HapAC2 Factory reset from ISP settings
I did buy Mikrotik HapAC2 from my ISP and I am struggling to reset it to default configurations. I was able to flash the newest firmware, currently 7.8 via Netinstall. I have admin rights and can setup anything I want as far as I can tell.
But some of the ISP brandings still persist and Netinstall or
system/reset-configuration no-defaults=yes
is not resetting to the default Mikrotik values.
Here are the things that persist and I want to reset to defaults:
  • Webfig login page is ISP branded
system/default-configuration/script/
is still a custom ISP script
* ASCII Logo in terminal
* Webfig Design skins. They were originally in Files as .json configuration files but they still persist even after removing them from the router
Additional info:
* Yes the router is legally mine, I did pay for it
* Tried resetting via terminal and Netinstall (without keeping old configuration) but the things mentioned above still persist
* Files are empty
* I have complete admin right
Is this something that is baked into the Router hardware and cannot be set/reset?
Any other ideas on how could I reset it to the default Mikrotik config?
http://forum.mikrotik.com/t/default-configuration/165596/2
