hAP be lite as CAP — clients disconnected every 60s at -30 dBm signal
Setup: RB5009UPr+S+ running CAPsMAN (/interface/wifi), two CAPs — a cAP ax (cAPGi-5HaxD2HaxD) and an hAP be lite (A42G-HbeP). All devices on RouterOS 7.24.3. Single SSID across both bands, WPA2/WPA3 mixed, local forwarding (traffic processing on CAP).
Problem: any client associated to the hAP be lite is disconnected on a precise 60-second cycle, regardless of signal strength. Clients on the cAP ax are stable. Removing the be lite from the network resolves the issue entirely.
Log excerpt — client is roughly 1 metre from the AP:
18:04:47 DE:C3:61:E5:65:B3@cap-wifi4(Aether) disconnected, connection lost, signal strength -38 18:04:50 DE:C3:61:E5:65:B3@cap-wifi4(Aether) connected, signal strength -36 18:05:56 DE:C3:61:E5:65:B3@cap-wifi4(Aether) disconnected, connection lost, signal strength -35 18:05:57 DE:C3:61:E5:65:B3@cap-wifi4(Aether) connected, signal strength -35 18:06:57 DE:C3:61:E5:65:B3@cap-wifi4(Aether) disconnected, connection lost, signal strength -34 18:07:00 DE:C3:61:E5:65:B3@cap-wifi4(Aether) connected, signal strength -36 18:08:00 DE:C3:61:E5:65:B3@cap-wifi4(Aether) disconnected, connection lost, signal strength -30 18:08:03 DE:C3:61:E5:65:B3@cap-wifi4(Aether) connected, signal strength -30 18:09:03 DE:C3:61:E5:65:B3@cap-wifi4(Aether) disconnected, connection lost, signal strength -30
cap-wifi4 is the be lite's 5 GHz radio. The interval is consistently 60 seconds, which suggests a timer rather than an RF problem.
The be lite also loses its CAPsMAN session periodically (connection interrupted, and once activity timeout) on a different port and cable from the cAP ax, so it does not appear to be cabling.
MLO is active on this device — mld-interface is set on both radios and an MLD interface is constructed automatically. There is no way to disable it that I can find: /interface/wifi/configuration exposes no MLO parameter, and mld-interface= on the interface only accepts existing interface names, with no empty or none option. Splitting the SSID per band did not stop the disconnects.
Has anyone else seen this on the be lite? With it disconnected, coverage is stable but limited — the other room is now uncovered, so I'd like to get this AP working rather than replace it.
Thanks.
I had a similar problem.
I solved it by disabling MLO in the Provisioning menu on CAPsMAN: for each radio, set Multi Link Mode = disabled, then reboot the hAP BE Lite.
In my case, the MLD interface got stuck in an inconsistent state, and rebooting cleared it.
It looked like the managed CAP wasn't getting its datapath configured correctly with MLO enabled, so connected devices would wait a bit for an Internet connection and then roam or disconnect.
I haven't tried re-enabling MLO yet to see whether a subsequent update has fixed the issue.
I will try that @antlanc and will report back.
Thanks for sharing @antlanc I think I had the exact same issue.
In my case it was also the case that the CAPsMAN did not have the same wifi package wifi-qcom while the CAP has wifi-qcom-be. Perhaps the provisioning of MultiLinkOperations (MLO) needs to be available on the CAPsMAN as well for it to correctly functioning?
My devices
  • CAPsMAN - hAP AX2
  • CAP - hAP BE3
OS
  • 7.24.4 on both devices
I tried again to reenable MLO in Provisioning menu and initially it did not work.
I found out that on slave hAP be lite you have to go to WiFi / CAP and set MLD datapath like Slaves Datapath (in my case it was not set).
in this way MLO is working perfectly!
Thank you, that worked for me, too.
