hAP be lite loses 5Ghz signal
Hi all.
I have 2 hAP be lite, on 2 different rooms. One connected directly to a RB5009UG and the other to a RB260GS. Both have the same behaviour, connect to the 5Ghz and after some seconds disconnects and connects to the 2.4 GHz, even if i'm right next to the AP. I've done a lot of testing, and don't seem to be related to the signal strength, authentication type... At this point not sure on what else I can test.
Maybe some can provide me some insight on this.
Thank you in advance.
Export config and share here as I can not read your config remotly :grinning_face: and I do not have this issue on my devices.
Wild guess
5GHz frequency on device which is not supported by client devices.
That's why I always set frequencies manually. So I know where it should be.
But in that case the SSID is not seen at all, here it is seen, a connection happens followed by an almost instantaneous disconnection AFAICU.
Hi, try long-term 7.24.6, it fixed my be lite wifi issues
On the meanwhile I've updated for the new version 7.25.1, which caused even more issues (wifi6 not recognized, no internet connection, huge latency...). I had to downgrade for the previous version and I did it for the long therm version. I've done some more testing and changed signal frequency and such and it seems to be hanging so far. Is not disconnecting as before, the only thing I've noticed is the speed, ~10% lower that it was... Not sure if the upgrade/downgrade had the necessary impact or if after I've done some changes that were necessary. Saw many people on forum thread complaining that the new version is causing a lot of issues.
