hap ax3 802.11b possible in /wifi/capsman? SOLVED
I’m setting up a new hap ax3 in my existing network (RB952Ui-5ac2nD). I would like to setup wifi2.4, wifi5 and wifi6 with the hap ax3. Importance fact: I have devices that requires 802.11b.
According to the specifications the ax3 supports 802.11b/g/n/ax (https://mikrotik.com/product/hap_ax3#fndtn-specifications):
Wireless 2.4 GHz standards 802.11b/g/n/ax
But in the /wifi/capsman there is no possibility to set the band 802.11b, only 802.11g and 802.11n are available. Is this a feature that is missing in /wifi/capsman?
From what I understood: leave it to AX and it should automatically remain backwards compatible down to 802.11b.
Thank you very much for this information, I did not know this fact. It resolved my issue (setting up 802.11AX that I hadn’t before).
All good!
