Having SNR setting in access list
Hi there,
i want to configure a lot of Accesspoints to have clients disconnect where the SNR is >=25db. Currently the access list only supports setting a signal range that does not look at the current noise floor.
We are having dual APs (2,4+5Ghz) and i want to use one access-list entry to keep the config as simple as possible.
I think that it would be really nice if MT would add a SNR setting in the access-list.
Any ideas?
I think you can have it by some scripting on Mikrotik. Try it, It shouldn’t be hard :smiley:
I’m not too hot on scripting but remembered reading this in the wiki - http://wiki.mikrotik.com/wiki/Force_Disconnect_Wireless_Stations_with_Low_CCQ
Maybe changing ‘tx-ccq’ with the equivalent of ‘noise floor’ reading and then forcing the disconnect?
Hope this helps.
EDIT - also found this which could help you write your script - http://wiki.mikrotik.com/wiki/Logging_SNR_and_thruput_values
Rgds,
Mark.
