Yip, I think a lot of the issues were fixed, but it’s still not as stable as the good old AC wireless access points… Step in the right direction though…
No. I just found out about this issue recently.
I am a remote administrator and I can’t create a good ticket. I don’t know the full list of buggy devices. Sometimes they tell me about problems but they don’t tell me the device models.
I don’t want to create a ticket because tech support thinks I’m an idiot and often closes tickets without understanding the problem.
Several other bugs in older versions were fixed by other people’s tickets. Although I have repeatedly reported those problems. I have a very negative experience with tech support.
Is it possible from flat-snoop or other tool to see neighbor frequency channel width (20,40,80 MHz) ?
I haven’t tried flat-snoop, but I have used WiFi Explorer (by Intuitibits) before, and they definitely show the channel widths being used by scanned networks ![]()
@mikrotik4kvm3 I mean other mikrotik tool from routeros
Oh, sorry, didn’t realise ![]()
OK, it’s been a few days of using 7.19.2 now, and I can gladly report back that my WiFi network has been pretty rock solid!! My PS Portal used to cause a lot of issues with other devices on my network, but now works flawlessly
I only have some disconnect issues with my 2 x Google Nest Hub devices, but at least they don’t cause other devices to disconnect and/or roam like mad. I think there might be a different issue with them specifically, but I plan on ditching them anyway
Getting closer to installing cAP ax devices in my new home ![]()
I had the same exact problem. I downgraded until I got to 7.18.2. 7.18.2 resolve the problem with many Wi-Fi hosts disconnecting when they renew their DHCP leases.
I can report that the random disconnects seemingly have stopped after upgrading my hAP AX^3 to 7.19.3.
Groetjes,
I have two hAP ax^3s for APs. All my networks get leases from DHCP servers setup in a RB5009. 7.19.x caused my Wifi hosts uptime to reset when DHCP lease renewed . Downgrading to 7.18.2 resolved the uptime reset. Smart Devices where rebooting from this issue as well.
Does support look at these post to investigate?
No, they don't by default.
Best way to get their attention is to create a support ticket.
But... are you using capsman ?
I don't see this problem at all.
I do not use CAPsMAN.
Is anyone still having problems with inexplicable wifi disconnects on the 7.19.x series?
You need to be at least on 7.19.3, where the updated WiFi driver was introduced. It has been solid for me since then. Some IoT devices still disconnect randomly once per few days-weeks, but that just might be that those devices are doing their reboots or something, it does not bother me since they are always available when I need them. The important devices like phones and PCs are now rock solid for me, including the streaming devices, that had the biggest issue pre 7.19.3 version.
Hi colleagues,
In the latest ROS 7.20 release, has the known WiFi disconnection issue been fixed?
Was already solved in 7.19.3 (or earlier, can't remember exactly).
Have both parents and mother in law on a hAP AX3 running 7.20, no problems for them. Also, they got uptime of over 25 days without problems.
Thank you for your reply!
Still having this issue under 7.20 and even 7.21 beta8
I installed version 7.20 in our office on a cAP ax access point. I haven’t observed any issues for three months. The access point is under active load with 40–55 clients.
Care to share your config? As others...I haven't seen these disconnects for a long time.
