Hello everyone, Since my CRS312 as core / router is running at 100% constantly, I am thinking about upgrading and was looking into the CCR-2002-1G-12S+2XS, but I am not 100% sure if it would also work as some form of core switch or if I'd still need my CRS312. At the moment, my CRS is located straight behind my ISPs Router, the Fritzbox. Which design would you pick and why? Or would you do something different entirely?
Jens Home Netzwerk 2026-07-03-no-coredswitch.drawio.pdf (67.5 KB)
Jens Home Netzwerk 2026-07-03-additional-router.pdf (67.4 KB)
If you dont share the conf... every comment has no sense. if you have 100% cpu you are doing for sure something wrong, you should have the L3 HW feature correctly configured.
Okay, sure, I can share the config: `
I am just curious if this might not be a bit much for the CRS312 that I am currently using.... ``
capsman-router-2026-06-28.rsc (43.3 KB)
To me you are asking too much for this little guy, this gear you have is much of a switch than a router
Thanks, that was my initial question, so which would be the better new way, replace it with the CCR-2004 or simply add the CCR-2004 in front of it? I am not 100% if the CCR-2004 would be enough "Switch" for my tasks and if it even has a switching chipset
You don't seem to be using L3 HW features?
Where do you mean that and what by L3 HW Features?
If you want to replace CRS with a CCR, then definitely look at block diagrams ... and look for devices which have "switch chip" between ethernet ports (either RJ45 or SFP) and CPU. Not PIPE, a proper switch chip.
Currently CPU of your switch (CRS are esentially switches) is your bottleneck between different subnets and internet. If you'll replace it with CCR (a router with multiple ports) without switch chip, CPU (although much more powerful) will be bottleneck between same-subnet hosts.
Of course configuring your CRS to enable L3HW offload is an option as well, if done correctly it can allow your CRS to shine.
Have a look at docs: L3 Hardware Offloading - RouterOS - MikroTik Documentation
Not my niche of (little) experience, but it doesn't seem possible to me that you can saturate at 100% what would otherwise be a quite powerful switch, unless there is something "wrong".
Or maybe it is the capsman setup that is too much for this device?
There are a few things that could be fixed/removed, but nothing that I can see that could saturate the switch.
The explicit use of VLAN1 is usually strongly deprecated, but if it works in your setup it is just fine (in case it should cause connection issues, not overloading of the CPU).
Can you check "how" the 100% is reached?
Maybe the profile tool can tell which part(s) are using the CPU:
https://www.hellascom.gr/en/blog/mikrotik-profiler-cpu-usage-monitoring-complete-guide
capsman-router-2026-07-04-HW-Offload.rsc (43.5 KB)
Okay, I enabled HW Offloading but the CPU is still at 100%. Well, as for the VLAN1: As far as I understand it (which might be wrong....) It's just a tag and it should not be used for security reasons. The Config "grew", it is my home system....
Ich würde an den Router nur ein oder zwei (aggregierte) 10G-Trunks führen und nicht alle Switche am Router auflaufen lassen. Setz einen Switch davor und von da 1x (oder 2x) zum zentralen Router.
Der CCR ist ein Router, kein Switch, der kann zwar auch manche Sachen offloaden, aber lassen den Router Router sein und die Switche Switche. Mit so Mischgeräten kommt gern sowas raus. Und wenn ich mir das Netz anschaue, da spielt jetzt ein Switch mehr auch keine Rolle mehr.
You'll need to use Fasttrack too for you CRS312 (which has support for L3HW with NAT) to be able to use L3HW with NAT-ed connections. Read everything that mentions "fasttrack" on this documentation page and apply accordingly:
L3 Hardware Offloading | RouterOS Manual
EDIT: Please note that Fasttrack is not compatible with mangle mark-parket and mark-routing. If you have connections needing those actions, first use mark-connection on them and add the condition connection-mark=no-mark to the fasttrack rule to make it skip the connections handled by mangle.
Also, Fasttrack L3HW does not work for IPv6 yet.
More or less, bridging is what a switch should do, so the one value that is "off" should be routing.
Though I cannot understand which traffic is (or should be) routed in your setup.
Enabling correctly LH3W should however reduce your current 34.5% to 1/2 or less, so 15-17%, but the 34.5% could be "false", i.e. even more resources are needed and the current 34.5% comes from the 100% limit.
Okay, L3 HW Offloading went somewhat wrong so that I had to reset the 312 and 2 of the 328s... I guess I'll wait until the 2004 arrives and redo my config then. I never played with L3 HW Offloading before...
You didn't have to touch anything on the 328 ones, nobody said anything about those.
Campsman-Router-2026-07-04-endOfDay.rsc (43.1 KB)
I also enabled L3 HW Offloading on them, might not be related to the 312 being a bit overwhelmed but I thought it would not hurt. I assume what screwed me up was enabling HW offloading for IPv6... This is currently running on the 312, but still at 100%. What else might be worth optimizing?
From your post the majoritiy of your CPU usage is routing and bridging.
The block diagram of the CCR2004-1G-12S+2XS is here, and you can see it has no integrated switch chip.
You must be doing something that is preventing the CRS from offloading the switching to the switch chip, because the CRS block diagram has a 12 port non-blocking wire-speed switch build in to handle the L2 switching functions in dedicated hardware.
So something in the config is causing the switching function to be done by the software bridge, and the CPU in the CRS312 is meant for management functions only. And it won't be able to route or bridge in software with the performance you need. Compare the switching vs ethernet (CPU software based) performance numbers.
The one thing I notice in your config is that you have a vlan interface defined for VLAN 1, but the bridge itself is using vlan 1 too. And you have two different interfaces (both using the same ip address 192.168.100.1) accessing the same vlan on the switch.
Unless you override it, the bridge interface itself will have pvid=1. Since you don't override the pvid, any traffic from the bridge interface itself (vlanBridge) will use vlan 1 on the switch.
add igmp-snooping=yes multicast-querier=yes multicast-router=permanent name=\
vlanBridge port-cost-mode=short priority=0 querier-interval=30s \
query-interval=30s startup-query-interval=15s vlan-filtering=yes
But you also explicitly create a vlan interface for vlan 1
/interface vlan
add interface=vlanBridge name=vlan1_Management vlan-id=1
add interface=vlanBridge name=vlan10_Shelly vlan-id=10
add interface=vlanBridge name=vlan20_Guest vlan-id=20
add interface=vlanBridge name=vlan30_Office vlan-id=30
add interface=vlanBridge name=vlan40_Dante vlan-id=40
add interface=vlanBridge name=vlan50_Cams vlan-id=50
A vlan interface inserts/removes tags and uses the parent interface for transporting the tagged frames; in your case the parent interface is the bridge (vlanBridge).
If you issue the CLI commands:
/interface/bridge print
/interface/bridge/port print
/interface/bridge/vlan print
You will see what is being used.
Also a verbose export of bridge will show it has pvid=1.
I see you have added an address to the bridge itself here: And I am surprized it even allowed you to do this, you are using the same ip address 192.168.110.1 for vlanBridge (the bridge itself) and also for the vlan 1 (sub) interface.
add address=192.168.104.254/24 interface=ether1-UL-Fritzbox network=\
192.168.104.0
add address=192.168.111.1/24 interface=vlan10_Shelly network=192.168.111.0
add address=192.168.112.1/24 interface=vlan20_Guest network=192.168.112.0
add address=192.168.113.1/24 interface=vlan30_Office network=192.168.113.0
add address=192.168.110.1/24 interface=vlan1_Management network=192.168.110.0
add address=192.168.114.1/24 interface=vlan40_Dante network=192.168.114.0
add address=192.168.115.1/24 interface=vlan50_Cams network=192.168.115.0
add address=192.168.110.1 comment="for IGMP-Querrier" interface=vlanBridge \
network=192.168.110.1
That looks like a misconfiguration to me.
While on the topic of vlans and ip addresses, a vlan that isn't reserved (and is supported by your hardward) can be used as a container for any ip subnet, but for ease of maintenance and understanding, a common convention is to use a vlan id that has something in common with the subnet's ip address. The most common convention for ip subnets with /24 masks is to use the decimal value of the third octet as the vlan id; e.g. for your camera network with ip address 192.168.115.0/24 it would be more common to see vlan 115 used than vlan 50. But 50 will work as is without causing any problems (other than possible confusion for someone expecting the standard convention). But the way you have it is much better than using vlan 115 for ip subnet 192.168.110.0/24 and then using vlan 100 for subnet 192.168.114.0/24, that would be even more confusing.
If you want to understand what the bridge device does (three different things), I recommend reading RouterOS bridge mysteries explained by sindy.
The bridge interface (part of the Iinux kernel) itself always sends untagged traffic. And the router facing bridge port of the "vitual switch" by default has a pvid of 1 (as do all other bridge ports by default). The virtual link between the router and the virtual switch is a "hybrid" trunk, with untagged traffic going between the linux bridge interface and vlan 1 in the switch. You can change what vlan untagged traffic is mapped to by specifying a pvid on the bridge interface. If you want vlan 1 tagged (I wouldn't), then to reduce confusion, you should set the bridge pvid to something else (it can be an unused vlan), and don't apply any ip address to the bridge itself. But your choice of vlans ( at least for 10,20,30,40,50) has nothing to do with any problem you are seeing. However, your vlan 1 misconfiguration, having two interface both using vlan 1, one tagged (vlan1_Management) and one untagged (vlanBridge), and having those two interfaces both use ip address 192.168.100.1; that is probably contributing to the problems you are seeing.
As to your question about what to do with the CRS312, I would still use it. It will handle intra-vlan traffic between your other switches without that traffic ever even reaching the CCR. The CCR will have to do all inter-vlan (between vlan) routing.
How much traffic to you really have? Is most traffic intra-vlan (within the same vlan), or do you have a lot of inter-vlan traffic (between vlans)? What is the purpose of the vlans? Is it because you want to use a firewall to keep things separate?
If most of your traffic is within the same lan (and it probably is), then having the switch will be an advantage, especially if that vlan is used across all your switches.
If there is one "main" vlan that will communicate with the other vlans, you may get marginally better performance it you dedicate a CCR port for that vlan and have a second connection between the CRS and the CCR (I would just use untagged, and configure the port on the CRS as an access port for the particular main vlan). But that's a optimization, get things working with a single trunk port between the CRS and the CCR to start with. Because without knowing what is being routed between vlans, you won't be able to know which vlan to give preferential treatment to.
P.S. you have a typo in your first post (change CCR-2002... to CCR-2004)
I just noticed in one of your other threads that you have a 4011. Is it being used a a Dude server? How much CPU is being used on it?
I would consider moving the capsman off the CRS switch to either the 4011 or the CCR and let the CSR switches do what they are designed to do: switching L2 traffic.
This youtube video discusses hardware offloaded bridging in RouterOS
Understanding Bridge Hardware Offloading in Mikrotik Devices by Wilmer Almazan / Arawi Network Consulting (The Network Trip)
