info A4:7E:FA:5C:F7:90@wifi_iot(Mikrotik_iot) disconnected, connection lost, signal strength -72
2026-09-18 08:35:30 wireless,info E0:0A:F6:75:76:A9@wifi1(MikroTik-AC8291) disconnected, connection lost, signal strength -55
2026-09-18 08:36:09 wireless,info E0:0A:F6:75:76:A9@wifi2(MikroTik-AC8291) disconnected, connection lost, signal strength -43
2026-09-18 08:36:26 wireless,info E0:0A:F6:75:76:A9@wifi1(MikroTik-AC8291) disconnected, connection lost, signal strength -52
2026-09-18 08:48:42 wireless,info E0:0A:F6:75:76:A9@wifi1(MikroTik-AC8291) disconnected, connection lost, signal strength -68
It seems to be prohibited to one device. Can you tell a bit more about that device?
Can you reset both wifi interfaces and reapply the config?
There’s no quick solution to it and software configuration might not solve any problem until you rule out hardware ones. First of all, stock antennas are very low quality. I’d suggest to unscrew built-in antennas, clear the sockets with contact cleaner and screw them back in. To verify tight connection and radio amplifier signal travels through antenna I used guitar amplifier and a cable moving around but am/fm radio receiver can be used too.
For my ax^3 I even decided to replace antennas with better quality ones, it did help to wireless signal greater than any software change. Then I talked to MikroTik support and followed their recommendations to find how much power I can set according to the regulations, for your country try
interface/wifi/radio/reg-info country=France 0
After that plug to the router with an ethernet cable and capture Wireless “Frequency usage” and “Frequency scan”. Once you find it out least busy channel and better router placement it won’t take too long to set software configuration part.
Thanks for that orientation. I would not have reflected about hardware but that makes perfect sense. I'll try and clean the sockets see if it improves the situation. I don't need antennas with more gain since I live in a small flat. Do you think that changing the antennas may improve something else than the gain?
there are many factors to that, amplifier transmission power isn’t the biggest one, what shape they radiate the signal is more important. Higher transmission signal changes its shape, it gets narrower. Battery powered devices limit client power too, so its increase on access point side may do nothing.
I can tell what helped me but you need to do your own research in your own property for your wireless devices. What did help me to eliminate frequent disconnects:
  • settup regular monitoring GitHub - akpw/mktxp: CLI Diagnostic, Prometheus Exporter, and GitOps Configuration for Mikrotik RouterOS devices · GitHub
  • start capturing wireless signal from all devices every 5 seconds
  • position three wireless devices in far remote places in the property
  • adjust antenna placement so wireless signal distributes the signal as far as possible and doesn’t jump as much
  • only after that, start changing the channels and move away from noisy channels
  • set 2Ghz transmission power -10dB compared to 5Ghz channel
  • configure 5Ghz channel only to all devices that support it via Accesslist
  • keep monitoring and adjusting position, then tx-power if necessary
No, it happens to all devices. At least the two laptops (one Linux, one Windows).
