I've setup a eoip bridge, I'm using two outdoor RB230's with version 2.8.24 and parabolic dishes.
Here is the configuration:
mainClient1 ------ mainRouter 1 ------(wireless)------stationRouter2 ------ stationClient2
I can ping between lan workstations without a problem or routers.
The local lan use 10.180.180.8 as dns and 10.180.180.3 as the gateway. when I go to the station client it connects with no problem
to the local lan at the main, but when trying to share files or go on the internet It will not work.
Can anyone give me a clue as to why it is so slow or what I may have missed.
This is how everything is configured right now.
[admin@station] tool> bandwidth-test
status: done testing
duration: 15s
tx-current: 12Mbps
tx-10-second-average: 11.9Mbps
tx-total-average: 12Mbps
rx-current: 6.42Mbps
rx-10-second-average: 6Mbps
rx-total-average: 6.01Mbps
[admin@station] interface wireless> print
0 R name="wlan1" mtu=1500 mac-address=00:01:24:70:56:81 arp=enabled
disable-running-check=no interface-type=Atheros AR5211
radio-name="000124705681" mode=station ssid="mikrotik" frequency=5180
band=5ghz scan-list=default-ism rate-set=default
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,
54Mbps
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
ack-timeout=dynamic tx-power=default noise-floor-threshold=default
periodic-calibration=default burst-time=disabled fast-frames=no
dfs-mode=none antenna-mode=ant-a wds-mode=disabled
wds-default-bridge=none wds-ignore-ssid=no
update-stats-interval=disabled default-authentication=yes
default-forwarding=yes hide-ssid=no 802.1x-mode=none
disconnect-timeout=3s on-fail-retry-time=100ms
[admin@station] interface wireless> monitor numbers: wlan1
status: connected-to-ess
band: 5ghz
frequency: 5180
tx-rate: 54Mbps
rx-rate: 54Mbps
ssid: mikrotik
bssid: 00:01:24:70:0B:7E
radio-name: 000124700B7E
signal-strength: -67
tx-signal-strength: -66
tx-ccq: 15
rx-ccq: 21
current-ack-timeout: 28
current-distance: 28
wds-link: no
nstreme: no
framing-mode: none
routeros-version: 2.8.24
last-ip: 10.1.0.1
[admin@station] > ip address print
ADDRESS NETWORK BROADCAST INTERFACE
0 10.1.0.2/24 10.1.0.0 10.1.0.255 wlan1
1 10.180.180.202/24 10.180.180.3 10.180.180.255 ether1
[admin@station] > interface print
Flags: X - disabled, D - dynamic, R - running
NAME TYPE RX-RATE TX-RATE MTU
0 R ether1 ether 0 0 1500
1 R wlan1 wlan 0 0 1500
2 R eoip-tunnel1 eoip-tunnel 0 0 1500
3 R bridge1 bridge 0 0 1500
[admin@main] > interface wireless print
0 R name="wlan1" mtu=1500 mac-address=00:01:24:70:0B:7E arp=enabled
radio-name="000124700B7E" mode=bridge ssid="mikrotik" frequency=5180
54Mbps
[admin@master] > interface print
[admin@master] ip address> print
0 10.1.0.1/24 10.1.0.0 10.1.0.255 wlan1
1 10.180.180.201/24 10.180.180.3 10.180.180.255 ether1
