Hardware for RF Link 10-15 meter
Hi all,
I have to create an RF link With a distance of 10 to 15 Meter.
Which product should i usw. for this? FIrst idea was to use an SXT 2 but what is with overmodulation due to the low distance?
Thanks for your ideas!
Br
Markus
Use this.
https://mikrotik.com/product/wireless_wire
You can turn down the tx power of Sxt, or you can slightly tilt them up to loose some gain, if you insist on the Sxt…
It looks good but can i use it in germany? I can‘t find Information about the regulation details for 60 GHz
If it is not an outdoor installation, you SHOULD BE fine. (I am not sure about regulations in Germany)
So if you can, try to install it close to window.
According to CEPT it is ok for indoor use.
http://www.erodocdb.dk/Docs/doc98/official/pdf/20171483EU.pdf
Check points 74/75 in the annex.
Outdoor: https://www.bundesnetzagentur.de/SharedDocs/Downloads/DE/Sachgebiete/Telekommunikation/Unternehmen_Institutionen/Frequenzen/Allgemeinzuteilungen/2008_217_Richtfunk_59-63GHz_pdf.pdf?__blob=publicationFile&v=4
Indoor:
https://www.bundesnetzagentur.de/SharedDocs/Downloads/DE/Sachgebiete/Telekommunikation/Unternehmen_Institutionen/Frequenzen/Allgemeinzuteilungen/2011_08_MGWS_pdf.pdf?__blob=publicationFile&v=4
Thanks for the info.
It´s for outdoor usage.
Br
Markus
