Help configuring RB260GSP, hAP ac lite & Metal 52 ac
Good Afternoon all,
I’m completely new to MikroTik but wanted to try out there equipment in a use case. We have an RV that I want to create an internal Wifi network on and use the G-52SHPacn to pull in internet from a campground. I’m trying to figure out the best way to setup the equipment to allow me to do the following:
  • Power the RB260GSP via an AC adapter and then provide POE output to the hAP AC Lite and Metal 52 ac
  • Connect and configure the RB260GSP, hAP ac lite and Metal 52 ac via the internal network created by the hAP ac lite
Essentially I need the Metal 52 ac to act as the internet provider by pulling in an external signal and using that as the WAN source on the hAP AC Lite. I’d like to be able to login to the Metal 52 ac wirelessly when connected to the hAP ac lite in order to scan for and connect to the external wifi network at various campgrounds.
Is this possible?
Good Morning,
It should work without any problems.
The “Easy” Way: One Big Network.
Step 1 : Configure hAP AC as Main-Router
  • Basic-Config
  • DHCP-Server
  • Wlan
  • etc…
Step 2: Configure Other Mikrotik-Devices
Basic Config + RB260GSP and Metal 52 AC as DHCP-Client
Metal 52 as Static-Lease
Steo 3: Gateway
On the hAP AC unter /ip route …
Enter the IP of the Metal52 for 0.0.0.0/0
Step 4: NAT
On the Metal52
add NAT / Masquerade for outgoing
Everything schould now Work…
because it’s one Big Network, you will be able to connect to all Mikrotik devices via Web, Shh, Winbox , etc
P.S: After everything ist working like you want it to, dont forget to Secure your Mikrotik-Devices (Password, Firewall, etc..)
I appreciate the initial push. I’ve got the Metal52 setup in CPE + Router + DHCP + NAT. I then have that acquiring a signal and passing it to the WAN interface on the hAP ac Lite.
The issue I’m running into is how to login to a captive portal when connected to a network that requires a login via that method. Any ideas how to allow me to login to a captive portal when connecting the Metal52 to that type of network?
Current metal configuration is below:
# sep/18/2021 20:02:37 by RouterOS 6.48.3
# software id = E3ZJ-05D4
# model = RBMetalG-52SHPacn
# serial number = B7DE0DB59B0C
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n disabled=no frequency=auto \
    installation=outdoor mode=station-pseudobridge ssid="Raptor Guest" \
    wireless-protocol=nv2-nstreme-802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk group-ciphers=\
    tkip,aes-ccm supplicant-identity=MikroTik unicast-ciphers=tkip,aes-ccm
add name=dhcp ranges=192.168.101.100-192.168.101.200
add address-pool=dhcp disabled=no interface=ether1 name=defconf
add comment=defconf interface=ether1 list=LAN
add comment=defconf interface=wlan1 list=WAN
add list=LAN
add address=192.168.101.1/24 comment=defconf interface=ether1 network=\
    192.168.101.0
/ip dhcp-client
add comment=defconf disabled=no interface=wlan1
add address=192.168.101.0/24 comment=defconf gateway=192.168.101.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.101.1 comment=defconf name=router.lan
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/system clock
set time-zone-name=America/New_York
/system identity
set name=MikroTikMetal
/tool mac-server
/tool mac-server mac-winbox
Sounds like the metal unit should simply be an accesspoint switch antenna so to speak, no decisions required just a conduit for wifi signal to the HAPAC.
On the hapac you are connected via PC to one port do to the authentication required is my guess.
I dont think there is a way for the router to answer hotspot questions?/
After you connect to the AP with the captive portal first make sure you have an IP from the AP then make your first URL request to a non-https:// website such as http://httpforever.com/ . This usually allows the captive portal redirect page to come up.
That is part of the issue I’m running into. I’m testing this out with a Unifi Guest Controller. When I connect to the open network with a laptop directly, it grabs an IP address and pops up with the captive portal to enter credentials. When using the Metal52, it doesn’t acquire an IP address and doesn’t allow for the captive portal to login. I’m sure different portals will behave differently, I’ just unsure why the Metal52 is behaving differently than the computer.
I’m certainly open to any other ideas.
Correct on all fronts. I figured having a double NAT wouldn’t be a huge issue. I have it setup so that I can access the Metal52 directly from the wireless network generated from the hAP AC to make all things wireless and easier to use.
What I can’t figure out is how to get the Metal52 to “pass through” the same as a computer does to accept any captive portals I might encounter. Currently running a Unifi Guest portal to test and it won’t acquire an IP address unlike a computer or other wireless device.
When you say it doesn’t acquire an IP address do you mean wlan1 connects but the dhcp-client fails to acquire an address?
The use of mode=station-pseudobridge is strongly discouraged due to vendor interoperability issues, and as you are operating the Metal as a router is unnecessary. I wouldn’t expect hotspots to be using proprietary protocols, wireless-protocol=802.11 may be a better choice.
There can be other issues with captive portals as some attempt to detect when people are using routers and NAT as this potentially reduces the operators revenue on paid-for hotspots.
When you try to make a connection does the status on the Quick Set page oscillate between “searching for network” and “connected to ess”?
Correct. WLAN shows connected to ESS, gives all the stats on the AP, but doesn’t acquire a IP address through the DHCP server on the AP (in this case it’s a Unifi AP setup with a Guest Portal for testing).
Talk to me about station-pseudobridge vs 802.11. I read up on the modes here https://wiki.mikrotik.com/wiki/Manual:Wireless_Station_Modes but I’m not sure what mode would be better suited since the AP isn’t running routerOS. station-pseudobridge, station-pseudobridge-clone and station all appear to support 802.11.
Do you think bridging the connection vs setting up as an AP could alleviate the problem by not double NAT’ing?
No, rock solid on “connected to ess”.
If i recall in days long gone, connect with PC then clone pC mac address on router mac address ??
Does the Metal identify your Unifi as routerboard hardware; you will see an “R” in the first column of “Scanner” in wireless? I ask this because I am not familiar with Ubiquiti’s Unifi hardware but I know that Ubiquiti’s Airmax hardware such as Nanostation or Bullets will be identified by Mikrotik CPE’s as routerboards. When this happens routerOS will change your wireless Mode to whatever mode it see as appropriate. This can prevent the acquiring of IP.
mode and wireless-protocol are different things, not all combinations are valid. As you are not connecting to a Mikrotik AP only 802.11 works, so there isn’t much point trying to connect with the others. That page is where it says station-pseudobridge should only be used as a last resort, so unless bridging use mode=station.
No. As you are not even getting an IP address NAT doesn’t enter into it. Some captive portal systems only allow connections from one MAC address, so bridge and having multiple MACs is likely to make authentication and use worse once you have sorted the IP connectivity issue.
