“I have two fiber connections and a Starlink dish.
I’m using a MikroTik 5-port router (version 6, GR3).
I want ports 1 and 2 assigned to the fiber lines using PPPoE with username and password authentication.
Port 3 should be used for Starlink, connected via DHCP.
The router’s IP should be 192.168.1.1.
Ports 4 and 5 should be bridged together to create a DS-CIP bridge with IP address 192.168.99.1.
I want the fiber connections to work together to maximize speed (load balancing or bonding).
Games like PUBG and Yemeni-specific apps should use the fiber connection.
All other applications should use Starlink.
If the fiber goes down, Starlink should take over completely.
Cloud services must run through the fiber connection only, as Starlink doesn’t support them.
I would like a full script for MikroTik that sets this up.”
Think you prompted to the incorrect place. Chat GPT was in another tab…
