I’m having a strange issue with a MikroTik C52iG-5HaxD2HaxD running RouterOS firmware type ipq6000 . The device is brand new and was first tested with the factory firmware 7.6 .
The 2.4 GHz SSID works normally and is visible to all devices. The 5 GHz SSID is the problem: MikroTik can see it in scan, but most client devices do not see it at all.
What I tested:
Different RouterOS versions: 7.21.1 , 7.21.3 LTS , 7.22.3 stable
Factory firmware 7.6
Default configuration
Complete configuration wipe/reset
Different wireless parameter changes
Different frequencies and channel settings
DFS disabled / changed
Security variations
Current behavior:
Out of about 10 computers, only one laptop can see the 5 GHz SSID.
MikroTik can see the SSID in scan.
About half of the phones cannot see it.
Samsung phones with One UI 8.5 do not see it at all.
Samsung phones with One UI 8.0 can see it.
Windows 10 / Windows 11 devices also mostly do not see it.
This does not look like a client connection problem — the network is simply not visible to most devices.
I already tried:
Different firmware versions
Full configuration wipe/reset
Different channel/frequency settings
Disabling DFS
Changing channel width
Various security settings
QuickSet defaults and manual changes
At this point I suspect either:
a compatibility issue in the hAP ax2 WiFi implementation,
a regulatory/channel broadcast issue,
or a bug in RouterOS WiFi on this model.
Has anyone seen similar behavior where the AP sees the SSID itself, but most modern clients do not detect it?
PrintDetail
[admin@MikroTik] > /interface/wifi/print detail
Flags: M - MASTER; D - DYNAMIC, N - NETWORK; B - BOUND;
X - DISABLED, I - INACTIVE, R - RUNNING
0 M B default-name="wifi1" name="wifi1" l2mtu=1560
mac-address=48:A9:8A:64:FA:CE arp-timeout=auto
radio-mac=48:A9:8A:64:FA:CE
configuration.country=Czech .installation=indoor .ssid="5G" .mode=ap
security.authentication-types=wpa2-psk .encryption=""
.group-encryption=ccmp
datapath.bridge=bridge
channel.frequency=5180 .band=5ghz-ax .width=20mhz
.skip-dfs-channels=all
1 M B default-name="wifi2" name="wifi2" l2mtu=1560
mac-address=48:A9:8A:64:FA:CF arp-timeout=auto
radio-mac=48:A9:8A:64:FA:CF
configuration.country=Czech .ssid="24G" .mode=ap
security.authentication-types=wpa2-psk,wpa3-psk .ft=yes
.ft-over-ds=yes
channel.skip-dfs-channels=10min-cac
Thanks.
99 out of 100 the issue is config but we did not get to see that ?
Default AX devices tend to select higher frequencies for 5GHz and quite a bit of clients can not handle it.
However there might be other reasons.
So please show export of your config, specifically the wifi part.
Make sure to remove serial, passwd, ... then post back here between code quotes for easier readability.
nicknamer:
.encryption=""
Really?
Config wrong, use /export as mentioned before.
aldek
May 26, 2026, 9:17am
4
The same device model = C52iG-5HaxD2HaxD
RouterOS 7.21.1
No problem at all - iOS, MAC, Ubuntu, Win11 clients, at any 2.4/5 GHz SSIDs
My config:
/interface wifi set [ find default-name=wifi2 ] channel.band=2ghz-ax .reselect-interval=2h..4h .width=20mhz configuration.country=Superchannel .hw-protection-mode=rts-cts .mode=ap .ssid=XXX-X disabled=no name=wifi.2GHz security.authentication-types=wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=yes .passphrase=PASSPHRASE .wps=disable
/interface wifi set [ find default-name=wifi1 ] channel.band=5ghz-ax .reselect-interval=2h..4h .width=20/40/80mhz configuration.country=Superchannel .hw-protection-mode=rts-cts .mode=ap .ssid=XXX-X disabled=no name=wifi.5GHz security.authentication-types=wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=yes .passphrase=PASSPHRASE .wps=push-button
[xxxxxxx@hAPax2-ZL] > interface/wifi print detail
Flags: M - master; D - dynamic; B - bound; X - disabled, I - inactive, R - running
0 M BR default-name="wifi2" name="wifi.2GHz" l2mtu=1560 mac-address=FF:FF:FF:FF:XX:XX arp-timeout=auto
radio-mac=FF:FF:FF:FF:FF:FF
configuration.mode=ap .ssid="XXX-X" .country=Superchannel .hw-protection-mode=rts-cts
security.authentication-types=wpa2-psk,wpa3-psk .wps=disable .ft=yes .ft-over-ds=yes
channel.band=2ghz-ax .width=20mhz .reselect-interval=2h..4h
1 M BR default-name="wifi1" name="wifi.5GHz" l2mtu=1560 mac-address=FF:FF:FF:FF:FF:FF arp-timeout=auto
security.authentication-types=wpa2-psk,wpa3-psk .wps=push-button .ft=yes .ft-over-ds=yes
channel.band=5ghz-ax .width=20/40/80mhz .reselect-interval=2h..4h
aldek:
For maximum compatibility, it should not be set. See other topics on the same topic.
aldek
May 26, 2026, 9:47am
6
Yep, I know, but in my case it doesn't matter.
MMM MMM KKK TTTTTTTTTTT KKK
MMMM MMMM KKK TTTTTTTTTTT KKK
MMM MMMM MMM III KKK KKK RRRRRR OOOOOO TTT III KKK KKK
MMM MM MMM III KKKKK RRR RRR OOO OOO TTT III KKKKK
MMM MMM III KKK KKK RRRRRR OOO OOO TTT III KKK KKK
MMM MMM III KKK KKK RRR RRR OOOOOO TTT III KKK KKK
MikroTik RouterOS 7.22.3 (c) 1999-2026 https://www.mikrotik.com/
Press F1 for help
[admin@MikroTik] > /export hide-sensitive
2026-05-26 08:04:11 by RouterOS 7.22.3
add admin-mac=48:A9:8A:64:FA:CA auto-mac=no comment=defconf name=bridge
/interface wifi
set [ find default-name=wifi1 ] channel.band=5ghz-ax .frequency=5180 .skip-dfs-channels=all .width=20mhz configuration.country=Czech .installation=indoor .mode=ap .ssid=5G datapath.bridge=bridge
disabled=no security.authentication-types=wpa2-psk .encryption="" .group-encryption=ccmp
set [ find default-name=wifi2 ] channel.skip-dfs-channels=10min-cac configuration.country=Czech .mode=ap .ssid=24G security.authentication-types=wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=yes
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge name=defconf
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
/ip dhcp-client
Interface not active
add comment=defconf interface=ether1 name=ether1
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1 in-interface=lo src-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat in-interface-list=WAN
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" dst-port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack6" connection-state=established,related
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system routerboard settings
set auto-upgrade=yes
/tool mac-server
/tool mac-server mac-winbox
[admin@MikroTik] >
/interface wifi
set [ find default-name=wifi1 ] channel.band=5ghz-ax .frequency=5180 .skip-dfs-channels=all .width=20mhz configuration.country=Czech .installation=indoor .mode=ap .ssid=5G disabled=no
interworking.realms-raw="" security.authentication-types=wpa2-psk .encryption=ccmp .group-encryption=ccmp
set [ find default-name=wifi2 ] channel.skip-dfs-channels=10min-cac configuration.country=Czech .mode=ap .ssid=24G disabled=no security.authentication-types=wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=yes
/disk settings
/ip dhcp-client
/ip dns static
/tool mac-server
aldek:
Thank you. I have two of these devices. Both are configured the same way, but one is having these issues and the other isn't...
The only difference is that on one of them, I updated and then downgraded the firmware, while on the other, I've had version 21.1.1 for a long time and it's working fine... But now I'm afraid to upgrade it...
2ghz works perfect... problem is in 5ghz...
tested your configuration - not working
Search other topic: Do not use winbox 3 and remove that wrong config.
Other topics explain exactly how do that.
Paste on Terminal:
/interface wifi
set [ find ] !interworking.realms-raw
Thank you, but not working
/interface wifi
.reselect-interval=2h..4h .skip-dfs-channels=all .width=20/40/80mhz
configuration.country=Czech .hw-protection-mode=rts-cts .installation=
indoor .mode=ap .ssid=5ghzt disabled=no name=wifi.5GHz
security.authentication-types=wpa2-psk,wpa3-psk .encryption=ccmp .ft=yes
.ft-over-ds=yes .group-encryption=ccmp .wps=push-button
First start from a base where it works for everyone, then customize...
Paste this:
/interface wifi
set [ find default-name=wifi1 ] !channel.band channel.frequency=5180 !channel.reselect-interval \
.skip-dfs-channels=all !channel.width configuration.country=Czech !configuration.hw-protection-mode .installation=indoor \
.mode=ap disabled=no !interworking.realms-raw security.authentication-types=wpa2-psk \
.encryption=ccmp .ft=yes .ft-over-ds=yes .group-encryption=ccmp .management-protection=disabled .wps=disable
/interface wifi
SSID not set
must specify passphrase for PSK
set [ find default-name=wifi1 ] configuration.country=Czech .installation=indoor .mode=ap disabled=no mtu=1500 security.authentication-types=wpa2-psk
.beacon-protection=disabled .encryption=ccmp .ft=yes .ft-over-ds=yes .group-encryption=ccmp .management-protection=disabled .wps=disable
SSID not set
set [ find default-name=wifi2 ] configuration.country=Czech .installation=indoor .mode=ap disabled=no security.authentication-types=wpa2-psk .encryption=ccmp
jaclaz
May 26, 2026, 12:25pm
16
You probably need to add this:
aldek:
to each set of commands
Something new comes up every time,
but what are you doing?
set [ find default-name=wifi1 ] configuration.country=Czech .installation=indoor .mode=ap .ssid=T5G mtu=1500 security.authentication-types=wpa2-psk
.beacon-protection=disabled .encryption="" .management-protection=disabled .wps=disable
It doesn't matter if there's no authentication—I turned off all authentication options and it still doesn't work. Now I've set it to WPA2 with the password 12345678, and that doesn't work either. Most devices just can't see it; it's not listed among the visible networks...
jaclaz
May 26, 2026, 1:49pm
19
Could it be an issue with channel range?, i.e. this:
deprioritize-unii-3-4=yes
is sometimes needed when clients cannot reach the higher frequency channels.
