Hap ax3 random wireless disconnects
Capsman config
2025-11-18 13:47:49 by RouterOS 7.21beta8
software id = 5EJC-Z10J
model = RB5009UPr+S+
serial number =
add name=bridge1
set [ find default-name=ether1 ] l2mtu=1514
set [ find default-name=ether2 ] l2mtu=1514
set [ find default-name=ether3 ] l2mtu=1514
set [ find default-name=ether4 ] l2mtu=1514
set [ find default-name=ether5 ] l2mtu=1514
set [ find default-name=ether6 ] l2mtu=1514
set [ find default-name=ether7 ] l2mtu=1514
set [ find default-name=ether8 ] l2mtu=1514
set [ find default-name=sfp-sfpplus1 ] disabled=yes l2mtu=1514
add name=LAN
/interface wifi channel
add band=2ghz-ax frequency=2412,2437,2462 name=AX_2G
add band=5ghz-ax frequency=5180,5200,5220,5240,5745,5765,5785,5805,5825 name=
AX_5G
add band=2ghz-ax frequency=2412 name=AX_2G_ch01_2412
add band=2ghz-ax frequency=2437 name=AX_2G_ch06_2437
add band=2ghz-ax frequency=2462 name=AX_2G_ch11_2462
add band=5ghz-ax frequency="5260,5280,5300,5240,5320,5500,5520,5540,5560,5580,
5600,5620,5640,5660,5680,5700,5720" name=AX_5G_DFS
add band=5ghz-ax frequency=5180 name=AX_5G_ch36_5180
add band=5ghz-ax frequency=5200 name=AX_5G_ch40_5200
add band=5ghz-ax frequency=5220 name=AX_5G_ch44_5220
add band=5ghz-ax frequency=5240 name=AX_5G_ch48_5240
add band=5ghz-ax frequency=5745 name=AX_5G_ch159_5745
add band=5ghz-ax frequency=5765 name=AX_5G_ch153_5765
add band=5ghz-ax frequency=5785 name=AX_5G_ch157_5785
add band=5ghz-ax frequency=5805 name=AX_5G_ch161_5805
add band=5ghz-ax frequency=5825 name=AX_5G_ch165_5825
add band=2ghz-ax frequency=2417 name=AX_2G_ch02_2417
add band=2ghz-ax frequency=2422 name=AX_2G_ch03_2422
add band=2ghz-ax frequency=2427 name=AX_2G_ch04_2427
add band=2ghz-ax frequency=2432 name=AX_2G_ch05_2432
add band=2ghz-ax frequency=2442 name=AX_2G_ch07_2442
add band=2ghz-ax frequency=2447 name=AX_2G_ch08_2447
add band=2ghz-ax frequency=2452 name=AX_2G_ch09_2452
add band=2ghz-ax frequency=2457 name=AX_2G_ch10_2457
add band=2ghz-ax frequency=2467 name=AX_2G_ch12_2467
add band=2ghz-ax frequency=2472 name=AX_2G_ch13_2472
add band=2ghz-n frequency=2412,2437,2462 name=N_2G
add band=5ghz-ac frequency=5180,5200,5220,5240,5745,5765,5785,5805,5825 name=
AC_5G
add band=2ghz-n frequency=2412 name=N_2G_ch01_2412
add band=2ghz-n frequency=2437 name=N_2G_ch06_2437
add band=2ghz-n frequency=2462 name=N_2G_ch11_2462
add band=5ghz-ac frequency="5260,5280,5300,5240,5320,5500,5520,5540,5560,5580,
5600,5620,5640,5660,5680,5700,5720" name=AC_5G_DFS
add band=5ghz-ac frequency=5180 name=AC_5G_ch36_5180
add band=5ghz-ac frequency=5200 name=AC_5G_ch40_5200
add band=5ghz-ac frequency=5220 name=AC_5G_ch44_5220
add band=5ghz-ac frequency=5240 name=AC_5G_ch48_5240
add band=5ghz-ac frequency=5745 name=AC_5G_ch159_5745
add band=5ghz-ac frequency=5765 name=AC_5G_ch153_5765
add band=5ghz-ac frequency=5785 name=AC_5G_ch157_5785
add band=5ghz-ac frequency=5805 name=AC_5G_ch161_5805
add band=5ghz-ac frequency=5825 name=AC_5G_ch165_5825
add band=2ghz-n frequency=2417 name=N_2G_ch02_2417
add band=2ghz-n frequency=2422 name=N_2G_ch03_2422
add band=2ghz-n frequency=2427 name=N_2G_ch04_2427
add band=2ghz-n frequency=2432 name=N_2G_ch05_2432
add band=2ghz-n frequency=2442 name=N_2G_ch07_2442
add band=2ghz-n frequency=2447 name=N_2G_ch08_2447
add band=2ghz-n frequency=2452 name=N_2G_ch09_2452
add band=2ghz-n frequency=2457 name=N_2G_ch10_2457
add band=2ghz-n frequency=2467 name=N_2G_ch12_2467
add band=2ghz-n frequency=2472 name=N_2G_ch13_2472
/interface wifi datapath
add disabled=no name=datapath1
/interface wifi security
add authentication-types=wpa2-psk disable-pmkid=yes disabled=no encryption=""
ft=yes ft-over-ds=yes name=sec1
/interface wifi configuration
add channel=N_2G country=Russia datapath=datapath1 disabled=no mode=ap name=
cfg_2G_N security=sec1 ssid=OIS
add channel=AX_2G country=Russia datapath=datapath1 disabled=no mode=ap name=
cfg_2G_AX security=sec1 ssid=OIS
add channel=AX_5G country=Russia datapath=datapath1 disabled=no mode=ap name=
cfg_5G_AX security=sec1 ssid=OIS
add channel=AC_5G country=Russia datapath=datapath1 disabled=no mode=ap name=
cfg_5G_AC security=sec1 ssid=OIS
/interface wifi steering
add disabled=no name=steering1 neighbor-group=dynamic-OIS-dbcadb6c rrm=yes
wnm=yes
add name=dhcp_pool1 ranges=192.168.88.2-192.168.88.254
add name=dhcp_pool2 ranges=192.168.88.2-192.168.88.254
add address-pool=dhcp_pool2 interface=bridge1 name=dhcp1
add bridge=bridge1 comment=LAN interface=ether2
add bridge=bridge1 interface=ether6
add bridge=bridge1 interface=ether7
add bridge=bridge1 interface=ether8
set udp-timeout=10s
/interface ovpn-server server
add mac-address= name=ovpn-server1
/interface wifi capsman
set enabled=yes interfaces=bridge1 package-path="" require-peer-certificate=
no upgrade-policy=none
/interface wifi provisioning
add action=create-dynamic-enabled disabled=no master-configuration=cfg_2G_N
name-format=%I-2G_N_Master supported-bands=2ghz-n
add action=create-dynamic-enabled disabled=no master-configuration=cfg_5G_AX
name-format=%I-5G_AX_Master supported-bands=5ghz-ax
add action=create-dynamic-enabled disabled=no master-configuration=cfg_5G_AC
name-format=%I-5G_AC_Master supported-bands=5ghz-ac
add action=create-dynamic-enabled disabled=no master-configuration=cfg_2G_AX
name-format=%I-2G_AX_Master supported-bands=2ghz-ax
add address=192.168.88.1/24 interface=bridge1 network=192.168.88.0
add address=81.90.212.158/30 comment=WAN interface=ether1 network=
81.90.212.156
/ip cloud
set update-time=no
/ip dhcp-server lease
add address=192.168.88.239 client-id=1:4:f4:1c:b:b7:a1 mac-address=
04:F4:1C:0B:B7:A1 server=dhcp1
add address=192.168.88.220 client-id=1:f4:1e:57:dc:c0:12 mac-address=
F4:1E:57:DC:C0:12 server=dhcp1
add address=192.168.88.0/24 gateway=192.168.88.1
set servers=81.90.208.3,81.90.208.4
add action=accept chain=input connection-state=established in-interface=
ether1
add action=accept chain=input connection-state=related in-interface=ether1
add action=drop chain=input in-interface=ether1
ether1
add action=jump chain=forward in-interface=ether1 jump-target=customer
add action=accept chain=customer connection-state=established
add action=accept chain=customer connection-state=related
add action=drop chain=customer
add action=accept chain=input comment="accept established,related,untracked"
add action=drop chain=input comment="drop invalid" connection-state=invalid
add action=accept chain=input comment="accept ICMP" in-interface=ether1
protocol=icmp
add action=accept chain=input comment="allow Winbox" in-interface=ether1
port=8291 protocol=tcp
add action=accept chain=input comment="allow SSH" in-interface=ether1 port=22
protocol=tcp
add action=drop chain=input comment="block everything else" in-interface=
ether1
add action=fasttrack-connection chain=forward comment=
"fast-track for established,related" connection-state=established,related
add action=accept chain=forward comment="accept established,related"
"drop access to clients behind NAT from WAN" connection-nat-state=!dstnat
connection-state=new in-interface=ether1
/ip ipsec profile
add disabled=no dst-address=0.0.0.0/0 gateway=81.90.212.157 routing-table=
main
/ip service
set ftp disabled=yes
set telnet disabled=yes
set www disabled=yes
set ssh port=2200
set winbox address=192.168.88.0/24
set api disabled=yes
/ip ssh
set strong-crypto=yes
/ip upnp interfaces
add interface=ether1 type=external
add interface=ether2 type=internal
add interface=ether3 type=internal
add interface=ether4 type=internal
add interface=ether5 type=internal
add interface=ether6 type=internal
add interface=ether7 type=internal
add interface=ether8 type=internal
add interface=bridge1 type=internal
/system clock
set time-zone-name=Asia/Yekaterinburg
/system ntp client
set enabled=yes
/system ntp client servers
add address=
add address=
/system package update
set channel=testing
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
1sp Cap
2025-11-18 14:07:41 by RouterOS 7.21beta8
software id = VVUZ-XUK6
model = cAPGi-5HaxD2HaxD
serial number =
add name=bridgeLocal
/interface ethernet switch
set 0 cpu-flow-control=yes
add bridge=bridgeLocal disabled=no name=capdp
/interface wifi
managed by CAPsMAN 192.168.88.1, traffic processing on CAP
mode: AP, SSID: OIS, channel: 5745/ax/Ceee
set [ find default-name=wifi1 ] configuration.manager=capsman .mode=ap
disabled=no
/interface wifi
mode: AP, SSID: OIS, channel: 2462/n/eC
set [ find default-name=wifi2 ] configuration.manager=capsman datapath=capdp
disabled=no
add bridge=bridgeLocal interface=ether1
add bridge=bridgeLocal interface=ether2
/ipv6 settings
set disable-ipv6=yes forward=no
/interface wifi cap
set caps-man-addresses=192.168.88.1 enabled=yes slaves-datapath=capdp
/ip dhcp-client
add comment=defconf interface=bridgeLocal
/system clock
/system identity
set name=cAP_01_AX
/system note
set show-at-login=no
/system ntp client
set enabled=yes
add address=
add address=
2nd Cap
2025-11-18 14:09:55 by RouterOS 7.21beta8
software id = WV5I-Q6R7
serial number =
/interface wifi
set [ find default-name=wifi1 ] configuration.manager=capsman datapath=capdp
disabled=no
disabled=no
/ipv6 settings
/interface wifi cap
/ip dhcp-client
/system clock
/system identity
set name=cAP_02_AX
/system ntp client
set enabled=yes
add address=
add address=
Couple of things:
I wouldn't use 40MHz bandwidth on the 2.4GHz radio, set it to 20MHz and limit TX-Power.
I notice something in your security settings:
No reason to disable pmkid, encryption is empty.
Could you try this instead:
add authentication-types=wpa2-psk disabled=no encryption=ccmp
At last, you might want to use fixed channels. With this configuration, it is highly possible that radios are using equal frequencies.
First of all, you should fix the firewall configuration of the primary 5009 router, because the rules there are incorrect, they are repeated several times, etc. I would recommend that you create this configuration as in this tutorial - firewall config
However, a good practice for creating Capsman is to create a Vlan. If that is possible, here is a tutorial -
Caps_Vlan
Simple setup CapsMann - setup
Thank you!
done
set Max TX-Power 20
done
What do you mean? To set 1 frequency for each channel?
Set fixed frquencies (or channels if you would like to call them) per radio.
Something like this (didn't test it):
add band=frequency=2412 width=20mhz name=2G_CH1
add band=frequency=2437 width=20mhz name=2G_CH6
add band=frequency=2462 width=20mhz name=2G_CH11
add band=frequency=5180  width=20/40/80mhz name=5G_CH36
add band=frequency=5260  width=20/40/80mhz name=5G_CH52
add band=frequency=5500  width=20/40/80mhz name=5G_CH100
add band=frequency=5580  width=20/40/80mhz name=5G_CH116
add channel=2G_CH1 channel.band=2ghz-n country=Russia datapath=datapath1 disabled=no mode=ap name=cfg_2G_N security=sec1 ssid=OIS
add channel=2G_CH6 channel.band=2ghz-ax country=Russia datapath=datapath1 disabled=no mode=ap name=cfg_2G_AX security=sec1 ssid=OIS
add channel=5G_CH36 channel.band=5ghz-ax country=Russia datapath=datapath1 disabled=no mode=ap name=cfg_5G_AX security=sec1 ssid=OIS
add channel=5G_CH52 channel.band=5ghz-ac country=Russia datapath=datapath1 disabled=no mode=ap name=cfg_5G_AC security=sec1 ssid=OIS
name-format=%I-2G_N_Master radio-mac=XX:XX:XX:XX:XX:XX
name-format=%I-5G_AX_Master radio-mac=XX:XX:XX:XX:XX:XX
name-format=%I-5G_AC_Master radio-mac=XX:XX:XX:XX:XX:XX
name-format=%I-2G_AX_Master radio-mac=XX:XX:XX:XX:XX:XX
This way, you have a provision rule per radio (MAC ADDRESS) and you can specify what frequencies (or channels) the accesspoint is using.
I just specified two (dual band) configurations and provision rules, you should add more in your case.
Just added.
A disconnect is in itself perfectly fine...it is only a problem when it is occuring multiple times after another.
From the screenshots:
Bandwidth was adjusted on the 2.4GHz radio. Channels (frequencies) though are overlapping. This might give interference (also depending on the number of neighboring wireless networks).
You might want to do a scan on the cAP_01_AX-2G to have an idea of anything interfering. And AFAIK this topic was related to the 5GHz radio (if memory serves me well).
Is the disconnect limited to a single client? What device is shown in the printscreen?
There are multiple devices disconnected on multiple cAPs
I’d like to share my experience resolving persistent Wi-Fi disconnections when using MikroTik CAP ax as an access point.
In my setup, several devices were randomly disconnecting — most notably:
  • A network printer
  • Two laptops with Intel AX201 and AX211 Wi-Fi cards
Interestingly, I also have three other laptops with AX200, AX211, and AX210 cards that showed no issues at all. The disconnections affected only a subset of devices, and I couldn’t find a consistent pattern in logs or signal strength.
After extensive testing and firmware checks, I decided to replace the CAP ax with a Ubiquiti UniFi U6 Pro. Since then, all connectivity issues have disappeared completely — no more drops, no more reconnections, even for the previously problematic devices.
I hesitated for a long time before switching, because I genuinely appreciate MikroTik’s philosophy and the flexibility of CAPsMAN. But in this case, stability won. I still admire MikroTik’s ecosystem and will continue using it in routing and switching roles — just not for Wi-Fi in this particular environment.
If anyone’s experiencing similar issues with Intel AX2xx clients and CAP ax, I’d recommend testing with a different AP chipset. Happy to share more details if needed.
I would be interested how you experienced practical connectivity issues with these "several devices". Was it just log-entries on the AP or did you really experience issues with the printer (e.g. wanted to print something and printer was offline, etc.), laptop constantly loosing connection making e.g. accessing network/internet or voip calls hardly impossible?
Thanks for your interest — here’s a more detailed explanation of the issues I observed, based on my own configuration and hardware.
:printer: Printer: Brother DCP-T710W
• The main issue was interrupted printing, especially with documents containing more than 10 pages.
• The most frustrating case was photo printing on glossy paper — the job would randomly stop mid-way, and the sheet would be ejected unfinished and go straight to the trash.
• At first, I suspected the printer itself or software bugs.
• After checking the AP logs, I found numerous disconnection entries during those failed print attempts.
:laptop: Laptops: Intel AX201 vs AX211
• On my setup, I use a company-issued HP laptop with an Intel AX201 card, connected via VPN to my corporate network, with frequent Teams calls.
• During calls, I often received “poor connection quality” warnings, and the audio would cut out for several seconds. In extreme cases, the VPN connection dropped entirely.
• My daughter experienced similar interruptions during Messenger calls.
• My wife, however, uses a Dell laptop with an Intel AX211 card, same VPN setup, same AP — and has no connection issues at all, despite similar work patterns.
• Based on my observations, connection problems occurred only with AX201-class devices on my network.
:satellite_antenna: Access Points
• I observed these issues only with AX-class APs: two hAP ax³ units and one cAP ax (now sold).
• I also run a separate network based on RB5009, connected to one hAP ac³ and three hAP ac² units (all with the WiFi QCOM AC package, configured as CAPs) — and none of these show any Wi-Fi problems.
Would be nice to compare the configs of both networks (CAPsMAN specifically).
What firmware version are you running?
Thanks, this is a very thorough summary. Mikrotik should really take this into consideration as well. Which ROS version did you run on your CAP ax before you've sold it?
Hello everyone !!!!! Please tell me, is this a normal number of errors or not? I'm just a beginner at this. I'm using a mANTBox ax 15s base station (L22UGS-5HaxD2HaxD-15S) firmware version 7.20.1. My clients that connect to this base station are using version 6.47.10.
All my devices were running RouterOS 7.20.2. The CAPsMAN configuration was practically identical across instances — I use a unified setup that adapts based on hardware type, distinguishing between AC and AX devices. The CAP ax was sold a week ago, and its last firmware version was also 7.20.2.
Frankly, I believe MikroTik should immediately withdraw products like hAP ax and CAP ax from sale. Wi-Fi simply does not work reliably. I’ve incurred real losses — wasted photo paper and materials due to printer failures, and countless hours spent on tuning that brought no improvement. I asked for help here on the forum, and also reached out to individual users via Facebook, but unfortunately none of it led to better Wi-Fi stability.
Currently, in my apartment I run an RB5009 with a U6 Pro connected — and finally, I don’t have to search, tweak, or babysit hardware that’s supposed to “just work.” And it does — flawlessly. The printer is extremely responsive, everything works instantly. Printing and scanning just work. No more “printer offline” messages.
The only minor drawback is the need for additional hardware to configure the U6 Pro — I solved that by installing the Ubiquiti server on a Raspberry Pi 5.
Also, I think it’s worth taking a look at Grandstream’s offering — they have some very interesting gear, it’s evolving quickly and priced well.
Just looked at mi wi-fi adapder - also have AX201…((
Yes - laptop constantly loosing connection making e.g. accessing network/internet or voip calls hardly impossible.
Also after loosing connection and reconnect again wi-fi shows that I have only local net without Internet access (If it happens it also shows “No Internet connection“ at all office laptops for a 10-15 minutes)
We have just bought 2 cap ax, It will be hart to explain why we have to by Ubiquiti UniFi U6 Pro
Agree that getting most out of MikroTik wifi, it requires a lot of tweaking. I run an RB5009 (CAPsMAN) with 2x wAP AX and 1x cAP AX...rock solid! The same for the hAP AX3 at my parents house and the hAP AX3 together with wAP AX at my mother in law's house. Imagine the clients that conenct there...
Have experience with both Unify and Grandstream, switched to MikroTik and won't go back.
If I didn’t use laptops with AX201 cards, work remotely, and rely on a Brother DCP-T710W printer, I probably wouldn’t have many complaints either. Unfortunately, in my case, the facts are clear — MikroTik’s AX devices cause real issues, both in terms of connection continuity and day-to-day stability.
I don’t deny that they may work fine in some environments, but in mine — despite many attempts and hours spent analyzing and configuring — I couldn’t achieve the level of stability I expect from hardware in this class.
so I made all tweaks, that were provided… Noting changes(
Have you also made sure that the frequencies are non overlapping? From the screenshot I see a lot of possible interference due to overlapping frequencies.
And check as well if setting transmission power to the lowest possible while maintaining good rates?
Did you perform a scan? Any idea about the wifi saturation?
