HELP AM LOSING MY CLIENT!!!!!!!!!!!!!!!!!!!!
hi it’s my first time in the community and am glad am here
i setup a base using the 600 board with the 1watt card on it
and a client with the 433 board with 600mw card on it the distance between
is about a kilometer through a small angle of a building.
initially it was replying in 1-3ms but after about 2month it reply from
the client is about 1000 - 3000ms which is pretty bad.
[please help me out am losing my client.
try to change your frequency and if possible get another card
How about the signal, CCQ and traffic?
This response time can indicate high traffic or a low link throughput.
If your problem is the throughput you may need to take a look on your radio cards or
if the problem occour in other channels.
Are you using 1W and 600mW cards for 1Km range link? I think you dont need all this power anyway, in some
circunstances excess of power can generate more problems like link saturation.
cya
