I have a hAP ax3. I setup using the QuickSet feature to setup initially. It has been working well. Recently, I lost internet connectivity on devices connected to this router, despite the router itself being able to ping the main router.
- I initially had the internet cable connected to ether1, but devices couldn’t access the internet.
- Using the terminal on the hAP ax3, I could ping the main router successfully.
- I moved the internet cable to ether2, and now devices can access the internet again.
I’m puzzled because the hAP ax3 can communicate with the main router itself, but devices connected to it couldn’t access the internet initially. I’d appreciate any guidance on what might have caused this issue and how be able to put the internet back to ether 1.
I haven’t changed the routing (see below) but everything is working.
[admin@MikroTik] /ip/route> print
Flags: D - DYNAMIC; I - INACTIVE, A - ACTIVE; c - CONNECT, s - STATIC; H - HW-OFFLOADED
Columns: DST-ADDRESS, GATEWAY, DISTANCE
# DST-ADDRESS GATEWAY DISTANCE
0 As 0.0.0.0/0 10.215.81.21 1
DIcH 10.215.81.0/24 ether1 - Internet - to upstr hp sw 0
DAc 10.215.81.0/24 bridge 0
