I was looking for latest version of hAP that contains all essentials packages, including ntp.
my current version: 6.49.15 smips, which supports all but NTP server.
on main website, didn’t find any versions that supports all, which version should I provide?
best regards.
Which hap are you talking about ?
Because normal hAP is MIPSBE, not SMIPS.
hAP LITE perhaps ? That one uses smips architecture.
What’s the exact board model ?
NTP server is part of NTP package BUT that package is not available for SMIPS.
What other functions besides ntp do you need ?
ROS7 is not recommended for hAP Lite since it doesn’t have at least 64Mb RAM and only 16Mb of storage.
If you consider upgrading, maybe AX Lite is already good enough ?
It’s hAP lite.
For Packages all I need:
system
ntp
wireless
dhcp
routing
security
advanced-tools
+/- ppp
so your saying, there is no ntp package for smips?
It’s not in extra packages ZIP file so yes, it’s not available.
